My server is a VM on esxi. I tried moving the virtual disk to a new data source.
Now the server boots but the addons don’t start and I can’t load the addon page (http://SERVER:8123/hassio/dashboard)
I tried running the supervisor repair from the CLI and get the following:
Processing... Done.
Error: 'a0d7b954_zerotier'
I had the ZeroTier addon installed at one time, but uninstalled it the day before.
Here is the supervisor logs:
22-11-22 20:17:00 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/home-assistant/addons repository
22-11-22 20:17:00 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/alexbelgium/hassio-addons repository
22-11-22 20:17:00 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/Expaso/hassos-addons repository
22-11-22 20:17:00 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/Apipa169/Assistant-Relay-for-Hassio repository
22-11-22 20:17:00 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/blakeblackshear/frigate-hass-addons repository
22-11-22 20:17:00 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/allangood/rtlamr2mqtt repository
22-11-22 20:17:00 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/hassio-addons/repository repository
22-11-22 20:17:00 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/esphome/home-assistant-addon repository
22-11-22 20:17:00 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/thomasmauerer/hassio-addons repository
22-11-22 20:17:00 ERROR (MainThread) [aiohttp.server] Error handling request
File "/usr/local/lib/python3.10/site-packages/aiohttp/web_protocol.py", line 433, in _handle_request
resp = await request_handler(request)
File "/usr/local/lib/python3.10/site-packages/sentry_sdk/integrations/aiohttp.py", line 126, in sentry_app_handle
reraise(*_capture_exception(hub))
File "/usr/local/lib/python3.10/site-packages/sentry_sdk/_compat.py", line 56, in reraise
raise value
File "/usr/local/lib/python3.10/site-packages/sentry_sdk/integrations/aiohttp.py", line 116, in sentry_app_handle
response = await old_handle(self, request)
File "/usr/local/lib/python3.10/site-packages/aiohttp/web_app.py", line 504, in _handle
resp = await handler(request)
File "/usr/local/lib/python3.10/site-packages/aiohttp/web_middlewares.py", line 117, in impl
return await handler(request)
File "/usr/src/supervisor/supervisor/api/middleware/security.py", line 138, in system_validation
File "/usr/src/supervisor/supervisor/api/middleware/security.py", line 204, in token_validation
File "/usr/src/supervisor/supervisor/api/utils.py", line 60, in wrap_api
answer = await method(api, *args, **kwargs)
File "/usr/src/supervisor/supervisor/api/supervisor.py", line 103, in info
ATTR_ADDONS: [
File "/usr/src/supervisor/supervisor/api/supervisor.py", line 107, in <listcomp>
ATTR_VERSION: addon.version,
File "/usr/src/supervisor/supervisor/addons/addon.py", line 254, in version
return self.persist[ATTR_VERSION]
File "/usr/src/supervisor/supervisor/addons/addon.py", line 234, in persist
return self.sys_addons.data.user[self.slug]
KeyError: 'a0d7b954_zerotier'
raise value
ATTR_ADDONS: [
22-11-22 20:17:01 WARNING (SyncWorker_7) [supervisor.store.data] Can't read /data/addons/core/matter_server/config.yaml: Service matter not found @ data['discovery'][0]. Got 'matter'
22-11-22 20:17:01 WARNING (SyncWorker_3) [supervisor.store.data] Can't read /data/addons/core/matter_server/config.yaml: Service matter not found @ data['discovery'][0]. Got 'matter'
22-11-22 20:17:01 INFO (MainThread) [supervisor.store] Loading add-ons from store: 149 all - 0 new - 0 remove
22-11-22 20:17:01 ERROR (MainThread) [aiohttp.server] Error handling request
raise value
ATTR_ADDONS: [
Not sure what to do next…
