Supervisor on fresh HA OS 6.0 installation on RasPi2B give me problems
Hello!
Yesterday I’ve upgraded to HAos 6.0 and since then I’m not able to use my hub due to supervisor problems.
I thought it was due a failure during installation, so I tried a fresh installation. Nothing changed even on a brand new sd card. The startup takes ages, even loading the supervisor takes longer and doesn’t allow me to normally install or start add-ons.
I tried to downgrade to 5.7 and 5.9 but I’m not allowed using any add-ons because of the older version.
I’m at the moment with a fresh installation, with spotify connect, file editor and espHome which can’t be started. No edits to config files, except for the spotify connect one.
0% of cpu and ram usage on core and supervisor
I have no idea of what to do since I’m new to HA and previous versions I used during the latests weeks were working just fine.
2021-06-14 18:30:16 WARNING (Recorder) [homeassistant.components.recorder.util] The system could not validate that the sqlite3 database at //config/home-assistant_v2.db was shutdown cleanly
2021-06-14 18:30:28 WARNING (MainThread) [homeassistant.setup] Setup of hassio is taking over 10 seconds.
2021-06-14 18:30:57 WARNING (MainThread) [homeassistant.setup] Setup of media_source is taking over 10 seconds.
2021-06-14 18:30:57 WARNING (MainThread) [homeassistant.setup] Setup of counter is taking over 10 seconds.
2021-06-14 18:48:27 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/a0d7b954_esphome/options request
2021-06-14 18:48:27 ERROR (MainThread) [homeassistant.components.hassio] Failed to to call /addons/a0d7b954_esphome/options -
2021-06-14 18:48:51 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /core/stats request
2021-06-14 18:48:51 ERROR (MainThread) [homeassistant.components.hassio] Failed to to call /core/stats -
2021-06-14 18:48:51 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /supervisor/stats request
2021-06-14 18:48:51 ERROR (MainThread) [homeassistant.components.hassio] Failed to to call /supervisor/stats -
2021-06-14 18:49:03 ERROR (MainThread) [homeassistant.components.hassio] Failed to to call /addons/a0d7b954_esphome/start - 404 Client Error for http+docker://localhost/v1.41/containers/create?name=addon_a0d7b954_esphome: Not Found ("No such image: esphome/esphome-hassio-armv7:1.18.0")
21-06-14 16:27:08 INFO (MainThread) [supervisor.bootstrap] Initializing Supervisor Sentry
21-06-14 16:27:08 INFO (MainThread) [supervisor.bootstrap] Seting up coresys for machine: raspberrypi2
21-06-14 16:27:08 INFO (SyncWorker_0) [supervisor.docker.supervisor] Attaching to Supervisor homeassistant/armhf-hassio-supervisor with version 2021.06.0
21-06-14 16:27:09 WARNING (SyncWorker_1) [supervisor.docker.interface] Can't find homeassistant/armhf-hassio-supervisor for cleanup
21-06-14 16:27:09 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.INITIALIZE
21-06-14 16:27:10 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
21-06-14 16:27:10 INFO (MainThread) [__main__] Setting up Supervisor
21-06-14 16:27:11 INFO (MainThread) [supervisor.api] Starting API on 172.30.32.2
21-06-14 16:27:11 INFO (MainThread) [supervisor.hardware.monitor] Started Supervisor hardware monitor
21-06-14 16:27:15 INFO (MainThread) [supervisor.host.info] Updating local host information
21-06-14 16:27:15 INFO (MainThread) [supervisor.host.services] Updating service information
21-06-14 16:27:16 INFO (MainThread) [supervisor.host.network] Updating local network information
21-06-14 16:27:20 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
21-06-14 16:27:20 INFO (MainThread) [supervisor.host] Host information reload completed
21-06-14 16:27:20 INFO (MainThread) [supervisor.host.apparmor] Loading AppArmor Profiles: {'hassio-supervisor'}
21-06-14 16:27:20 INFO (MainThread) [supervisor.host.services] Reloading local service hassos-apparmor.service
21-06-14 16:27:20 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to homeassistant/armhf-hassio-dns with version 2021.04.0
21-06-14 16:27:20 INFO (MainThread) [supervisor.plugins.dns] Starting CoreDNS plugin
21-06-14 16:27:39 INFO (SyncWorker_0) [supervisor.docker.dns] Starting DNS homeassistant/armhf-hassio-dns with version 2021.04.0 - 172.30.32.3
21-06-14 16:27:39 INFO (MainThread) [supervisor.plugins.dns] Updated /etc/resolv.conf
21-06-14 16:27:40 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to homeassistant/armhf-hassio-audio with version 2021.04.0
21-06-14 16:27:41 INFO (MainThread) [supervisor.plugins.audio] Starting Audio plugin
21-06-14 16:28:13 INFO (SyncWorker_0) [supervisor.docker.audio] Starting Audio homeassistant/armhf-hassio-audio with version 2021.04.0 - 172.30.32.4
21-06-14 16:28:13 INFO (SyncWorker_1) [supervisor.docker.interface] Attaching to homeassistant/armhf-hassio-cli with version 2021.05.1
21-06-14 16:28:13 INFO (MainThread) [supervisor.plugins.cli] Starting CLI plugin
21-06-14 16:28:49 INFO (SyncWorker_1) [supervisor.docker.cli] Starting CLI homeassistant/armhf-hassio-cli with version 2021.05.1 - 172.30.32.5
21-06-14 16:28:49 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to homeassistant/armhf-hassio-observer with version 2020.10.1
21-06-14 16:28:50 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to homeassistant/armhf-hassio-multicast with version 2021.04.0
21-06-14 16:28:50 INFO (MainThread) [supervisor.plugins.multicast] Starting Multicast plugin
21-06-14 16:29:00 INFO (SyncWorker_0) [supervisor.docker.multicast] Starting Multicast homeassistant/armhf-hassio-multicast with version 2021.04.0 - Host
21-06-14 16:29:00 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
21-06-14 16:29:05 INFO (MainThread) [supervisor.homeassistant.secrets] Loaded 1 Home Assistant secrets
21-06-14 16:29:05 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to homeassistant/raspberrypi2-homeassistant with version 2021.6.4
21-06-14 16:29:06 INFO (MainThread) [supervisor.hassos] Detect Home Assistant Operating System 6.0 / BootSlot B
21-06-14 16:29:10 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/a0d7b954 repository
21-06-14 16:29:10 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/core repository
21-06-14 16:29:14 INFO (MainThread) [supervisor.store] Loading add-ons from store: 63 all - 63 new - 0 remove
21-06-14 16:29:14 INFO (MainThread) [supervisor.addons] Found 3 installed add-ons
21-06-14 16:29:14 INFO (SyncWorker_2) [supervisor.docker.interface] Attaching to homeassistant/armv7-addon-configurator with version 5.3.1
21-06-14 16:29:15 INFO (SyncWorker_1) [supervisor.docker.interface] Attaching to hassioaddons/spotify-armv7 with version 0.8.2
21-06-14 16:29:15 INFO (MainThread) [supervisor.snapshots] Found 0 snapshot files
21-06-14 16:29:15 INFO (MainThread) [supervisor.discovery] Loaded 0 messages
21-06-14 16:29:15 INFO (MainThread) [supervisor.ingress] Loaded 0 ingress sessions
21-06-14 16:29:15 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state CoreState.SETUP
21-06-14 16:29:15 INFO (MainThread) [supervisor.resolution.check] System checks complete
21-06-14 16:29:15 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.SETUP
21-06-14 16:29:16 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
21-06-14 16:29:16 INFO (MainThread) [supervisor.jobs] 'ResolutionFixup.run_autofix' blocked from execution, system is not running - CoreState.SETUP
21-06-14 16:29:16 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.SETUP
21-06-14 16:29:17 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
21-06-14 16:29:17 INFO (MainThread) [__main__] Running Supervisor
21-06-14 16:29:18 INFO (MainThread) [supervisor.hassos] Rauc: B - marked slot kernel.1 as good
21-06-14 16:29:18 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.INITIALIZE' starting 0 add-ons
21-06-14 16:29:18 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.SYSTEM' starting 0 add-ons
21-06-14 16:29:18 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.SERVICES' starting 1 add-ons
21-06-14 16:29:23 INFO (SyncWorker_0) [supervisor.docker.addon] Starting Docker add-on hassioaddons/spotify-armv7 with version 0.8.2
21-06-14 16:29:27 INFO (MainThread) [supervisor.api.middleware_security] /host/info access from a0d7b954_spotify
21-06-14 16:29:28 INFO (MainThread) [supervisor.core] Start Home Assistant Core
21-06-14 16:29:29 INFO (SyncWorker_1) [supervisor.docker.interface] Starting homeassistant
21-06-14 16:29:37 INFO (MainThread) [supervisor.homeassistant.core] Wait until Home Assistant is ready
21-06-14 16:30:27 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.STARTUP
21-06-14 16:30:27 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
21-06-14 16:30:59 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
21-06-14 16:31:23 INFO (MainThread) [supervisor.homeassistant.core] Detect a running Home Assistant instance
21-06-14 16:31:23 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.APPLICATION' starting 2 add-ons
21-06-14 16:31:39 INFO (SyncWorker_2) [supervisor.docker.interface] Cleaning addon_core_configurator application
21-06-14 16:34:21 INFO (SyncWorker_2) [supervisor.docker.addon] Starting Docker add-on homeassistant/armv7-addon-configurator with version 5.3.1
21-06-14 16:34:38 ERROR (SyncWorker_0) [supervisor.docker] Image esphome/esphome-hassio-armv7 not exists for addon_a0d7b954_esphome
21-06-14 16:34:38 INFO (SyncWorker_0) [supervisor.resolution.module] Create new issue IssueType.MISSING_IMAGE - ContextType.ADDON / a0d7b954_esphome
21-06-14 16:34:38 INFO (SyncWorker_0) [supervisor.resolution.module] Create new suggestion SuggestionType.EXECUTE_REPAIR - ContextType.ADDON / a0d7b954_esphome
21-06-14 16:34:39 WARNING (MainThread) [supervisor.addons] Can't start Add-on a0d7b954_esphome
21-06-14 16:34:44 INFO (MainThread) [supervisor.misc.tasks] All core tasks are scheduled
21-06-14 16:34:44 INFO (MainThread) [supervisor.core] Supervisor is up and running
21-06-14 16:34:44 INFO (MainThread) [supervisor.host.info] Updating local host information
21-06-14 16:34:44 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
21-06-14 16:34:45 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state CoreState.RUNNING
21-06-14 16:34:45 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.SECURITY/ContextType.CORE
21-06-14 16:34:45 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.PWNED/ContextType.ADDON
21-06-14 16:34:46 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.FREE_SPACE/ContextType.SYSTEM
21-06-14 16:34:46 INFO (MainThread) [supervisor.resolution.module] Create new suggestion SuggestionType.CREATE_FULL_SNAPSHOT - ContextType.SYSTEM / None
21-06-14 16:34:46 INFO (MainThread) [supervisor.resolution.check] System checks complete
21-06-14 16:34:46 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.RUNNING
21-06-14 16:34:59 INFO (MainThread) [supervisor.host.services] Updating service information
21-06-14 16:35:00 INFO (MainThread) [supervisor.host.network] Updating local network information
21-06-14 16:35:14 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
21-06-14 16:35:14 INFO (MainThread) [supervisor.host] Host information reload completed
21-06-14 16:35:52 ERROR (MainThread) [supervisor.utils.codenotary] Timeout while processing CodeNotary
21-06-14 16:35:53 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
21-06-14 16:35:53 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state CoreState.RUNNING
21-06-14 16:35:53 INFO (MainThread) [supervisor.resolution.fixup] System autofix complete
21-06-14 16:37:45 WARNING (MainThread) [supervisor.misc.tasks] Watchdog/Application found a problem with observer plugin!
21-06-14 16:37:49 INFO (SyncWorker_4) [supervisor.docker.interface] Stopping hassio_observer application
21-06-14 16:38:47 INFO (SyncWorker_4) [supervisor.docker.interface] Cleaning hassio_observer application
21-06-14 16:38:59 INFO (MainThread) [supervisor.plugins.observer] Starting observer plugin
21-06-14 16:46:16 INFO (SyncWorker_0) [supervisor.docker.observer] Starting Observer homeassistant/armhf-hassio-observer with version 2020.10.1 - 172.30.32.6
21-06-14 16:49:03 ERROR (SyncWorker_4) [supervisor.docker] Image esphome/esphome-hassio-armv7 not exists for addon_a0d7b954_esphome
The pi3 has been the minimum recommended hardware for quite a while.
Ok, so why put a pi2 version on 6.0 release then?
and why I could use it smoothly untill yesterday ?
I’m getting the same on a Pi 3 B+ running Supervisor version 2021.06.3 on Hass.io
21-06-19 09:18:29 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.FREE_SPACE/ContextType.SYSTEM
21-06-19 09:18:29 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.PWNED/ContextType.ADDON
21-06-19 09:18:31 INFO (MainThread) [supervisor.resolution.check] System checks complete
21-06-19 09:18:31 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.RUNNING
21-06-19 09:18:38 INFO (MainThread) [supervisor.host.services] Updating service information
21-06-19 09:18:38 INFO (MainThread) [supervisor.host.network] Updating local network information
21-06-19 09:18:42 ERROR (MainThread) [supervisor.utils.codenotary] Timeout while processing CodeNotary
21-06-19 09:18:42 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
21-06-19 09:18:42 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state CoreState.RUNNING
21-06-19 09:18:42 INFO (MainThread) [supervisor.resolution.fixup] System autofix complete
21-06-19 09:18:47 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
21-06-19 09:18:47 INFO (MainThread) [supervisor.host] Host information reload completed```
Ditto have the same issue on the same device
Hi everyone, has anyone managed to solve this problem? I am doing a fresh install on my rpi0w. Despite this error, the configuration proceeds, but once completed a series of errors are generated, especially the supervisor is not available.
Anyone have any ideas?
Getting the same after updating to OS 6.2 in a Rpi 4 1GB
same here on RPI 3b
Having nearly exactly the same symptoms and error logs as op, on a Pi 3b. Started around 2 months ago. A full wipe & snapshot restore changed nothing.
Hi. I can only add that I have the same problem on a fresh install of 2021.12.5 on Raspberry Pi 3B. The only thing I can do is get HA started and then it quickly becomes unusable. Only way to recover is to pull the plug. Hopefully someone has some idea on where to start troubleshooting. Read something about disk issues on another thread, but is seemed related to SSDs and not SD cards.
I’m having the same issue on a 3B and 2021.12.7. I works for some days, then starts to become unstable until eventually everything is inaccessible. The host can’t even be rebooted from the UI as the supervisor can’t load.
