No idea where to adjust the environment variables as we don’t use a docker run command anywhere or a script as the supervisor is a service. Where is the file to adjust those variables found? Is the best approach just to run the installation script again?
first of all find out if they are there already.
docker inspect hassio_supervisor|grep Env -A10
should catch your env variables.
"SUPERVISOR_SHARE=/usr/share/hassio",
"SUPERVISOR_NAME=hassio_supervisor",
"SUPERVISOR_MACHINE=intel-nuc",
So just the machine name then. I’m thinking I just run the install script again…
no change.
So the script is writing to /etc/hassio.json looks like this:
"supervisor": "homeassistant/amd64-hassio-supervisor",
"machine": "generic-x86-64",
"data": "/usr/share/hassio"
So the reinstall fixed that file.
The script is in /usr/sbin/hassio-supervisor
Maybe I can restart Supervisor? Nope!
Tried downgrading to 2021.8.7 but that’s not making it change the image it’s pulling either.
My file looks the same. I am a bit confused should we be changing the name to
“supervisor”: “hassio-supervisor”
Yes, after apt install libglib2.0-bin
I saw the osagent was installed correct.
If I remember correctly you are using home assistant supervised.
The service is located here:
/etc/systemd/system/hassio-supervisor.service
which is calling following script:
where you will find the docker run command with the environment variables
EDIT: On my supervised installation they were already present
They were on mine as well but the machine type is wrong as I posted even though after reinstalling the json file has the correct machine in there. I did notice there is a new beta supervisor now and I’ll update to that soon. Perhaps it needs that supervisor to fix it.
I see. Well on my installation everything is configured as expected. I did nothing special…just the update
yes but I’m on an intel-nuc install which is now being replaced by generic.
"Env": [
"PATH=/usr/local/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin",
"LANG=C.UTF-8",
"S6_BEHAVIOUR_IF_STAGE2_FAILS=2",
"S6_CMD_WAIT_FOR_SERVICES=1",
"S6_SERVICES_GRACETIME=10000",
"SUPERVISOR_API=http://localhost"
Everything is right but I can’t set a different machine type as I already posted.
the json file hassio.json:
So it’s set for that just not getting into the script even after I reran the installer (Your installation machine hasn’t changed but mine has)
EDIT: Updated to the beta supervisor 2021.08.0 and loaded beta 2021.9.0b0 and it’s pulled generic! Now:
"Env": [
"SUPERVISOR_MACHINE=generic-x86-64",
"LANG=C.UTF-8",
So looks like it needed the new supervisor to ‘take’ the machine change
I had a missing dependency; I needed to install the udisks2
package before the .deb
file.
Me too. And after
libglib2.0-bin
I have opened an issue for that already. I had it missing too. Thanks to this thread I was able to solve it.
Btw what is the outcome of this? Future use? Or I can see something already now?
Well, I upgraded first to bullseye, and then installed osagent. So it is not standard on Debian 11 too.
Do you have a hint for a simple way to update to bullseye?
In a console :
su
sed -i 's/buster/bullseye/' /etc/apt/sources.list
sed -i 's/buster/bullseye/' /etc/apt/sources.list.d/*.list
sed -i 's|bullseye/updates|bullseye-security|' /etc/apt/sources.list
sed -i 's/bullseye/buster/' /etc/apt/sources.list.d/*mosquitto*.list
apt update
apt upgrade
apt full-upgrade
apt autopurge
That seems far too simple when you look at the official docs. Chapter 4. Upgrades from Debian 10 (buster)
Thanks.
I have followed this and upgraded to Bullseye without issues.
I think the official docs were even simpler actually… one line to replace buster with bullseye in all source lists and then the standard update and Disto-upgrade
Its all the warnings and seeming gotchas that worry me.
Still I am on the final leg of @francisp 's instructions and will hold my breath and reboot shortly.
