Supervisor not updating
Hey guys!
I’m replacing an older post with updated information.
I recently moved and when setting up home assistant, I had the error listed below.
“Unhealthy system - Supervisor update failed
System. is currently unhealthy because of an attempt to update supervisor to the latest version has failed. Use the link to learn more and how to fix this.”
When going to the link, it gives steps on how to manually update, with both methods also failing. I have done a full reboot multiple times with no success. I have tried to restore to a backup which will not complete(I assume due to the same issue.) I am using the same router with all the same IP settings as my old home. All of the related logs are listed below. Thanks in advance!
https://hastebin.com/share/utudijojix.vbnet
https://hastebin.com/share/ejomirenav.sql
https://hastebin.com/share/owaxikuvej.rust
The link to the learn more page would be nice.
