Supervisor says Im running a unsupported installation
Versie
core-2022.9.6
The link transfers me to Connectivity check - Home Assistant
I logged into my machine to
sudo busctl set-property org.freedesktop.NetworkManager /org/freedesktop/NetworkManager org.freedesktop.NetworkManager ConnectivityCheckEnabled b true
and rebooted afterwards.
Supervisor still says unsupported installation.
Any idea on this?
Log:
22-09-22 16:12:38 INFO (MainThread) [supervisor.api.middleware.security] /supervisor/info access from cebe7a76_hassio_google_drive_backup
22-09-22 16:12:38 INFO (MainThread) [supervisor.api.middleware.security] /backups access from cebe7a76_hassio_google_drive_backup
22-09-22 16:12:58 INFO (MainThread) [supervisor.misc.scheduler] Shutting down scheduled tasks
22-09-22 16:12:58 INFO (MainThread) [supervisor.docker.monitor] Stopped docker events monitor
22-09-22 16:12:58 INFO (MainThread) [supervisor.api] Stopping API on 172.30.32.2
22-09-22 16:12:58 INFO (MainThread) [supervisor.dbus.manager] Closed conection to system D-Bus.
22-09-22 16:12:58 INFO (MainThread) [supervisor.hardware.monitor] Stopped Supervisor hardware monitor
22-09-22 16:12:58 WARNING (MainThread) [supervisor.homeassistant.websocket] Connection is closed
22-09-22 16:12:58 INFO (MainThread) [supervisor.core] Supervisor is down - 100
22-09-22 16:12:58 INFO (MainThread) [__main__] Closing Supervisor
[14:12:58] INFO: Supervisor restart after closing
22-09-22 14:12:59 INFO (MainThread) [__main__] Initializing Supervisor setup
22-09-22 14:12:59 INFO (MainThread) [supervisor.bootstrap] Initializing Supervisor Sentry
22-09-22 16:12:59 INFO (MainThread) [supervisor.bootstrap] Seting up coresys for machine: qemux86-64
22-09-22 16:12:59 INFO (SyncWorker_0) [supervisor.docker.supervisor] Attaching to Supervisor ghcr.io/home-assistant/amd64-hassio-supervisor with version 2022.09.1
22-09-22 16:12:59 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
22-09-22 16:12:59 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.INITIALIZE
22-09-22 16:12:59 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
22-09-22 16:12:59 INFO (MainThread) [__main__] Setting up Supervisor
22-09-22 16:12:59 INFO (MainThread) [supervisor.api] Starting API on 172.30.32.2
22-09-22 16:12:59 INFO (MainThread) [supervisor.hardware.monitor] Started Supervisor hardware monitor
22-09-22 16:12:59 INFO (MainThread) [supervisor.dbus.manager] Connected to system D-Bus.
22-09-22 16:12:59 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface io.hass.os
22-09-22 16:12:59 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface org.freedesktop.systemd1
22-09-22 16:12:59 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface org.freedesktop.login1
22-09-22 16:12:59 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface org.freedesktop.hostname1
22-09-22 16:12:59 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface org.freedesktop.timedate1
22-09-22 16:13:00 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface org.freedesktop.NetworkManager
22-09-22 16:13:00 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface de.pengutronix.rauc
22-09-22 16:13:00 WARNING (MainThread) [supervisor.dbus.manager] Can't load dbus interface de.pengutronix.rauc: The name de.pengutronix.rauc was not provided by any .service files
22-09-22 16:13:00 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface org.freedesktop.resolve1
22-09-22 16:13:00 INFO (MainThread) [supervisor.host.info] Updating local host information
22-09-22 16:13:00 INFO (MainThread) [supervisor.host.services] Updating service information
22-09-22 16:13:00 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
22-09-22 16:13:00 INFO (MainThread) [supervisor.host.manager] Host information reload completed
22-09-22 16:13:00 INFO (MainThread) [supervisor.host.network] Updating local network information
22-09-22 16:13:00 WARNING (MainThread) [supervisor.host.network] Requested to update interface eno1 which does not exist or is disabled.
22-09-22 16:13:00 INFO (MainThread) [supervisor.host.apparmor] Loading AppArmor Profiles: {'hassio-supervisor'}
22-09-22 16:13:00 INFO (MainThread) [supervisor.docker.monitor] Started docker events monitor
22-09-22 16:13:00 INFO (SyncWorker_1) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-cli with version 2022.08.0
22-09-22 16:13:00 INFO (SyncWorker_1) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-dns with version 2022.04.1
22-09-22 16:13:00 INFO (MainThread) [supervisor.plugins.dns] Updated /etc/resolv.conf
22-09-22 16:13:00 INFO (SyncWorker_1) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-audio with version 2022.07.0
22-09-22 16:13:00 INFO (SyncWorker_1) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-observer with version 2021.10.0
22-09-22 16:13:00 INFO (SyncWorker_1) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-multicast with version 2022.02.0
22-09-22 16:13:00 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
22-09-22 16:13:00 INFO (MainThread) [supervisor.homeassistant.secrets] Loaded 14 Home Assistant secrets
22-09-22 16:13:00 INFO (SyncWorker_1) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/qemux86-64-homeassistant with version 2022.9.6
22-09-22 16:13:00 INFO (MainThread) [supervisor.os.manager] No Home Assistant Operating System found
22-09-22 16:13:01 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/db21ed7f repository
22-09-22 16:13:01 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/5c53de3b repository
22-09-22 16:13:01 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/a0d7b954 repository
22-09-22 16:13:01 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/core repository
22-09-22 16:13:01 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/cebe7a76 repository
22-09-22 16:13:01 INFO (MainThread) [supervisor.store] Loading add-ons from store: 135 all - 135 new - 0 remove
22-09-22 16:13:01 INFO (MainThread) [supervisor.addons] Found 1 installed add-ons
22-09-22 16:13:01 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to sabeechen/hassio-google-drive-backup-amd64 with version 0.108.4
22-09-22 16:13:01 INFO (MainThread) [supervisor.backups.manager] Found 5 backup files
22-09-22 16:13:01 INFO (MainThread) [supervisor.discovery] Loaded 0 messages
22-09-22 16:13:01 INFO (MainThread) [supervisor.ingress] Loaded 3 ingress sessions
22-09-22 16:13:01 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state CoreState.SETUP
22-09-22 16:13:01 INFO (MainThread) [supervisor.resolution.check] System checks complete
22-09-22 16:13:01 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.SETUP
22-09-22 16:13:01 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
22-09-22 16:13:01 INFO (MainThread) [supervisor.jobs] 'ResolutionFixup.run_autofix' blocked from execution, system is not running - CoreState.SETUP
22-09-22 16:13:01 INFO (MainThread) [__main__] Running Supervisor
22-09-22 16:13:01 INFO (MainThread) [supervisor.jobs] 'OSManager.mark_healthy' blocked from execution, no Home Assistant OS available
22-09-22 16:13:01 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.INITIALIZE' starting 0 add-ons
22-09-22 16:13:01 INFO (MainThread) [supervisor.core] Supervisor reboot detected
22-09-22 16:13:01 INFO (MainThread) [supervisor.misc.tasks] All core tasks are scheduled
22-09-22 16:13:01 INFO (MainThread) [supervisor.core] Supervisor is up and running
22-09-22 16:13:01 INFO (MainThread) [supervisor.host.info] Updating local host information
22-09-22 16:13:01 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state CoreState.RUNNING
22-09-22 16:13:01 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.SECURITY/ContextType.CORE
22-09-22 16:13:01 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.DNS_SERVER_FAILED/ContextType.DNS_SERVER
22-09-22 16:13:01 INFO (MainThread) [supervisor.host.services] Updating service information
22-09-22 16:13:01 INFO (MainThread) [supervisor.host.network] Updating local network information
22-09-22 16:13:01 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.PWNED/ContextType.ADDON
22-09-22 16:13:01 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.NO_CURRENT_BACKUP/ContextType.SYSTEM
22-09-22 16:13:01 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.DNS_SERVER_IPV6_ERROR/ContextType.DNS_SERVER
22-09-22 16:13:01 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.IPV4_CONNECTION_PROBLEM/ContextType.SYSTEM
22-09-22 16:13:01 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.TRUST/ContextType.SUPERVISOR
22-09-22 16:13:01 INFO (MainThread) [supervisor.host.manager] Host information reload completed
22-09-22 16:13:02 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.FREE_SPACE/ContextType.SYSTEM
22-09-22 16:13:02 INFO (MainThread) [supervisor.resolution.check] System checks complete
22-09-22 16:13:02 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.RUNNING
22-09-22 16:13:02 WARNING (MainThread) [supervisor.resolution.evaluations.base] Connectivity checks are required for Home Assistant. (more-info: https://www.home-assistant.io/more-info/unsupported/connectivity_check)
22-09-22 16:13:02 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
22-09-22 16:13:02 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state CoreState.RUNNING
22-09-22 16:13:02 INFO (MainThread) [supervisor.resolution.fixup] System autofix complete
22-09-22 16:13:03 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.RUNNING
22-09-22 16:13:03 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
Solved it with this post:
