venterce
(Chuck Venter)
1
I’m running Home Assistant OS on a dedicated laptop (Intel i7, 8GB RAM) and have noticed several related symptoms that suggest a Supervisor issue:
Symptoms:
- Add-ons is missing from the Settings menu entirely
http://homeassistant.local:8123/hassio/supervisor/logs loads but is completely blank
- Advanced SSH & Web Terminal add-on installs but returns 502 Bad Gateway and never starts
- The original Terminal add-on shows
[core-ssh ~]$ prompt with no Python3 available
- AppDaemon is running and connected to HA, but cannot see the HA SQLite database tables
System info:
- Installation method: Home Assistant OS
- Core: 2026.3.1
- Supervisor: 2026.03.1
- Operating System: 17.1
- Frontend: 20260304.0
What still works:
- HA Core is fully functional — automations, Zigbee, Z-Wave, Sense integration all working
- Add-on dashboard accessible via direct URL
hassio/dashboard
- AppDaemon installed and authenticated successfully
What I’ve tried:
- Rebooting HA
- Installing Advanced SSH & Web Terminal — installs but won’t start
- Checking Supervisor logs — page is blank
Is this a known Supervisor degraded state? Is there a repair command or safe fix short of a full reinstall?
tom_l
2
They were renamed “Apps”.
venterce
(Chuck Venter)
3
Thanks Tom, I see that now, I’m sorry I was looking at old documentation.
Should I post the other issues again without that header?
AutoDIY
(Ettore)
5
hello,
did you configure the user name and password?
