Supervisor not starting
Hi, while I was away something happend to my homeassistant - probably an update. Since then the supervisor and 15 related apps don’t start. It’s particularly bad, because the Samba share, that I’d need for SSH, the backup function of HASSIO, and the file and terminal applications don’t start either.
Questions:
1.) Is there a way to undo the last update, and restart the supervisor?
2.) Is there a way to access backups without samba, terminal or any of those apps – or a way to start them without the supervisor?
3.) how can I backup my automations and scripts now, without the file app - they are what took the most work.
Here is a log from the observer, if that helps anyone - i just took a sample from this endless file, not sure when exactly it fell apart…
23-08-02 01:35:34 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.FREE_SPACE/ContextType.SYSTEM
23-08-02 01:35:34 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.DNS_SERVER_IPV6_ERROR/ContextType.DNS_SERVER
23-08-02 01:35:34 INFO (MainThread) [supervisor.resolution.check] System checks complete
23-08-02 01:35:34 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.RUNNING
23-08-02 01:35:35 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
23-08-02 01:35:35 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state CoreState.RUNNING
23-08-02 01:35:35 INFO (MainThread) [supervisor.resolution.fixup] System autofix complete
23-08-02 01:39:17 WARNING (MainThread) [supervisor.addons.options] Option 'interface' does not exist in the schema for Samba share (core_samba)
23-08-02 01:44:23 WARNING (MainThread) [supervisor.addons.options] Option 'interface' does not exist in the schema for Samba share (core_samba)
23-08-02 01:46:30 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
23-08-02 01:49:29 WARNING (MainThread) [supervisor.addons.options] Option 'interface' does not exist in the schema for Samba share (core_samba)
23-08-02 01:52:08 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/synesthesiam/hassio-addons.git repository
23-08-02 01:52:08 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/zigbee2mqtt/hassio-zigbee2mqtt repository
23-08-02 01:52:08 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/hassio-addons/repository repository
23-08-02 01:52:08 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/esphome/home-assistant-addon repository
23-08-02 01:52:08 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/home-assistant/addons repository
23-08-02 01:52:08 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/CarstenHess/hassio-addons repository
23-08-02 01:52:11 WARNING (SyncWorker_2) [supervisor.addons.validate] Add-on config 'devices' use a deprecated format, the new format uses a list of paths only. Please report this to the maintainer of nexus433
23-08-02 01:52:14 WARNING (SyncWorker_2) [supervisor.addons.validate] Add-on config 'devices' use a deprecated format, the new format uses a list of paths only. Please report this to the maintainer of nexus433
23-08-02 01:52:15 INFO (MainThread) [supervisor.store] Loading add-ons from store: 90 all - 0 new - 0 remove
23-08-02 01:54:35 WARNING (MainThread) [supervisor.addons.options] Option 'interface' does not exist in the schema for Samba share (core_samba)
23-08-02 01:59:41 WARNING (MainThread) [supervisor.addons.options] Option 'interface' does not exist in the schema for Samba share (core_samba)
23-08-02 02:04:47 WARNING (MainThread) [supervisor.addons.options] Option 'interface' does not exist in the schema for Samba share (core_samba)
23-08-02 02:09:53 WARNING (MainThread) [supervisor.addons.options] Option 'interface' does not exist in the schema for Samba share (core_samba)
23-08-02 02:14:59 WARNING (MainThread) [supervisor.addons.options] Option 'interface' does not exist in the schema for Samba share (core_samba)
23-08-02 02:16:30 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
23-08-02 02:20:05 WARNING (MainThread) [supervisor.addons.options] Option 'interface' does not exist in the schema for Samba share (core_samba)
23-08-02 02:25:11 WARNING (MainThread) [supervisor.addons.options] Option 'interface' does not exist in the schema for Samba share (core_samba)
23-08-02 02:30:17 WARNING (MainThread) [supervisor.addons.options] Option 'interface' does not exist in the schema for Samba share (core_samba)
23-08-02 02:32:18 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
23-08-02 02:35:23 WARNING (MainThread) [supervisor.addons.options] Option 'interface' does not exist in the schema for Samba share (core_samba)
23-08-02 02:35:35 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state CoreState.RUNNING
23-08-02 02:35:35 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.PWNED/ContextType.ADDON
23-08-02 02:35:35 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.SECURITY/ContextType.CORE
23-08-02 02:35:35 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.DNS_SERVER_FAILED/ContextType.DNS_SERVER
23-08-02 02:35:35 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.IPV4_CONNECTION_PROBLEM/ContextType.SYSTEM
23-08-02 02:35:35 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.DOCKER_CONFIG/ContextType.SYSTEM
23-08-02 02:35:35 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.MULTIPLE_DATA_DISKS/ContextType.SYSTEM
23-08-02 02:35:35 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.TRUST/ContextType.SUPERVISOR
23-08-02 02:35:35 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.FREE_SPACE/ContextType.SYSTEM
23-08-02 02:35:35 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.DNS_SERVER_IPV6_ERROR/ContextType.DNS_SERVER
23-08-02 02:35:35 INFO (MainThread) [supervisor.resolution.check] System checks complete
23-08-02 02:35:35 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.RUNNING
23-08-02 02:35:35 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
23-08-02 02:35:35 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state CoreState.RUNNING
23-08-02 02:35:35 INFO (MainThread) [supervisor.resolution.fixup] System autofix complete
23-08-02 02:40:14 INFO (MainThread) [supervisor.host.info] Updating local host information
23-08-02 02:40:15 INFO (MainThread) [supervisor.host.services] Updating service information
23-08-02 02:40:15 INFO (MainThread) [supervisor.host.network] Updating local network information
23-08-02 02:40:16 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
23-08-02 02:40:16 INFO (MainThread) [supervisor.host.manager] Host information reload completed
23-08-02 02:40:29 WARNING (MainThread) [supervisor.addons.options] Option 'interface' does not exist in the schema for Samba share (core_samba)
23-08-02 02:45:35 WARNING (MainThread) [supervisor.addons.options] Option 'interface' does not exist in the schema for Samba share (core_samba)
23-08-02 02:46:31 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
23-08-02 02:50:41 WARNING (MainThread) [supervisor.addons.options] Option 'interface' does not exist in the schema for Samba share (core_samba)
23-08-02 02:55:47 WARNING (MainThread) [supervisor.addons.options] Option 'interface' does not exist in the schema for Samba share (core_samba)
23-08-02 03:00:53 WARNING (MainThread) [supervisor.addons.options] Option 'interface' does not exist in the schema for Samba share (core_samba)
23-08-02 03:05:59 WARNING (MainThread) [supervisor.addons.options] Option 'interface' does not exist in the schema for Samba share (core_samba)
23-08-02 03:11:05 WARNING (MainThread) [supervisor.addons.options] Option 'interface' does not exist in the schema for Samba share (core_samba)
23-08-02 03:16:11 WARNING (MainThread) [supervisor.addons.options] Option 'interface' does not exist in the schema for Samba share (core_samba)
23-08-02 03:16:31 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
23-08-02 03:21:17 WARNING (MainThread) [supervisor.addons.options] Option 'interface' does not exist in the schema for Samba share (core_samba)
23-08-02 03:26:23 WARNING (MainThread) [supervisor.addons.options] Option 'interface' does not exist in the schema for Samba share (core_samba)
23-08-02 03:31:29 WARNING (MainThread) [supervisor.addons.options] Option 'interface' does not exist in the schema for Samba share (core_samba)
23-08-02 03:35:35 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state CoreState.RUNNING
23-08-02 03:35:35 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.PWNED/ContextType.ADDON
23-08-02 03:35:35 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.SECURITY/ContextType.CORE
23-08-02 03:35:35 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.DNS_SERVER_FAILED/ContextType.DNS_SERVER
23-08-02 03:35:35 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.IPV4_CONNECTION_PROBLEM/ContextType.SYSTEM
23-08-02 03:35:35 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.DOCKER_CONFIG/ContextType.SYSTEM
23-08-02 03:35:35 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.MULTIPLE_DATA_DISKS/ContextType.SYSTEM
23-08-02 03:35:35 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.TRUST/ContextType.SUPERVISOR
23-08-02 03:35:35 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.FREE_SPACE/ContextType.SYSTEM
23-08-02 03:35:35 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.DNS_SERVER_IPV6_ERROR/ContextType.DNS_SERVER
23-08-02 03:35:35 INFO (MainThread) [supervisor.resolution.check] System checks complete
23-08-02 03:35:35 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.RUNNING
23-08-02 03:35:36 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
23-08-02 03:35:36 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state CoreState.RUNNING
23-08-02 03:35:36 INFO (MainThread) [supervisor.resolution.fixup] System autofix complete
23-08-02 03:36:35 WARNING (MainThread) [supervisor.addons.options] Option 'interface' does not exist in the schema for Samba share (core_samba)
23-08-02 03:41:41 WARNING (MainThread) [supervisor.addons.options] Option 'interface' does not exist in the schema for Samba share (core_samba)
23-08-02 03:46:33 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
23-08-02 03:46:47 WARNING (MainThread) [supervisor.addons.options] Option 'interface' does not exist in the schema for Samba share (core_samba)
23-08-02 03:51:53 WARNING (MainThread) [supervisor.addons.options] Option 'interface' does not exist in the schema for Samba share (core_samba)
23-08-02 03:56:59 WARNING (MainThread) [supervisor.addons.options] Option 'interface' does not exist in the schema for Samba share (core_samba)
23-08-02 04:02:05 WARNING (MainThread) [supervisor.addons.options] Option 'interface' does not exist in the schema for Samba share (core_samba)
23-08-02 04:07:11 WARNING (MainThread) [supervisor.addons.options] Option 'interface' does not exist in the schema for Samba share (core_samba)
23-08-02 04:12:17 WARNING (MainThread) [supervisor.addons.options] Option 'interface' does not exist in the schema for Samba share (core_samba)
23-08-02 04:16:33 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
23-08-02 04:17:23 WARNING (MainThread) [supervisor.addons.options] Option 'interface' does not exist in the schema for Samba share (core_samba)
23-08-02 04:22:29 WARNING (MainThread) [supervisor.addons.options] Option 'interface' does not exist in the schema for Samba share (core_samba)
23-08-02 04:27:35 WARNING (MainThread) [supervisor.addons.options] Option 'interface' does not exist in the schema for Samba share (core_samba)
23-08-02 04:32:19 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
23-08-02 04:32:41 WARNING (MainThread) [supervisor.addons.options] Option 'interface' does not exist in the schema for Samba share (core_samba)
23-08-02 04:35:36 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state CoreState.RUNNING
23-08-02 04:35:36 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.PWNED/ContextType.ADDON
23-08-02 04:35:36 WARNING (MainThread) [supervisor.addons.options] Option 'interface' does not exist in the schema for Samba share (core_samba)
23-08-02 04:35:36 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.SECURITY/ContextType.CORE
23-08-02 04:35:36 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.DNS_SERVER_FAILED/ContextType.DNS_SERVER
23-08-02 04:35:36 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.IPV4_CONNECTION_PROBLEM/ContextType.SYSTEM
23-08-02 04:35:36 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.DOCKER_CONFIG/ContextType.SYSTEM
23-08-02 04:35:36 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.MULTIPLE_DATA_DISKS/ContextType.SYSTEM
23-08-02 04:35:36 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.TRUST/ContextType.SUPERVISOR
23-08-02 04:35:36 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.FREE_SPACE/ContextType.SYSTEM
23-08-02 04:35:36 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.DNS_SERVER_IPV6_ERROR/ContextType.DNS_SERVER
23-08-02 04:35:36 INFO (MainThread) [supervisor.resolution.check] System checks complete
23-08-02 04:35:36 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.RUNNING
23-08-02 04:35:37 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
23-08-02 04:35:37 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state CoreState.RUNNING
23-08-02 04:35:37 INFO (MainThread) [supervisor.resolution.fixup] System autofix complete
23-08-02 04:37:47 WARNING (MainThread) [supervisor.addons.options] Option 'interface' does not exist in the schema for Samba share (core_samba)
23-08-02 04:42:53 WARNING (MainThread) [supervisor.addons.options] Option 'interface' does not exist in the schema for Samba share (core_samba)
23-08-02 04:46:34 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
23-08-02 04:46:56 INFO (MainThread) [supervisor.host.info] Updating local host information
23-08-02 04:46:57 INFO (MainThread) [supervisor.host.services] Updating service information
23-08-02 04:46:57 INFO (MainThread) [supervisor.host.network] Updating local network information
23-08-02 04:46:58 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
23-08-02 04:46:58 INFO (MainThread) [supervisor.host.manager] Host information reload completed
23-08-02 04:47:59 WARNING (MainThread) [supervisor.addons.options] Option 'interface' does not exist in the schema for Samba share (core_samba)
23-08-02 04:52:15 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/synesthesiam/hassio-addons.git repository
23-08-02 04:52:15 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/zigbee2mqtt/hassio-zigbee2mqtt repository
23-08-02 04:52:15 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/hassio-addons/repository repository
23-08-02 04:52:15 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/esphome/home-assistant-addon repository
23-08-02 04:52:15 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/home-assistant/addons repository
23-08-02 04:52:15 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/CarstenHess/hassio-addons repository
23-08-02 04:52:19 WARNING (SyncWorker_0) [supervisor.addons.validate] Add-on config 'devices' use a deprecated format, the new format uses a list of paths only. Please report this to the maintainer of nexus433
23-08-02 04:52:21 WARNING (SyncWorker_6) [supervisor.addons.validate] Add-on config 'devices' use a deprecated format, the new format uses a list of paths only. Please report this to the maintainer of nexus433
23-08-02 04:52:22 INFO (MainThread) [supervisor.store] Loading add-ons from store: 90 all - 0 new - 0 remove
23-08-02 04:53:05 WARNING (MainThread) [supervisor.addons.options] Option 'interface' does not exist in the schema for Samba share (core_samba)
23-08-02 04:58:11 WARNING (MainThread) [supervisor.addons.options] Option 'interface' does not exist in the schema for Samba share (core_samba)
23-08-02 05:03:17 WARNING (MainThread) [supervisor.addons.options] Option 'interface' does not exist in the schema for Samba share (core_samba)
23-08-02 05:08:23 WARNING (MainThread) [supervisor.addons.options] Option 'interface' does not exist in the schema for Samba share (core_samba)
23-08-02 05:13:29 WARNING (MainThread) [supervisor.addons.options] Option 'interface' does not exist in the schema for Samba share (core_samba)
23-08-02 05:16:34 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
23-08-02 05:18:35 WARNING (MainThread) [supervisor.addons.options] Option 'interface' does not exist in the schema for Samba share (core_samba)
23-08-02 05:23:41 WARNING (MainThread) [supervisor.addons.options] Option 'interface' does not exist in the schema for Samba share (core_samba)
23-08-02 05:28:47 WARNING (MainThread) [supervisor.addons.options] Option 'interface' does not exist in the schema for Samba share (core_samba)
23-08-02 05:33:53 WARNING (MainThread) [supervisor.addons.options] Option 'interface' does not exist in the schema for Samba share (core_samba)
23-08-02 05:35:37 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state CoreState.RUNNING
23-08-02 05:35:37 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.PWNED/ContextType.ADDON
23-08-02 05:35:37 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.SECURITY/ContextType.CORE
23-08-02 05:35:37 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.DNS_SERVER_FAILED/ContextType.DNS_SERVER
23-08-02 05:35:37 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.IPV4_CONNECTION_PROBLEM/ContextType.SYSTEM
23-08-02 05:35:37 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.DOCKER_CONFIG/ContextType.SYSTEM
23-08-02 05:35:37 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.MULTIPLE_DATA_DISKS/ContextType.SYSTEM
23-08-02 05:35:37 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.TRUST/ContextType.SUPERVISOR
23-08-02 05:35:37 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.FREE_SPACE/ContextType.SYSTEM
23-08-02 05:35:37 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.DNS_SERVER_IPV6_ERROR/ContextType.DNS_SERVER
23-08-02 05:35:37 INFO (MainThread) [supervisor.resolution.check] System checks complete
23-08-02 05:35:37 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.RUNNING
23-08-02 05:35:37 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
23-08-02 05:35:37 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state CoreState.RUNNING
23-08-02 05:35:37 INFO (MainThread) [supervisor.resolution.fixup] System autofix complete
23-08-02 05:38:59 WARNING (MainThread) [supervisor.addons.options] Option 'interface' does not exist in the schema for Samba share (core_samba)
23-08-02 05:44:05 WARNING (MainThread) [supervisor.addons.options] Option 'interface' does not exist in the schema for Samba share (core_samba)
23-08-02 05:46:35 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
23-08-02 05:49:11 WARNING (MainThread) [supervisor.addons.options] Option 'interface' does not exist in the schema for Samba share (core_samba)
23-08-02 05:54:17 WARNING (MainThread) [supervisor.addons.options] Option 'interface' does not exist in the schema for Samba share (core_samba)
23-08-02 05:59:23 WARNING (MainThread) [supervisor.addons.options] Option 'interface' does not exist in the schema for Samba share (core_samba)
23-08-02 06:04:29 WARNING (MainThread) [supervisor.addons.options] Option 'interface' does not exist in the schema for Samba share (core_samba)
23-08-02 06:09:35 WARNING (MainThread) [supervisor.addons.options] Option 'interface' does not exist in the schema for Samba share (core_samba)
23-08-02 06:14:41 WARNING (MainThread) [supervisor.addons.options] Option 'interface' does not exist in the schema for Samba share (core_samba)
23-08-02 06:16:35 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
Connect a monitor and keyboard to your HA dvice, use ha-console
