Supervisor panel won't load (just spins) - can't update
New here, and have tried searching for similar issues, but can’t seem to find a solution. I am inexperienced when it comes to home assistant.
The supervisor panel in Home Assistant will not load, and therefore I don’t know how to get access to update my version of Home Assistant so that I can use the mobile companion app with remote access (nabu casa).
When I click on the supervisor panel there are no error messages and I only see the spinning progress icon.
Here is the system health information:
Is there a way I can update my system without access to the supervisor panel?
Thank you for any and all help. If you can please help with step by step instructions on things I should try.
System Health
version: core-2021.2.1
installation_type: Home Assistant OS
dev: false
hassio: true
docker: true
virtualenv: false
python_version: 3.8.7
os_name: Linux
os_version: 5.4.79-v8
arch: aarch64
timezone: America/Edmonton
logged_in: true
subscription_expiration: November 25, 2023 at 5:00 PM
relayer_connected: true
remote_enabled: false
remote_connected: false
alexa_enabled: true
google_enabled: true
can_reach_cert_server: ok
can_reach_cloud_auth: ok
can_reach_cloud: ok
host_os: Home Assistant OS 5.10
update_channel: stable
supervisor_version: supervisor-2023.10.1
docker_version: 19.03.13
disk_total: 58.0 GB
disk_used: 3.5 GB
healthy: failed to load: Unhealthy
supported: failed to load: Unsupported
board: rpi4-64
supervisor_api: ok
version_api: ok
installed_addons: File editor (5.2.0), Lutron Certificate (0.6.0)
dashboards: 1
resources: 0
mode: auto-gen
api_endpoint_reachable: ok
Logs:
2023-10-28 13:14:45 ERROR (MainThread) [homeassistant.components.lutron_caseta.config_flow] Timeout while trying to connect to bridge at 192.168.1.50
2023-10-28 13:24:26 ERROR (SyncWorker_0) [homeassistant.components.tuya] Method [Discovery] fails 1 time(s) using poll interval 605 - error: you can discovery once in 1020 seconds
Like you, I’m a new user to Home Assistant. I installed on a raspberry PI 4, following the instructions for installing directly. The supervisor panel does not appear at all. Did you find anything out?
