Supervisor upgrade problem
Hi Alot of times when I try to upgrade supervisor in my enviroment it fails. This is a example of the log.
20-05-06 12:15:21 INFO (MainThread) [supervisor.updater] Fetch update data from https://version.home-assistant.io/stable.json
20-05-06 12:36:08 INFO (MainThread) [supervisor.homeassistant] Update Home Assistant to version 0.109.4
20-05-06 12:36:08 INFO (SyncWorker_3) [supervisor.docker.interface] Update image homeassistant/qemux86-64-homeassistant:0.108.9 to homeassistant/qemux86-64-homeassistant:0.109.4
20-05-06 12:36:08 INFO (SyncWorker_3) [supervisor.docker.interface] Pull image homeassistant/qemux86-64-homeassistant tag 0.109.4.
20-05-06 12:49:19 ERROR (SyncWorker_3) [supervisor.docker.interface] Can’t install homeassistant/qemux86-64-homeassistant:0.109.4 -> 404 Client Error: Not Found (“no such image: homeassistant/qemux86-64-homeassistant:0.109.4: No such image: homeassistant/qemux86-64-homeassistant:0.109.4”).
20-05-06 12:49:19 WARNING (MainThread) [supervisor.homeassistant] Update Home Assistant image fails
Anyone got some idea what can cause this and how to solve it?
thx
HĂĄkan
Cause : insufficient disk space
Solution : make more disk space available
Hi, I was getting the same issue. Wasn’t disk space for me…this was something to do with the systemd-resolved.service not started in my Ubuntu instance. I fixed that and rebooted it, and then was able to upgrade.
Don’t think it is a disk problem. System is running on a VM with 128Gig disk :=)… Some times its works if I Stop all addons make them not start if reboot it could work but this time it dose not.
Then you can login to the host (the host, not the ha container) and run
docker pull homeassistant/qemux86-64-homeassistant:0.109.4
Show what messages are displayed on the console.
you meen logon to HassOS and then run docker pull?
yes, that is the easiest way to troubleshoot the problem
I figured it out :). When running the docker command it seems as it actually had downloaded a part of the new image already. This could be some timeout issues if you have like me a slow ADSL.
The easiest way to fix : limit max concurrent downloads to 1
On raspbian I used this, don’t know where it is on HassOS
nano /etc/docker/daemon.json
“max-concurrent-downloads”: 1
Thx for help. My bad here I usually create all vhdx files but in this case I downloaded so when taking a look at disk size it was only 7gig. Hasos handel the expansion of the disk glorious :). Thx again
