Hello!
Having RaspberryPi 4 with plain Debian 12 installed. (Not a Raspberry OS)
Trying to set up a supervisor in this system, but the installation fails with the message:
dpkg -i homeassistant-supervised.deb
(Reading database ... 57576 files and directories currently installed.)
Preparing to unpack homeassistant-supervised.deb ...
[warn]
[warn] If you want more control over your own system, run
[warn] Home Assistant as a VM or run Home Assistant Core
[warn] via a Docker container.
Leaving 'diversion of /etc/NetworkManager/NetworkManager.conf to /etc/NetworkManager/NetworkManager.conf.real by homeassistant-supervised'
Leaving 'diversion of /etc/NetworkManager/system-connections/default to /etc/NetworkManager/system-connections/default.real by homeassist'
Leaving 'diversion of /etc/docker/daemon.json to /etc/docker/daemon.json.real by homeassistant-supervised'
Leaving 'diversion of /etc/network/interfaces to /etc/network/interfaces.real by homeassistant-supervised'
Unpacking homeassistant-supervised (1.5.0) over (1.5.0) ...
Setting up homeassistant-supervised (1.5.0) ...
[info] Restarting NetworkManager
[info] Set up systemd-journal-gatewayd socket file
[info] Enable systemd-journal-gatewayd
dpkg: error processing package homeassistant-supervised (--install):
installed homeassistant-supervised package post-installation script subprocess returned error exit status 1
Errors were encountered while processing:
same happens if trying to install using apt, all prerequisites are installed as per documentation.
The system is installed on the SSD disk not on SD card.
any ideas on how to install it successfully?
