Support covers with `tilt_position` in HomeKit integration
HomeKit doesn’t support setting the tilt orientation, only the ‘normal’ orientation.
Would be great if HomeKit would also support;SUPPORT_OPEN_TILT, SUPPORT_STOP_TILT, SUPPORT_CLOSE_TILT, SUPPORT_SET_TILT_POSITION to set orientation of blinds.
HomeAssistant situation
Original issue on GitHub with more background information; https://github.com/home-assistant/core/issues/36984
If you are looking for this feature in the HomeKit-Controller integration, you can vote for it here.
