дек 20 00:06:31 demServ systemd-udevd[624]: ethtool: autonegotiation is unset or enabled, the speed and duplex are not writable.
дек 20 00:06:32 demServ avahi-daemon[393]: Joining mDNS multicast group on interface docker0.IPv4 with address 172.17.0.1.
дек 20 00:06:32 demServ avahi-daemon[393]: New relevant interface docker0.IPv4 for mDNS.
дек 20 00:06:32 demServ avahi-daemon[393]: Registering new address record for 172.17.0.1 on docker0.IPv4.
дек 20 00:06:32 demServ NetworkManager[395]: <info> [1703023592.0260] manager: (br-84a8e2f4da9f): new Bridge device (/org/freedesktop/NetworkManager/Devices/7)
дек 20 00:06:32 demServ systemd-udevd[624]: ethtool: autonegotiation is unset or enabled, the speed and duplex are not writable.
дек 20 00:06:32 demServ avahi-daemon[393]: Joining mDNS multicast group on interface br-84a8e2f4da9f.IPv4 with address 172.20.0.1.
дек 20 00:06:32 demServ avahi-daemon[393]: New relevant interface br-84a8e2f4da9f.IPv4 for mDNS.
дек 20 00:06:32 demServ avahi-daemon[393]: Registering new address record for 172.20.0.1 on br-84a8e2f4da9f.IPv4.
дек 20 00:06:32 demServ dockerd[502]: time="2023-12-20T00:06:32.524528566+02:00" level=info msg="Default bridge (docker0) is assigned with an IP address 172.17.0.0/16. Daemon option --bip can be used to set a preferred IP address"
дек 20 00:06:33 demServ systemd-udevd[578]: ethtool: autonegotiation is unset or enabled, the speed and duplex are not writable.
дек 20 00:06:33 demServ NetworkManager[395]: <info> [1703023593.0817] manager: (vethcb8d76b): new Veth device (/org/freedesktop/NetworkManager/Devices/8)
дек 20 00:06:33 demServ systemd-udevd[624]: ethtool: autonegotiation is unset or enabled, the speed and duplex are not writable.
дек 20 00:06:33 demServ kernel: hassio: port 1(veth5abe9be) entered blocking state
дек 20 00:06:33 demServ kernel: hassio: port 1(veth5abe9be) entered disabled state
дек 20 00:06:33 demServ kernel: device veth5abe9be entered promiscuous mode
дек 20 00:06:33 demServ kernel: hassio: port 1(veth5abe9be) entered forwarding state
дек 20 00:06:33 demServ NetworkManager[395]: <info> [1703023593.0949] manager: (veth5abe9be): new Veth device (/org/freedesktop/NetworkManager/Devices/9)
дек 20 00:06:36 demServ systemd[1]: systemd-hostnamed.service: Succeeded.
дек 20 00:06:36 demServ containerd[453]: time="2023-12-20T00:06:36.976675246+02:00" level=info msg="loading plugin \"io.containerd.event.v1.publisher\"..." runtime=io.containerd.runc.v2 type=io.containerd.event.v1
дек 20 00:06:36 demServ containerd[453]: time="2023-12-20T00:06:36.986262686+02:00" level=info msg="loading plugin \"io.containerd.internal.v1.shutdown\"..." runtime=io.containerd.runc.v2 type=io.containerd.internal.v1
дек 20 00:06:36 demServ containerd[453]: time="2023-12-20T00:06:36.987246046+02:00" level=info msg="loading plugin \"io.containerd.ttrpc.v1.task\"..." runtime=io.containerd.runc.v2 type=io.containerd.ttrpc.v1
дек 20 00:06:36 demServ containerd[453]: time="2023-12-20T00:06:36.988383086+02:00" level=info msg="starting signal loop" namespace=moby path=/run/containerd/io.containerd.runtime.v2.task/moby/ddaa48b96aad7869b08606f9a6f85015aae56c8912c297b237317b8c24a5bcb1 pid=803 runtime=io.containerd.runc.v2
дек 20 00:06:38 demServ systemd[514]: run-docker-runtime\x2drunc-moby-ddaa48b96aad7869b08606f9a6f85015aae56c8912c297b237317b8c24a5bcb1-runc.ozHIGj.mount: Succeeded.
дек 20 00:06:38 demServ systemd[1]: run-docker-runtime\x2drunc-moby-ddaa48b96aad7869b08606f9a6f85015aae56c8912c297b237317b8c24a5bcb1-runc.ozHIGj.mount: Succeeded.
дек 20 00:06:38 demServ systemd[1]: Started libcontainer container ddaa48b96aad7869b08606f9a6f85015aae56c8912c297b237317b8c24a5bcb1.
дек 20 00:06:39 demServ kernel: eth0: renamed from vethcb8d76b
дек 20 00:06:39 demServ NetworkManager[395]: <info> [1703023599.2770] device (veth5abe9be): carrier: link connected
дек 20 00:06:39 demServ kernel: IPv6: ADDRCONF(NETDEV_CHANGE): veth5abe9be: link becomes ready
дек 20 00:06:39 demServ kernel: hassio: port 1(veth5abe9be) entered blocking state
дек 20 00:06:39 demServ kernel: hassio: port 1(veth5abe9be) entered forwarding state
дек 20 00:06:39 demServ kernel: IPv6: ADDRCONF(NETDEV_CHANGE): hassio: link becomes ready
дек 20 00:06:39 demServ NetworkManager[395]: <info> [1703023599.2798] device (hassio): carrier: link connected
дек 20 00:06:40 demServ dockerd[502]: time="2023-12-20T00:06:40.330984166+02:00" level=info msg="Loading containers: done."
дек 20 00:06:40 demServ systemd[514]: var-lib-docker-overlay2-opaque\x2dbug\x2dcheck164955498-merged.mount: Succeeded.
дек 20 00:06:40 demServ avahi-daemon[393]: Joining mDNS multicast group on interface hassio.IPv6 with address fe80::42:22ff:fee0:e488.
дек 20 00:06:40 demServ avahi-daemon[393]: New relevant interface hassio.IPv6 for mDNS.
дек 20 00:06:40 demServ avahi-daemon[393]: Registering new address record for fe80::42:22ff:fee0:e488 on hassio.*.
дек 20 00:06:40 demServ systemd-timesyncd[387]: Timed out waiting for reply from 78.30.254.80:123 (2.debian.pool.ntp.org).
дек 20 00:06:40 demServ systemd-timesyncd[387]: Initial synchronization to time server 31.28.161.68:123 (2.debian.pool.ntp.org).
дек 20 00:06:41 demServ avahi-daemon[393]: Joining mDNS multicast group on interface veth5abe9be.IPv6 with address fe80::a43b:8ff:fe9c:4b3.
дек 20 00:06:41 demServ avahi-daemon[393]: New relevant interface veth5abe9be.IPv6 for mDNS.
дек 20 00:06:41 demServ avahi-daemon[393]: Registering new address record for fe80::a43b:8ff:fe9c:4b3 on veth5abe9be.*.
дек 20 00:06:41 demServ dockerd[502]: time="2023-12-20T00:06:41.470872065+02:00" level=info msg="Docker daemon" commit=311b9ff graphdriver=overlay2 version=24.0.7
дек 20 00:06:41 demServ dockerd[502]: time="2023-12-20T00:06:41.532665363+02:00" level=info msg="Daemon has completed initialization"
дек 20 00:06:42 demServ dockerd[502]: time="2023-12-20T00:06:42.606830179+02:00" level=info msg="API listen on /run/docker.sock"
дек 20 00:06:42 demServ systemd[1]: Started Docker Application Container Engine.
дек 20 00:06:42 demServ systemd[1]: Starting Hass.io supervisor...
дек 20 00:06:42 demServ ddaa48b96aad[502]: 2023/12/19 22:06:42 Start webserver on http://0.0.0.0:80
дек 20 00:06:46 demServ docker[884]: hassio_supervisor
дек 20 00:06:46 demServ systemd[1]: Started Hass.io supervisor.
дек 20 00:06:46 demServ systemd[1]: Reached target Multi-User System.
дек 20 00:06:46 demServ systemd[1]: Reached target Graphical Interface.
дек 20 00:06:46 demServ systemd[1]: Starting Update UTMP about System Runlevel Changes...
дек 20 00:06:46 demServ systemd[1]: systemd-update-utmp-runlevel.service: Succeeded.
дек 20 00:06:46 demServ systemd[1]: Finished Update UTMP about System Runlevel Changes.
дек 20 00:06:46 demServ systemd[1]: Startup finished in 4.608s (kernel) + 1min 634ms (userspace) = 1min 5.242s.
дек 20 00:06:47 demServ kernel: docker0: port 1(vethe494c71) entered blocking state
дек 20 00:06:47 demServ kernel: docker0: port 1(vethe494c71) entered disabled state
дек 20 00:06:47 demServ kernel: device vethe494c71 entered promiscuous mode
дек 20 00:06:47 demServ NetworkManager[395]: <info> [1703023607.8490] manager: (veth2437c57): new Veth device (/org/freedesktop/NetworkManager/Devices/10)
дек 20 00:06:47 demServ systemd-udevd[915]: ethtool: autonegotiation is unset or enabled, the speed and duplex are not writable.
дек 20 00:06:47 demServ systemd-udevd[915]: Using default interface naming scheme 'v247'.
дек 20 00:06:47 demServ systemd-udevd[916]: ethtool: autonegotiation is unset or enabled, the speed and duplex are not writable.
дек 20 00:06:47 demServ systemd-udevd[916]: Using default interface naming scheme 'v247'.
дек 20 00:06:47 demServ NetworkManager[395]: <info> [1703023607.8624] manager: (vethe494c71): new Veth device (/org/freedesktop/NetworkManager/Devices/11)
дек 20 00:06:49 demServ containerd[453]: time="2023-12-20T00:06:49.874293555+02:00" level=info msg="loading plugin \"io.containerd.event.v1.publisher\"..." runtime=io.containerd.runc.v2 type=io.containerd.event.v1
дек 20 00:06:49 demServ containerd[453]: time="2023-12-20T00:06:49.874548656+02:00" level=info msg="loading plugin \"io.containerd.internal.v1.shutdown\"..." runtime=io.containerd.runc.v2 type=io.containerd.internal.v1
дек 20 00:06:49 demServ containerd[453]: time="2023-12-20T00:06:49.874593980+02:00" level=info msg="loading plugin \"io.containerd.ttrpc.v1.task\"..." runtime=io.containerd.runc.v2 type=io.containerd.ttrpc.v1
дек 20 00:06:49 demServ containerd[453]: time="2023-12-20T00:06:49.875351695+02:00" level=info msg="starting signal loop" namespace=moby path=/run/containerd/io.containerd.runtime.v2.task/moby/6f3250b4a747232be41525e402c6fc6330b609df6f668de02733e009c0d49c56 pid=934 runtime=io.containerd.runc.v2
дек 20 00:06:49 demServ systemd[514]: run-docker-runtime\x2drunc-moby-6f3250b4a747232be41525e402c6fc6330b609df6f668de02733e009c0d49c56-runc.BA4go7.mount: Succeeded.
дек 20 00:06:49 demServ systemd[1]: run-docker-runtime\x2drunc-moby-6f3250b4a747232be41525e402c6fc6330b609df6f668de02733e009c0d49c56-runc.BA4go7.mount: Succeeded.
дек 20 00:06:49 demServ systemd[1]: Started libcontainer container 6f3250b4a747232be41525e402c6fc6330b609df6f668de02733e009c0d49c56.
дек 20 00:06:50 demServ kernel: eth0: renamed from veth2437c57
дек 20 00:06:50 demServ kernel: IPv6: ADDRCONF(NETDEV_CHANGE): vethe494c71: link becomes ready
дек 20 00:06:50 demServ kernel: docker0: port 1(vethe494c71) entered blocking state
дек 20 00:06:50 demServ kernel: docker0: port 1(vethe494c71) entered forwarding state
дек 20 00:06:50 demServ kernel: IPv6: ADDRCONF(NETDEV_CHANGE): docker0: link becomes ready
дек 20 00:06:50 demServ NetworkManager[395]: <info> [1703023610.3122] device (vethe494c71): carrier: link connected
дек 20 00:06:50 demServ NetworkManager[395]: <info> [1703023610.3138] device (docker0): carrier: link connected
дек 20 00:06:50 demServ 6f3250b4a747[502]: exec /init: exec format error
дек 20 00:06:50 demServ systemd[1]: docker-6f3250b4a747232be41525e402c6fc6330b609df6f668de02733e009c0d49c56.scope: Succeeded.
дек 20 00:06:50 demServ containerd[453]: time="2023-12-20T00:06:50.497530117+02:00" level=warning msg="error from *cgroupsv2.Manager.EventChan" error="failed to add inotify watch for \"/sys/fs/cgroup/system.slice/docker-6f3250b4a747232be41525e402c6fc6330b609df6f668de02733e009c0d49c56.scope/memory.events\": no such file or directory"
дек 20 00:06:50 demServ hassio-supervisor[908]: exec /init: exec format error
дек 20 00:06:50 demServ containerd[453]: time="2023-12-20T00:06:50.813703947+02:00" level=info msg="shim disconnected" id=6f3250b4a747232be41525e402c6fc6330b609df6f668de02733e009c0d49c56
дек 20 00:06:50 demServ containerd[453]: time="2023-12-20T00:06:50.814301178+02:00" level=warning msg="cleaning up after shim disconnected" id=6f3250b4a747232be41525e402c6fc6330b609df6f668de02733e009c0d49c56 namespace=moby
дек 20 00:06:50 demServ containerd[453]: time="2023-12-20T00:06:50.814377245+02:00" level=info msg="cleaning up dead shim"
дек 20 00:06:50 demServ dockerd[502]: time="2023-12-20T00:06:50.832613266+02:00" level=info msg="ignoring event" container=6f3250b4a747232be41525e402c6fc6330b609df6f668de02733e009c0d49c56 module=libcontainerd namespace=moby topic=/tasks/delete type="*events.TaskDelete"
дек 20 00:06:50 demServ containerd[453]: time="2023-12-20T00:06:50.838220595+02:00" level=warning msg="cleanup warnings time=\"2023-12-20T00:06:50+02:00\" level=info msg=\"starting signal loop\" namespace=moby pid=987 runtime=io.containerd.runc.v2\n"
дек 20 00:06:51 demServ kernel: docker0: port 1(vethe494c71) entered disabled state
дек 20 00:06:51 demServ kernel: veth2437c57: renamed from eth0
дек 20 00:06:51 demServ systemd-udevd[925]: ethtool: autonegotiation is unset or enabled, the speed and duplex are not writable.
дек 20 00:06:51 demServ systemd-udevd[925]: Using default interface naming scheme 'v247'.
дек 20 00:06:51 demServ NetworkManager[395]: <info> [1703023611.2308] manager: (veth2437c57): new Veth device (/org/freedesktop/NetworkManager/Devices/12)
дек 20 00:06:51 demServ NetworkManager[395]: <info> [1703023611.2587] device (veth2437c57): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
дек 20 00:06:51 demServ kernel: docker0: port 1(vethe494c71) entered blocking state
дек 20 00:06:51 demServ kernel: docker0: port 1(vethe494c71) entered forwarding state
дек 20 00:06:51 demServ NetworkManager[395]: <info> [1703023611.2627] device (veth2437c57): carrier: link connected
дек 20 00:06:51 demServ NetworkManager[395]: <info> [1703023611.2681] settings: (veth2437c57): created default wired connection 'Проводное соединение 1'
дек 20 00:06:51 demServ NetworkManager[395]: <info> [1703023611.2756] device (vethe494c71): carrier: link connected
дек 20 00:06:51 demServ NetworkManager[395]: <info> [1703023611.2762] device (docker0): carrier: link connected
дек 20 00:06:51 demServ NetworkManager[395]: <info> [1703023611.2776] device (veth2437c57): state change: unavailable -> disconnected (reason 'none', sys-iface-state: 'managed')
дек 20 00:06:51 demServ NetworkManager[395]: <info> [1703023611.2813] policy: auto-activating connection 'Проводное соединение 1' (1268654f-c4d2-3c5b-9dd1-d843d9c85a23)
дек 20 00:06:51 demServ NetworkManager[395]: <info> [1703023611.2828] device (veth2437c57): Activation: starting connection 'Проводное соединение 1' (1268654f-c4d2-3c5b-9dd1-d843d9c85a23)
дек 20 00:06:51 demServ NetworkManager[395]: <info> [1703023611.2835] device (veth2437c57): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
дек 20 00:06:51 demServ NetworkManager[395]: <info> [1703023611.2866] device (veth2437c57): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
дек 20 00:06:51 demServ NetworkManager[395]: <info> [1703023611.2884] device (veth2437c57): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
дек 20 00:06:51 demServ NetworkManager[395]: <info> [1703023611.2900] dhcp4 (veth2437c57): activation: beginning transaction (timeout in 45 seconds)
дек 20 00:06:51 demServ avahi-daemon[393]: Joining mDNS multicast group on interface veth2437c57.IPv6 with address fe80::8f63:45a2:3d9b:b597.
дек 20 00:06:51 demServ avahi-daemon[393]: New relevant interface veth2437c57.IPv6 for mDNS.
дек 20 00:06:51 demServ avahi-daemon[393]: Registering new address record for fe80::8f63:45a2:3d9b:b597 on veth2437c57.*.
дек 20 00:06:51 demServ avahi-daemon[393]: Interface veth2437c57.IPv6 no longer relevant for mDNS.
дек 20 00:06:51 demServ avahi-daemon[393]: Leaving mDNS multicast group on interface veth2437c57.IPv6 with address fe80::8f63:45a2:3d9b:b597.
дек 20 00:06:51 demServ kernel: device vethe494c71 left promiscuous mode
дек 20 00:06:51 demServ avahi-daemon[393]: Withdrawing address record for fe80::8f63:45a2:3d9b:b597 on veth2437c57.
дек 20 00:06:51 demServ NetworkManager[395]: <info> [1703023611.5684] device (veth2437c57): state change: ip-config -> unmanaged (reason 'unmanaged', sys-iface-state: 'removed')
дек 20 00:06:51 demServ NetworkManager[395]: <info> [1703023611.5854] dhcp4 (veth2437c57): canceled DHCP transaction
дек 20 00:06:51 demServ NetworkManager[395]: <info> [1703023611.5855] dhcp4 (veth2437c57): state changed unknown -> terminated
дек 20 00:06:51 demServ NetworkManager[395]: <info> [1703023611.6002] device (vethe494c71): released from master device docker0
дек 20 00:06:51 demServ avahi-daemon[393]: Joining mDNS multicast group on interface docker0.IPv6 with address fe80::42:f6ff:fe60:70f6.
дек 20 00:06:51 demServ avahi-daemon[393]: New relevant interface docker0.IPv6 for mDNS.
дек 20 00:06:51 demServ avahi-daemon[393]: Registering new address record for fe80::42:f6ff:fe60:70f6 on docker0.*.
дек 20 00:06:51 demServ systemd[1]: run-docker-netns-db00c94382a3.mount: Succeeded.
дек 20 00:06:51 demServ systemd[514]: run-docker-netns-db00c94382a3.mount: Succeeded.
дек 20 00:06:52 demServ systemd[514]: var-lib-docker-overlay2-7ebf4550a216cec6d4208083b2d6d65ac61e38e1b592e24074427dd677db0055-merged.mount: Succeeded.
дек 20 00:06:52 demServ systemd[1]: var-lib-docker-overlay2-7ebf4550a216cec6d4208083b2d6d65ac61e38e1b592e24074427dd677db0055-merged.mount: Succeeded.
дек 20 00:06:54 demServ hassio-supervisor[1009]: hassio_supervisor
дек 20 00:06:54 demServ systemd[1]: var-lib-docker-overlay2-de51adbd0f8e1dda993aa6c3aabda5593bea147fbcb7ceab016ea8d0c9cadb0c\x2dinit-merged.mount: Succeeded.
дек 20 00:06:54 demServ systemd[514]: var-lib-docker-overlay2-de51adbd0f8e1dda993aa6c3aabda5593bea147fbcb7ceab016ea8d0c9cadb0c\x2dinit-merged.mount: Succeeded.
дек 20 00:06:55 demServ systemd[514]: var-lib-docker-overlay2-de51adbd0f8e1dda993aa6c3aabda5593bea147fbcb7ceab016ea8d0c9cadb0c-merged.mount: Succeeded.
дек 20 00:06:55 demServ systemd[1]: var-lib-docker-overlay2-de51adbd0f8e1dda993aa6c3aabda5593bea147fbcb7ceab016ea8d0c9cadb0c-merged.mount: Succeeded.
дек 20 00:06:56 demServ NetworkManager[395]: <info> [1703023616.0848] manager: (veth2960fd8): new Veth device (/org/freedesktop/NetworkManager/Devices/13)
дек 20 00:06:56 demServ NetworkManager[395]: <info> [1703023616.0870] manager: (vethb29e197): new Veth device (/org/freedesktop/NetworkManager/Devices/14)
дек 20 00:06:56 demServ systemd-udevd[1023]: ethtool: autonegotiation is unset or enabled, the speed and duplex are not writable.
дек 20 00:06:56 demServ systemd-udevd[1023]: Using default interface naming scheme 'v247'.
дек 20 00:06:56 demServ systemd-udevd[1022]: ethtool: autonegotiation is unset or enabled, the speed and duplex are not writable.
дек 20 00:06:56 demServ systemd-udevd[1022]: Using default interface naming scheme 'v247'.
дек 20 00:06:56 demServ kernel: docker0: port 1(vethb29e197) entered blocking state
дек 20 00:06:56 demServ kernel: docker0: port 1(vethb29e197) entered disabled state
дек 20 00:06:56 demServ kernel: device vethb29e197 entered promiscuous mode
дек 20 00:06:57 demServ containerd[453]: time="2023-12-20T00:06:57.313942573+02:00" level=info msg="loading plugin \"io.containerd.event.v1.publisher\"..." runtime=io.containerd.runc.v2 type=io.containerd.event.v1
дек 20 00:06:57 demServ containerd[453]: time="2023-12-20T00:06:57.316317144+02:00" level=info msg="loading plugin \"io.containerd.internal.v1.shutdown\"..." runtime=io.containerd.runc.v2 type=io.containerd.internal.v1
дек 20 00:06:57 demServ containerd[453]: time="2023-12-20T00:06:57.316410765+02:00" level=info msg="loading plugin \"io.containerd.ttrpc.v1.task\"..." runtime=io.containerd.runc.v2 type=io.containerd.ttrpc.v1
дек 20 00:06:57 demServ containerd[453]: time="2023-12-20T00:06:57.317561229+02:00" level=info msg="starting signal loop" namespace=moby path=/run/containerd/io.containerd.runtime.v2.task/moby/339e0d854a7210b530ddc261435d94760bfacf1372535eca66ed6b886127460c pid=1042 runtime=io.containerd.runc.v2
дек 20 00:06:57 demServ systemd[1]: Started libcontainer container 339e0d854a7210b530ddc261435d94760bfacf1372535eca66ed6b886127460c.
дек 20 00:06:57 demServ systemd[514]: run-docker-runtime\x2drunc-moby-339e0d854a7210b530ddc261435d94760bfacf1372535eca66ed6b886127460c-runc.WXDchx.mount: Succeeded.
дек 20 00:06:57 demServ kernel: eth0: renamed from veth2960fd8
дек 20 00:06:57 demServ kernel: IPv6: ADDRCONF(NETDEV_CHANGE): vethb29e197: link becomes ready
дек 20 00:06:57 demServ kernel: docker0: port 1(vethb29e197) entered blocking state
дек 20 00:06:57 demServ kernel: docker0: port 1(vethb29e197) entered forwarding state
дек 20 00:06:57 demServ NetworkManager[395]: <info> [1703023617.5991] device (vethb29e197): carrier: link connected
дек 20 00:06:57 demServ NetworkManager[395]: <info> [1703023617.6002] device (docker0): carrier: link connected
дек 20 00:06:57 demServ 339e0d854a72[502]: exec /init: exec format error
дек 20 00:06:57 demServ systemd[1]: docker-339e0d854a7210b530ddc261435d94760bfacf1372535eca66ed6b886127460c.scope: Succeeded.
дек 20 00:06:57 demServ hassio-supervisor[1014]: exec /init: exec format error
please help me
