I’ve had my Home Assistant install running for several months now (using the hassio image on a Raspberry Pi 4). I tried to update the Supervisor but it says “Error: Unknown Error, see logs”. The Supervisor logs show the following error:
21-01-05 20:31:52 INFO (SyncWorker_8) [supervisor.docker.interface] Pull image homeassistant/armv7-hassio-supervisor tag None.
21-01-05 20:31:52 ERROR (SyncWorker_8) [supervisor.docker.interface] Can't install homeassistant/armv7-hassio-supervisor:None -> 404 Client Error: Not Found ("manifest for homeassistant/armv7-hassio-supervisor:None not found: manifest unknown: manifest unknown").
21-01-05 20:31:52 ERROR (MainThread) [supervisor.supervisor] Update of Supervisor fails!
21-01-05 20:31:52 ERROR (MainThread) [asyncio] Task exception was never retrieved
future: <Task finished coro=<Tasks._update_supervisor() done, defined at /usr/src/supervisor/supervisor/misc/tasks.py:155> exception=SupervisorUpdateError()>
The key seems to be that it’s not getting the image tag from the manifest, but I’m not sure where that is nor how to fix it. There’s also a warning earlier on in the log that might be related
21-01-05 20:16:53 WARNING (MainThread) [supervisor.store.data] Can't read /data/addons/core/configurator/config.json: does not match regular expression @ data['map'][2]. Got 'media:rw'
21-01-05 20:16:53 WARNING (MainThread) [supervisor.store.data] Can't read /data/addons/core/ssh/config.json: does not match regular expression @ data['map'][5]. Got 'media:rw'
21-01-05 20:16:53 WARNING (MainThread) [supervisor.store.data] Can't read /data/addons/core/samba/config.json: does not match regular expression @ data['map'][5]. Got 'media:rw'
21-01-05 20:16:53 WARNING (MainThread) [supervisor.store.data] Can't read /data/addons/core/check_config/config.json: does not match regular expression @ data['map'][2]. Got 'media:rw'
21-01-05 20:16:53 WARNING (MainThread) [supervisor.store.data] Can't read /data/addons/git/a0d7b954/ftp/config.json: does not match regular expression @ data['map'][3]. Got 'media:rw'
21-01-05 20:16:53 WARNING (MainThread) [supervisor.store.data] Can't read /data/addons/git/a0d7b954/motioneye/config.json: does not match regular expression @ data['map'][0]. Got 'media:rw'
21-01-05 20:16:53 WARNING (MainThread) [supervisor.store.data] Can't read /data/addons/git/a0d7b954/ssh/config.json: does not match regular expression @ data['map'][3]. Got 'media:rw'
21-01-05 20:16:53 WARNING (MainThread) [supervisor.store.data] Can't read /data/addons/git/a0d7b954/node-red/config.json: does not match regular expression @ data['map'][1]. Got 'media:rw'
21-01-05 20:16:53 WARNING (MainThread) [supervisor.store.data] Can't read /data/addons/git/a0d7b954/vscode/config.json: does not match regular expression @ data['map'][3]. Got 'media:rw'
21-01-05 20:16:53 WARNING (MainThread) [supervisor.store.data] Can't read /data/addons/git/a0d7b954/plex/config.json: does not match regular expression @ data['map'][0]. Got 'media:rw'
Anybody know what might be going on?
