I searched the forum and documentation and unfortunately can’t find a solution why my supervisor stuck at 2022.9.1 and marked as unsupported (Debian 11 OS and docker).
I changed my NetworkManager settings. I can’t see any more bugs in supervisor logs (only complaining about other programs in docker but it didn’t bother before). I did a lot of host reboots and still unsupported and can’t update.
Below is some information that may be useful? Thanks!
System Information
version | core-2022.10.1 |
installation_type | Home Assistant Supervised |
dev | false |
hassio | true |
docker | true |
user | root |
virtualenv | false |
python_version | 3.10.5 |
os_name | Linux |
os_version | 5.10.0-18-amd64 |
arch | x86_64 |
timezone | Europe/Warsaw |
config_dir | /config |
Home Assistant Community Store
GitHub API | ok |
GitHub Content | ok |
GitHub Web | ok |
GitHub API Calls Remaining | 5000 |
Installed Version | 1.27.2 |
Stage | running |
Available Repositories | 1118 |
Downloaded Repositories | 17 |
Airly
can_reach_server | ok |
requests_remaining | 45 |
requests_per_day | 100 |
Home Assistant Cloud
logged_in | false |
can_reach_cert_server | ok |
can_reach_cloud_auth | ok |
can_reach_cloud | ok |
Home Assistant Supervisor
host_os | Debian GNU/Linux 11 (bullseye) |
update_channel | stable |
supervisor_version | supervisor-2022.09.1 |
agent_version | 1.4.1 |
docker_version | 20.10.18 |
disk_total | 57.9 GB |
disk_used | 31.0 GB |
healthy | true |
supported | failed to load: Unsupported |
supervisor_api | ok |
version_api | ok |
installed_addons | File editor (5.4.1), Mosquitto broker (6.1.3), Samba share (10.0.0), Home Assistant Google Drive Backup (0.108.4), AdGuard Home (4.7.4), UniFi Network Application (2.4.0), ZeroTier One (0.15.1), Terminal & SSH (9.6.1), Zigbee2MQTT (1.28.0-1), VLC (0.1.3), SQLite Web (3.6.1), FTP (4.6.1), ESPHome (2022.9.4) |
Dashboards
dashboards | 3 |
resources | 7 |
views | 10 |
mode | storage |
Recorder
oldest_recorder_run | October 7, 2022 at 7:04 AM |
current_recorder_run | October 8, 2022 at 3:05 PM |
estimated_db_size | 232.20 MiB |
database_engine | sqlite |
database_version | 3.38.5 |
Spotify
api_endpoint_reachable | ok |
Żadnego Ale
Supervisor logs after restart:
22-10-08 15:19:26 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.INITIALIZE
22-10-08 15:19:26 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
22-10-08 15:19:26 INFO (MainThread) [main] Setting up Supervisor
22-10-08 15:19:26 INFO (MainThread) [supervisor.api] Starting API on 172.30.32.2
22-10-08 15:19:26 INFO (MainThread) [supervisor.hardware.monitor] Started Supervisor hardware monitor
22-10-08 15:19:26 INFO (MainThread) [supervisor.dbus.manager] Connected to system D-Bus.
22-10-08 15:19:26 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface io.hass.os
22-10-08 15:19:26 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface org.freedesktop.systemd1
22-10-08 15:19:26 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface org.freedesktop.login1
22-10-08 15:19:26 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface org.freedesktop.hostname1
22-10-08 15:19:26 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface org.freedesktop.timedate1
22-10-08 15:19:26 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface org.freedesktop.NetworkManager
22-10-08 15:19:26 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface de.pengutronix.rauc
22-10-08 15:19:26 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface org.freedesktop.resolve1
22-10-08 15:19:26 INFO (MainThread) [supervisor.host.info] Updating local host information
22-10-08 15:19:26 INFO (MainThread) [supervisor.host.services] Updating service information
22-10-08 15:19:26 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
22-10-08 15:19:27 INFO (MainThread) [supervisor.host.manager] Host information reload completed
22-10-08 15:19:27 INFO (MainThread) [supervisor.host.network] Updating local network information
22-10-08 15:19:27 INFO (MainThread) [supervisor.host.apparmor] Loading AppArmor Profiles: {‘hassio-supervisor’}
22-10-08 15:19:27 INFO (MainThread) [supervisor.docker.monitor] Started docker events monitor
22-10-08 15:19:27 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to Package amd64-hassio-cli · GitHub with version 2022.08.0
22-10-08 15:19:27 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to Package amd64-hassio-dns · GitHub with version 2022.04.1
22-10-08 15:19:27 INFO (MainThread) [supervisor.plugins.dns] Updated /etc/resolv.conf
22-10-08 15:19:27 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to Package amd64-hassio-audio · GitHub with version 2022.07.0
22-10-08 15:19:27 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to Package amd64-hassio-observer · GitHub with version 2021.10.0
22-10-08 15:19:27 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to Package amd64-hassio-multicast · GitHub with version 2022.02.0
22-10-08 15:19:27 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
22-10-08 15:19:28 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to Package qemux86-64-homeassistant · GitHub with version 2022.10.1
22-10-08 15:19:28 INFO (MainThread) [supervisor.homeassistant.secrets] Loaded 14 Home Assistant secrets
22-10-08 15:19:28 INFO (MainThread) [supervisor.os.manager] No Home Assistant Operating System found
22-10-08 15:19:28 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/core repository
22-10-08 15:19:28 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/cebe7a76 repository
22-10-08 15:19:28 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/a0d7b954 repository
22-10-08 15:19:28 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/45df7312 repository
22-10-08 15:19:28 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/5c53de3b repository
22-10-08 15:19:28 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/c50d1fa4 repository
22-10-08 15:19:29 INFO (MainThread) [supervisor.store] Loading add-ons from store: 73 all - 73 new - 0 remove
22-10-08 15:19:29 INFO (MainThread) [supervisor.addons] Found 13 installed add-ons
22-10-08 15:19:29 INFO (SyncWorker_5) [supervisor.docker.interface] Attaching to Package unifi/amd64 · GitHub with version 2.4.0
22-10-08 15:19:29 INFO (SyncWorker_2) [supervisor.docker.interface] Attaching to homeassistant/amd64-addon-configurator with version 5.4.1
22-10-08 15:19:29 INFO (SyncWorker_3) [supervisor.docker.interface] Attaching to homeassistant/amd64-addon-mosquitto with version 6.1.3
22-10-08 15:19:29 INFO (SyncWorker_6) [supervisor.docker.interface] Attaching to sabeechen/hassio-google-drive-backup-amd64 with version 0.108.4
22-10-08 15:19:29 INFO (SyncWorker_4) [supervisor.docker.interface] Attaching to Package ftp/amd64 · GitHub with version 4.6.1
22-10-08 15:19:29 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to Package sqlite-web/amd64 · GitHub with version 3.6.1
22-10-08 15:19:29 INFO (SyncWorker_7) [supervisor.docker.interface] Attaching to Package zerotier/amd64 · GitHub with version 0.15.1
22-10-08 15:19:29 INFO (SyncWorker_5) [supervisor.docker.interface] Attaching to Package esphome-hassio-amd64 · GitHub with version 2022.9.4
22-10-08 15:19:29 INFO (SyncWorker_2) [supervisor.docker.interface] Attaching to homeassistant/amd64-addon-samba with version 10.0.0
22-10-08 15:19:29 INFO (SyncWorker_3) [supervisor.docker.interface] Attaching to zigbee2mqtt/zigbee2mqtt-amd64 with version 1.28.0-1
22-10-08 15:19:29 INFO (SyncWorker_6) [supervisor.docker.interface] Attaching to Package adguard/amd64 · GitHub with version 4.7.4
22-10-08 15:19:29 INFO (SyncWorker_4) [supervisor.docker.interface] Attaching to homeassistant/amd64-addon-vlc with version 0.1.3
22-10-08 15:19:29 INFO (SyncWorker_1) [supervisor.docker.interface] Attaching to homeassistant/amd64-addon-ssh with version 9.6.1
22-10-08 15:19:29 INFO (MainThread) [supervisor.backups.manager] Found 4 backup files
22-10-08 15:19:29 INFO (MainThread) [supervisor.discovery] Loaded 3 messages
22-10-08 15:19:29 INFO (MainThread) [supervisor.ingress] Loaded 15 ingress sessions
22-10-08 15:19:29 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state CoreState.SETUP
22-10-08 15:19:29 INFO (MainThread) [supervisor.resolution.check] System checks complete
22-10-08 15:19:29 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.SETUP
22-10-08 15:19:29 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
22-10-08 15:19:29 INFO (MainThread) [supervisor.jobs] ‘ResolutionFixup.run_autofix’ blocked from execution, system is not running - CoreState.SETUP
22-10-08 15:19:29 INFO (MainThread) [main] Running Supervisor
22-10-08 15:19:29 INFO (MainThread) [supervisor.jobs] ‘OSManager.mark_healthy’ blocked from execution, no Home Assistant OS available
22-10-08 15:19:29 INFO (MainThread) [supervisor.addons] Phase ‘AddonStartup.INITIALIZE’ starting 0 add-ons
22-10-08 15:19:29 INFO (MainThread) [supervisor.core] Supervisor reboot detected
22-10-08 15:19:29 INFO (MainThread) [supervisor.misc.tasks] All core tasks are scheduled
22-10-08 15:19:29 INFO (MainThread) [supervisor.core] Supervisor is up and running
22-10-08 15:19:29 INFO (MainThread) [supervisor.host.info] Updating local host information
22-10-08 15:19:29 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state CoreState.RUNNING
22-10-08 15:19:29 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.FREE_SPACE/ContextType.SYSTEM
22-10-08 15:19:29 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.TRUST/ContextType.SUPERVISOR
22-10-08 15:19:29 INFO (MainThread) [supervisor.host.services] Updating service information
22-10-08 15:19:29 INFO (MainThread) [supervisor.host.network] Updating local network information
22-10-08 15:19:29 INFO (MainThread) [supervisor.host.manager] Host information reload completed
22-10-08 15:19:29 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.IPV4_CONNECTION_PROBLEM/ContextType.SYSTEM
22-10-08 15:19:29 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.DNS_SERVER_IPV6_ERROR/ContextType.DNS_SERVER
22-10-08 15:19:29 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.PWNED/ContextType.ADDON
22-10-08 15:19:30 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.SECURITY/ContextType.CORE
22-10-08 15:19:30 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.DNS_SERVER_FAILED/ContextType.DNS_SERVER
22-10-08 15:19:30 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.NO_CURRENT_BACKUP/ContextType.SYSTEM
22-10-08 15:19:30 INFO (MainThread) [supervisor.resolution.check] System checks complete
22-10-08 15:19:30 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.RUNNING
22-10-08 15:19:30 WARNING (MainThread) [supervisor.resolution.evaluations.base] Found unsupported images: {‘portainer/portainer-ce’, ‘mariadb’, ‘nextcloud’, ‘lmscommunity/logitechmediaserver’, ‘minimworld/minimserver’} (more-info: Unsupported software - Home Assistant)
22-10-08 15:19:31 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
22-10-08 15:19:31 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state CoreState.RUNNING
22-10-08 15:19:31 INFO (MainThread) [supervisor.resolution.fixup] System autofix complete
22-10-08 15:29:36 INFO (MainThread) [supervisor.store.git] Update add-on GitHub - home-assistant/addons: ➕ Docker add-ons for Home Assistant repository
22-10-08 15:29:36 INFO (MainThread) [supervisor.store.git] Update add-on GitHub - sabeechen/hassio-google-drive-backup: Automatically create and sync Home Assistant backups into Google Drive repository
22-10-08 15:29:36 INFO (MainThread) [supervisor.store.git] Update add-on GitHub - zigbee2mqtt/hassio-zigbee2mqtt: Official Zigbee2MQTT Home Assistant add-on repository
22-10-08 15:29:36 INFO (MainThread) [supervisor.store.git] Update add-on GitHub - esphome/home-assistant-addon: ESPHome Home Assistant Add-on repository
22-10-08 15:29:36 INFO (MainThread) [supervisor.store.git] Update add-on GitHub - hassio-addons/repository: Home Assistant Community Add-ons repository
22-10-08 15:29:36 INFO (MainThread) [supervisor.store.git] Update add-on GitHub - w35l3y/hassio-addons: w35l3y's Hass.IO Add-on Repository repository
22-10-08 15:29:36 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
22-10-08 15:29:38 INFO (MainThread) [supervisor.store] Loading add-ons from store: 73 all - 0 new - 0 remove
gdbus introspect --system --dest org.freedesktop.NetworkManager --object-path /org/freedesktop/NetworkManager --only-properties:
node /org/freedesktop/NetworkManager {
interface org.freedesktop.NetworkManager {
properties:
readonly ao Devices = [‘/org/freedesktop/NetworkManager/Devices/1’, ‘/org/freedesktop/NetworkManager/Devices/2’, ‘/org/freedesktop/NetworkManager/Devices/3’, ‘/org/freedesktop/NetworkManager/Devices/4’, ‘/org/freedesktop/NetworkManager/Devices/5’, ‘/org/freedesktop/NetworkManager/Devices/6’, ‘/org/freedesktop/NetworkManager/Devices/7’, ‘/org/freedesktop/NetworkManager/Devices/9’, ‘/org/freedesktop/NetworkManager/Devices/11’, ‘/org/freedesktop/NetworkManager/Devices/13’, ‘/org/freedesktop/NetworkManager/Devices/15’, ‘/org/freedesktop/NetworkManager/Devices/17’, ‘/org/freedesktop/NetworkManager/Devices/19’, ‘/org/freedesktop/NetworkManager/Devices/21’, ‘/org/freedesktop/NetworkManager/Devices/23’, ‘/org/freedesktop/NetworkManager/Devices/25’, ‘/org/freedesktop/NetworkManager/Devices/27’, ‘/org/freedesktop/NetworkManager/Devices/31’, ‘/org/freedesktop/NetworkManager/Devices/33’, ‘/org/freedesktop/NetworkManager/Devices/35’, ‘/org/freedesktop/NetworkManager/Devices/40’, ‘/org/freedesktop/NetworkManager/Devices/42’, ‘/org/freedesktop/NetworkManager/Devices/63’];
readonly ao AllDevices = [‘/org/freedesktop/NetworkManager/Devices/1’, ‘/org/freedesktop/NetworkManager/Devices/2’, ‘/org/freedesktop/NetworkManager/Devices/3’, ‘/org/freedesktop/NetworkManager/Devices/4’, ‘/org/freedesktop/NetworkManager/Devices/5’, ‘/org/freedesktop/NetworkManager/Devices/6’, ‘/org/freedesktop/NetworkManager/Devices/7’, ‘/org/freedesktop/NetworkManager/Devices/9’, ‘/org/freedesktop/NetworkManager/Devices/11’, ‘/org/freedesktop/NetworkManager/Devices/13’, ‘/org/freedesktop/NetworkManager/Devices/15’, ‘/org/freedesktop/NetworkManager/Devices/17’, ‘/org/freedesktop/NetworkManager/Devices/19’, ‘/org/freedesktop/NetworkManager/Devices/21’, ‘/org/freedesktop/NetworkManager/Devices/23’, ‘/org/freedesktop/NetworkManager/Devices/25’, ‘/org/freedesktop/NetworkManager/Devices/27’, ‘/org/freedesktop/NetworkManager/Devices/31’, ‘/org/freedesktop/NetworkManager/Devices/33’, ‘/org/freedesktop/NetworkManager/Devices/35’, ‘/org/freedesktop/NetworkManager/Devices/40’, ‘/org/freedesktop/NetworkManager/Devices/42’, ‘/org/freedesktop/NetworkManager/Devices/63’];
readonly ao Checkpoints = ;
readonly b NetworkingEnabled = true;
readwrite b WirelessEnabled = true;
readonly b WirelessHardwareEnabled = true;
readwrite b WwanEnabled = true;
readonly b WwanHardwareEnabled = true;
readwrite b WimaxEnabled = false;
readonly b WimaxHardwareEnabled = false;
readonly ao ActiveConnections = [‘/org/freedesktop/NetworkManager/ActiveConnection/3’];
readonly o PrimaryConnection = ‘/org/freedesktop/NetworkManager/ActiveConnection/3’;
readonly s PrimaryConnectionType = ‘802-3-ethernet’;
readonly u Metered = 4;
readonly o ActivatingConnection = ‘/org/freedesktop/NetworkManager/ActiveConnection/3’;
readonly b Startup = false;
readonly s Version = ‘1.30.6’;
readonly au Capabilities = [1];
readonly u State = 70;
readonly u Connectivity = 4;
readonly b ConnectivityCheckAvailable = true;
readwrite b ConnectivityCheckEnabled = true;
readonly s ConnectivityCheckUri = ‘http://checkonline.home-assistant.io/online.txt’;
readwrite a{sv} GlobalDnsConfiguration = {};
node IP4Config {
node ActiveConnection {
node AgentManager {
node Devices {
node DHCP4Config {
node DnsManager {
node IP6Config {
node Settings {
cat /etc/NetworkManager/NetworkManager.conf:
[main]
dns=default
plugins=keyfile
autoconnect-retries-default=0
rc-manager=file
[keyfile]
unmanaged-devices=type:bridge;type:tun;driver:veth
[logging]
backend=journal
[connection]
connection.mdns=2
connection.llmnr=2
[connectivity]
uri=http://checkonline.home-assistant.io/online.txt
[device]
wifi.scan-rand-mac-address=no
busctl get-property org.freedesktop.NetworkManager /org/freedesktop/NetworkManager org.freedesktop.NetworkManager ConnectivityCheckAvailable:
b true
