I have been trying to research the issue of Supervisor failing to update (from 2024.4.0) to 2024.4.4. I have looked for hours and can’t find a valid solution. I have tried to update from the web interface for Home Assistant, as well as the “ha supervisor update” from the Home Assistant OS command line. (I am also having issues getting add-ons to installed as well, but probably not related and best for another topic). I would be so appreciative of any help, thanks!
Here is the log:
Logger: homeassistant.components.websocket_api.http.connection
Source: components/websocket_api/commands.py:239
integration: Home Assistant WebSocket API (documentation, issues)
First occurred: 10:29:51 AM (1 occurrences)
Last logged: 10:29:51 AM
[140706457677504] Error updating Home Assistant Supervisor: Update of Supervisor failed: Can't install ghcr.io/home-assistant/amd64-hassio-supervisor:2024.04.4: 500 Server Error for http+docker://localhost/v1.44/images/create?tag=2024.04.4&fromImage=ghcr.io%2Fhome-assistant%2Famd64-hassio-supervisor&platform=linux%2Famd64: Internal Server Error ("Get "https://ghcr.io/v2/": net/http: request canceled while waiting for connection (Client.Timeout exceeded while awaiting headers)")
File "/usr/src/homeassistant/homeassistant/components/hassio/update.py", line 259, in async_install
await async_update_supervisor(self.hass)
File "/usr/src/homeassistant/homeassistant/components/hassio/handler.py", line 59, in _wrapper
data = await funct(*argv, **kwargs)
File "/usr/src/homeassistant/homeassistant/components/hassio/handler.py", line 242, in async_update_supervisor
return await hassio.send_command(command, timeout=None)
File "/usr/src/homeassistant/homeassistant/components/hassio/handler.py", line 593, in send_command
raise HassioAPIError(error.get(ATTR_MESSAGE))
homeassistant.components.hassio.handler.HassioAPIError: Update of Supervisor failed: Can't install ghcr.io/home-assistant/amd64-hassio-supervisor:2024.04.4: 500 Server Error for http+docker://localhost/v1.44/images/create?tag=2024.04.4&fromImage=ghcr.io%2Fhome-assistant%2Famd64-hassio-supervisor&platform=linux%2Famd64: Internal Server Error ("Get "https://ghcr.io/v2/": net/http: request canceled while waiting for connection (Client.Timeout exceeded while awaiting headers)")
File "/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py", line 239, in handle_call_service
response = await hass.services.async_call(
File "/usr/src/homeassistant/homeassistant/core.py", line 2543, in async_call
response_data = await coro
File "/usr/src/homeassistant/homeassistant/core.py", line 2580, in _execute_service
return await target(service_call)
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 971, in entity_service_call
single_response = await _handle_entity_call(
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 1043, in _handle_entity_call
result = await task
File "/usr/src/homeassistant/homeassistant/components/update/__init__.py", line 162, in async_install
await entity.async_install_with_progress(version, backup)
File "/usr/src/homeassistant/homeassistant/components/update/__init__.py", line 466, in async_install_with_progress
await self.async_install(version, backup)
File "/usr/src/homeassistant/homeassistant/components/hassio/update.py", line 261, in async_install
raise HomeAssistantError(
homeassistant.exceptions.HomeAssistantError: Error updating Home Assistant Supervisor: Update of Supervisor failed: Can't install ghcr.io/home-assistant/amd64-hassio-supervisor:2024.04.4: 500 Server Error for http+docker://localhost/v1.44/images/create?tag=2024.04.4&fromImage=ghcr.io%2Fhome-assistant%2Famd64-hassio-supervisor&platform=linux%2Famd64: Internal Server Error ("Get "https://ghcr.io/v2/": net/http: request canceled while waiting for connection (Client.Timeout exceeded while awaiting headers)")
