I run H.A in docker.
The host is ubuntu 20.04 up to date.
HA is up to date:2021.04-6 for the core and 2021.04-3 for the supervisor.
All run well and no warning in the logs.
in Supervisor page under system, there is a notice that the supervisor doesn’t run in privileged mode.
Can anybody help me to solve this ?
I run again the install script but it doesn’t solve the problem.
Ubuntu is not an officially supported distribution of Linux for Home Assistant Supervised. Only Debian is officially supported. It means you have another message in Supervisor > System that states your installation method is “Unsupported”.
Not really. Now that it reports “supervisor is not privileged” it will probably refuse to update Home Assistant the next time you try to upgrade to the latest version.
My guess is there may be a problem with the version of Docker you have installed but it could be something else. Hopefully someone else can help you resolve it. Good luck.
