So, I connected my new Blink Wired Floodlight up to Home Assistant only to discover that there is no floodlight on/off control exposed. I was hoping to be able to setup a physical smart switch to be able to control the on/off state of the floodlight for “normal” people. This also means that currently I’ll have to make sure the Blink phone app is installed on my wife’s phone for now until I can find some other solution.
Did you find a solution to this? I have the same issue.
No I still don’t have a solution. I haven’t had time to dig into the Blink add-on or APIs to see if there is a way to add this support. I’m finding that to a degree the Blink support in HA is rather sub-par as compared to like a Google Nest product. Not being able to view a live stream of the camera in HA and the image grab being only the latest photo that was manually taken in the Blink app proves to be sort of useless from an HA standpoint.
I’m sort of regretting my purchase at this point.
Alexa can turn the floodlight on and off. I was able to use an event from my Kwik door deadbolt through Home Assistant to Amazon to trigger the light to turn on. Not ideal but opening the deadbolt manually to leave the house in the morning turns the light on. I guess I could just tell Alexa to turn the light on but I don’t want to have to think about it. I just wish there was a control to keep the light off during the daytime, but sadly, there are no other features in Alexa.
Interesting, idea to use Alexa as a way to control it via HA. I’m sort of regretting my decision to go with Blink tbh, though I was hard pressed to find a device with similar hardwired features at the price I paid for it. I’ll probably keep my eye out for a device with similar specs that has better offline and direct integration with HA an look to spend the extra money on it some time in the future.
It’s been almost a year and I don’t see any other way to request this feature. I guess I can start digging into the code to find a way to add this support. I find it hard to believe that there isn’t enough need for this support.
I’ve been looking for a way to do this as well. Any luck?
No luck for me either as of yet. I haven’t tried digging into hardware snooping or the integration code to see what can be done. Was hoping someone else might feel the itch to do that. LOL.
I am disappointed that this thread ended here. I just purchased this wired floodlight myself seeing that there was an integration for Blink. But as I found out, it does not support turning the light on and off, which you would think is the most basic function other than seeing the camera. I have not really even go the camera to work with home assistant as it does not look like a live view I am not exactly sure why. Also regretting purchasing this floodlight as it looks like the support for HA is very limited. Well, live and learn Everyone in my family will just have to get the Blink app if they want to turn the ligth on and off ad-hoc.
Yeah, it stinks because the camera/floodlight doesn’t require a cloud subscription to store video as you can use a second local storage device. However there are still a lot of features that just don’t work well or at all with HA. ![]()
Hi everyone. I have a pull request open with the BlinkPy maintainer to add on/off functionality for the wired flood light. Once there, the Blink integration would still need to be modified. I am not sure if or when this could be available in HA.
In the meantime, I have a temporary workaround installed in my HA Core running in docker. I am not sure how custom components work in the supervisor version.
Gist below contains three files that will get the retrieve Blink integration and creates a standalone switch for each flood light it finds. It calls the on/off of the flood light with just enough code to get to the rest api endpoint through your authenticated Blink integration.
I have it running against this wired flood light. If you have the same this should work: Amazon.com: Blink Wired Floodlight Camera - Smart security camera, 2600 lumens, HD live view, enhanced motion detection, built-in siren, Works with Alexa – 1 camera (Black) : Health & Household
Installation:
- The installation is straight forward. Create a folder in your
/config/custom_components/calledblink_floodlight - Download the files in the gist below and drop them in that folder. You should have three files,
switch.py, manifest.json, and __init__.py - Add
blink_floodlight:to yourconfiguration.yaml - Restart
You can additionally add a logger if needed for troubleshooting
logger:
logs:
custom_components.blink_floodlight: debug
The flood lights should appear as switches with name switch.<name>_floodlight under the Blink Floodlight Control on the entities tab.
Caveats:
- This is a workaround until things get sorted out properly.
- I am not sure the on / off state will always be accurate.
- If you have another version of the camera flood light, it may not work.
- If your camera network is busy, ie recording or live viewing, you cannot toggle the lights on / off, even if you are viewing the camera with the flood light. The Blink app can do this but it is not evident how.
FIles:
I suggest avoiding Blink at all cost especially their floodlights. I’m on a trek to hopefully find a working alternative.
