Supervisor update failed / Critical error
I’m using Home Assistant on a Raspberry Pi 4B (4GB RAM) with the Home Assistant Cloud subscription.
I just updated Home Assistant Supervisor around 2024.05.1 and something went wrong apparently…
Capture d’écran 2024-05-08 à 15.13.03
Capture d’écran 2024-05-08 à 15.13.13
I tried to restart everything but it doesn’t change anything, and I tried to restore a recent and apparently impossible partial backup…
Do you know what I can do?
Here are the logs I get:
AttributeError: 'NoneType' object has no attribute 'object_manager'
2024-05-08 14:54:05.266 CRITICAL (MainThread) [supervisor.core] Fatal error happening on load Task <coroutine object OSManager.load at 0x7f80ebf3e0>:
2024-05-08 14:54:07.095 WARNING (SyncWorker_1) [supervisor.store.data] Can't read /data/addons/git/09e60fb6/external/ring-client-api/packages/homebridge-ring/config.schema.json: Invalid Add-on config!. Got {'pluginAlias': 'Ring', 'pluginType': 'platform', 'singular': True, 'customUi': True, 'customUiPath': './lib/homebridge-ui', 'customUiDevServer': 'http://localhost:3000/api/plugins/settings-ui/homebridge-ring', 'headerDisplay': 'See [the wiki](https://github.com/dgreif/ring/wiki/Refresh-Tokens) for details on generating a refresh token', 'accountLinkingHeader': 'Please supply your Ring credentials.  These will be used to contact the Ring servers and generate a unique access token for your acc...
2024-05-08 14:54:08.001 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/5c53de3b repository
2024-05-08 14:54:08.003 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/09e60fb6 repository
2024-05-08 14:54:08.004 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/a0d7b954 repository
2024-05-08 14:54:08.009 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/core repository
2024-05-08 14:54:09.589 WARNING (SyncWorker_0) [supervisor.store.data] Can't read /data/addons/git/09e60fb6/external/ring-client-api/packages/homebridge-ring/config.schema.json: Invalid Add-on config!. Got {'pluginAlias': 'Ring', 'pluginType': 'platform', 'singular': True, 'customUi': True, 'customUiPath': './lib/homebridge-ui', 'customUiDevServer': 'http://localhost:3000/api/plugins/settings-ui/homebridge-ring', 'headerDisplay': 'See [the wiki](https://github.com/dgreif/ring/wiki/Refresh-Tokens) for details on generating a refresh token', 'accountLinkingHeader': 'Please supply your Ring credentials.  These will be used to contact the Ring servers and generate a unique access token for your acc...
2024-05-08 14:54:09.873 INFO (MainThread) [supervisor.store] Loading add-ons from store: 79 all - 79 new - 0 remove
2024-05-08 14:54:09.986 INFO (MainThread) [supervisor.addons.manager] Found 9 installed add-ons
2024-05-08 14:54:10.025 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/hassio-addons/ssh/aarch64 with version 17.2.0
2024-05-08 14:54:10.037 INFO (MainThread) [supervisor.docker.interface] Attaching to homeassistant/aarch64-addon-configurator with version 5.8.0
2024-05-08 14:54:10.042 INFO (MainThread) [supervisor.docker.interface] Attaching to homeassistant/aarch64-addon-mosquitto with version 6.4.0
2024-05-08 14:54:10.060 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/esphome/esphome-hassio with version 2024.4.2
2024-05-08 14:54:10.063 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/koush/scrypted with version v0.102.0-jammy-full
2024-05-08 14:54:10.100 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/hassio-addons/ftp/aarch64 with version 5.0.2
2024-05-08 14:54:10.101 INFO (MainThread) [supervisor.docker.interface] Attaching to homeassistant/aarch64-addon-silabs-multiprotocol with version 2.4.5
2024-05-08 14:54:10.114 INFO (MainThread) [supervisor.docker.interface] Attaching to homeassistant/aarch64-addon-vlc with version 0.3.0
2024-05-08 14:54:10.116 INFO (MainThread) [supervisor.docker.interface] Attaching to homeassistant/aarch64-addon-matter-server with version 5.6.0
2024-05-08 14:54:10.516 INFO (MainThread) [supervisor.backups.manager] Found 150 backup files
2024-05-08 14:54:11.048 INFO (MainThread) [supervisor.discovery] Loaded 5 messages
2024-05-08 14:54:11.049 INFO (MainThread) [supervisor.ingress] Loaded 3 ingress sessions
2024-05-08 14:54:11.049 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state setup
2024-05-08 14:54:11.049 INFO (MainThread) [supervisor.resolution.checks.base] Run check for disabled_data_disk/system
2024-05-08 14:54:11.049 INFO (MainThread) [supervisor.resolution.checks.base] Run check for multiple_data_disks/system
2024-05-08 14:54:11.049 INFO (MainThread) [supervisor.resolution.check] System checks complete
2024-05-08 14:54:11.049 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state setup
2024-05-08 14:54:11.050 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
2024-05-08 14:54:11.051 INFO (MainThread) [supervisor.jobs] 'ResolutionFixup.run_autofix' blocked from execution, system is not healthy - setup
2024-05-08 14:54:11.051 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state setup
2024-05-08 14:54:11.052 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
2024-05-08 14:54:11.052 INFO (MainThread) [__main__] Running Supervisor
2024-05-08 14:54:11.058 CRITICAL (MainThread) [supervisor.core] System is running in an unhealthy state and needs manual intervention!
2024-05-08 14:54:11.066 INFO (MainThread) [supervisor.os.manager] Rauc: B - marked slot kernel.1 as good
2024-05-08 14:54:11.096 INFO (MainThread) [supervisor.addons.manager] Phase 'initialize' starting 0 add-ons
2024-05-08 14:54:11.098 INFO (MainThread) [supervisor.core] Supervisor reboot detected
2024-05-08 14:54:11.099 INFO (MainThread) [supervisor.misc.tasks] All core tasks are scheduled
2024-05-08 14:54:11.102 INFO (MainThread) [supervisor.core] Supervisor is up and running
2024-05-08 14:54:11.102 INFO (MainThread) [supervisor.host.info] Updating local host information
2024-05-08 14:54:11.104 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state running
2024-05-08 14:54:11.104 INFO (MainThread) [supervisor.resolution.checks.base] Run check for trust/supervisor
2024-05-08 14:54:11.128 INFO (MainThread) [supervisor.resolution.checks.base] Run check for disabled_data_disk/system
2024-05-08 14:54:11.128 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_ipv6_error/dns_server
2024-05-08 14:54:11.149 INFO (MainThread) [supervisor.resolution.checks.base] Run check for ipv4_connection_problem/system
2024-05-08 14:54:11.150 INFO (MainThread) [supervisor.resolution.checks.base] Run check for pwned/addon
2024-05-08 14:54:11.165 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
2024-05-08 14:54:11.308 INFO (MainThread) [supervisor.resolution.checks.base] Run check for security/core
2024-05-08 14:54:11.308 INFO (MainThread) [supervisor.resolution.checks.base] Run check for no_current_backup/system
2024-05-08 14:54:11.312 INFO (MainThread) [supervisor.resolution.checks.base] Run check for multiple_data_disks/system
2024-05-08 14:54:11.312 INFO (MainThread) [supervisor.resolution.checks.base] Run check for free_space/system
2024-05-08 14:54:11.316 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_failed/dns_server
2024-05-08 14:54:11.335 INFO (MainThread) [supervisor.resolution.checks.base] Run check for docker_config/system
2024-05-08 14:54:11.336 INFO (MainThread) [supervisor.resolution.check] System checks complete
2024-05-08 14:54:11.336 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state running
2024-05-08 14:54:11.888 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
2024-05-08 14:54:11.889 INFO (MainThread) [supervisor.jobs] 'ResolutionFixup.run_autofix' blocked from execution, system is not healthy - setup
2024-05-08 14:54:12.182 INFO (MainThread) [supervisor.host.services] Updating service information
2024-05-08 14:54:12.195 INFO (MainThread) [supervisor.host.network] Updating local network information
2024-05-08 14:54:12.351 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
2024-05-08 14:54:12.363 INFO (MainThread) [supervisor.host.manager] Host information reload completed
2024-05-08 14:54:57.570 INFO (SyncWorker_6) [supervisor.docker.manager] Stopping addon_a0d7b954_ssh application
2024-05-08 14:55:01.406 INFO (SyncWorker_6) [supervisor.docker.manager] Cleaning addon_a0d7b954_ssh application
2024-05-08 14:55:24.018 INFO (MainThread) [supervisor.backups.manager] Found 150 backup files
2024-05-08 14:55:24.626 INFO (MainThread) [supervisor.backups.manager] Found 150 backup files
2024-05-08 14:55:55.164 INFO (MainThread) [supervisor.backups.manager] Backup 79230e24 starting stage addon_repositories
2024-05-08 14:55:55.164 INFO (MainThread) [supervisor.backups.manager] Backup 79230e24 starting stage docker_config
2024-05-08 14:55:55.165 INFO (MainThread) [supervisor.backups.manager] Creating new full backup with slug 79230e24
2024-05-08 14:55:55.169 INFO (MainThread) [supervisor.backups.manager] Backup 79230e24 starting stage addons
2024-05-08 14:55:55.210 INFO (MainThread) [supervisor.addons.addon] Building backup for add-on core_configurator
2024-05-08 14:55:55.226 INFO (MainThread) [supervisor.addons.addon] Finish backup for addon core_configurator
2024-05-08 14:55:55.256 INFO (MainThread) [supervisor.addons.addon] Building backup for add-on 5c53de3b_esphome
2024-05-08 14:55:55.267 INFO (MainThread) [supervisor.addons.addon] Finish backup for addon 5c53de3b_esphome
2024-05-08 14:55:55.294 INFO (MainThread) [supervisor.addons.addon] Building backup for add-on a0d7b954_ssh
2024-05-08 14:55:55.325 INFO (MainThread) [supervisor.addons.addon] Finish backup for addon a0d7b954_ssh
2024-05-08 14:55:55.357 INFO (MainThread) [supervisor.addons.addon] Building backup for add-on a0d7b954_ftp
2024-05-08 14:55:55.368 INFO (MainThread) [supervisor.addons.addon] Finish backup for addon a0d7b954_ftp
2024-05-08 14:55:55.398 INFO (MainThread) [supervisor.addons.addon] Building backup for add-on core_mosquitto
2024-05-08 14:55:55.414 INFO (MainThread) [supervisor.addons.addon] Finish backup for addon core_mosquitto
2024-05-08 14:55:55.445 INFO (MainThread) [supervisor.addons.addon] Building backup for add-on 09e60fb6_scrypted
2024-05-08 14:55:56.390 INFO (MainThread) [supervisor.addons.addon] Finish backup for addon 09e60fb6_scrypted
2024-05-08 14:55:56.425 INFO (MainThread) [supervisor.addons.addon] Building backup for add-on core_vlc
2024-05-08 14:55:56.442 INFO (MainThread) [supervisor.addons.addon] Finish backup for addon core_vlc
2024-05-08 14:55:56.475 INFO (MainThread) [supervisor.addons.addon] Building backup for add-on core_silabs_multiprotocol
2024-05-08 14:55:56.498 INFO (MainThread) [supervisor.addons.addon] Finish backup for addon core_silabs_multiprotocol
2024-05-08 14:55:56.531 INFO (MainThread) [supervisor.addons.addon] Building backup for add-on core_matter_server
2024-05-08 14:55:57.329 INFO (MainThread) [supervisor.addons.addon] Finish backup for addon core_matter_server
2024-05-08 14:55:57.331 INFO (MainThread) [supervisor.backups.manager] Backup 79230e24 starting stage home_assistant
2024-05-08 14:55:58.574 INFO (MainThread) [supervisor.homeassistant.module] Backing up Home Assistant Core config folder
2024-05-08 14:56:23.590 INFO (MainThread) [supervisor.homeassistant.module] Backup Home Assistant Core config folder done
2024-05-08 14:56:23.614 INFO (MainThread) [supervisor.backups.manager] Backup 79230e24 starting stage folders
2024-05-08 14:56:23.619 INFO (SyncWorker_4) [supervisor.backups.backup] Backing up folder share
2024-05-08 14:56:23.631 INFO (SyncWorker_4) [supervisor.backups.backup] Backup folder share done
2024-05-08 14:56:23.635 INFO (SyncWorker_0) [supervisor.backups.backup] Backing up folder addons/local
2024-05-08 14:56:23.642 INFO (SyncWorker_0) [supervisor.backups.backup] Backup folder addons/local done
2024-05-08 14:56:23.645 INFO (SyncWorker_6) [supervisor.backups.backup] Backing up folder ssl
2024-05-08 14:56:23.665 INFO (SyncWorker_6) [supervisor.backups.backup] Backup folder ssl done
2024-05-08 14:56:23.667 INFO (SyncWorker_3) [supervisor.backups.backup] Backing up folder media
2024-05-08 14:56:38.476 INFO (SyncWorker_3) [supervisor.backups.backup] Backup folder media done
2024-05-08 14:56:38.477 INFO (MainThread) [supervisor.backups.manager] Backup 79230e24 starting stage finishing_file
2024-05-08 14:56:38.484 INFO (MainThread) [supervisor.backups.manager] Creating full backup with slug 79230e24 completed
2024-05-08 14:56:38.592 INFO (MainThread) [supervisor.backups.manager] Found 151 backup files
Good news, the latest Home Assistant Operating System 12.3 update fixed the problem !
