Supervisor on Raspberry Pi 4 Core
Hi guys,
this is my second post here, so I’m quite new about this environment and this system.
I’m now installing Home Assistant Core running on my Raspberry Pi 4 4GB, after installation and first configuration, I’ve noticed that the Supervisor is not installed, so how can do to install it manually?
Thanks in advance
Alan
You can’t on HA Core. You need HA OS or HA Supervised.
Thanks for the quick reply,
And this is possible to run in Raspberry Pi OS?
Alan
Possible, but you will end up with an ‘unsupported’ installation.
Better to use Debian. See in the community guides for installation instructions.
@francisp I’ve only one problem using HA OS, now I would try it and and his potential, but I’ve done some Home Automations using NodeRED and his dashboard, and I can’t be without it!
So, now I’ve tried HA OS in VM over Windows, but I’ve got the curiosity to try it in RPI ambient!
Could you suggest me how to?
Alan
I followed the istructions on the official page for installation of HA OS, I’ve fleshed with etcher the SD, and once plugged into the slot of RPI I’ve powered up RPI.
After booting the result was:
What have I to do now, since the supervisor has not started?
This is the fourth try and the resoult is the same! I’ve tried also the 32-bit version but nothing…
Alan
You will never see anything on that screen. Look in your router (or with fing) what ip address your pi has, and go to http://ip:8123
