Please support firmware updates via the WiZ integration so that it is no longer necessary to utilize the WiZ app and, if possible, avoid automatic firmware updates unless enabled in Home Assistant.
There are quite a few obstacles for this to happen.
First the update function might not be available through the local access interface.
Secondly the firmwares might not be possible to even download from outside the Wiz app.
Thirdly the firmwares are often copyright protected, so it is not possible to host them outside the Wiz app, even if was possible to download them.
Fourthly the Wiz is an umbrella app for several brands and the updates might be different from brand to brand, even though the device hardwarewise is the same.
Fifthly who is responsible if the HA integration download the wrong firmware and brick the device.
