Tryck på det gula plusset och lägg till chargeamps…
Tack Fredrik och ursäkta.
Jag gjorde fel och hittade inte i add-ons chargeamps, men efter din förklaring gick bra.
Stor Tack.
//Christian
Added to the default HACS repo in July
https://github.com/hacs/default/commit/b16dcbe436bbbbd888f1db93cbe2f983d4ff30b7
Hi, thank you for good work!
Can you please help me understand what kind of configuration is possible to limit the currents?
Can I:
- Select which (or both) outlets to power?
- Select (per outlet?) if I want to charge using 3-phase or 1-phase (and which phase)
- Select (per outlet?) the max allowed current
Thank you
/Peter
Yes
No, ChargeAmp’s Api does not allow this.
Yes
Each outlet can be configured to act as a switch (or even a lamp where the dimming level is proportion of current).
Perhaps we should start a campaign for ChargeAmps to open up their api for this. @jschlyter, @chris4, @Wolfie2016, @crusell, @mats.nethander, @marten.fallman, @Jockz0rz
Unfortunately I have not had the time to look into it. But I support that we write to Chargeamp to open up their API locally without having to access their server.
Has anyone looked at the traffic flowing between wallbox and charge amps servers?
If I’m to guess, it’s a simple loop on the wallbox wifi chip that once every 30s connects to the server and get it’s latest config. Since it’s a esp8266 chip it might even be non-ssl but I doubt it.
Thanks for att great integration with Charge Amps, I’ve a HALO Wallbox for my Volvo Plug-In Hybrid.
I’m relatively new to Home Assistant but I’ve installed the integration via HACS, got my API-key from Charge Amps support and configured configuration.yaml with my username, password and API-key.
But the integration doesn’t start since I recieve the following error:
File "/usr/src/homeassistant/homeassistant/setup.py", line 213, in _async_setup_component
result = await task
File "/config/custom_components/chargeamps/__init__.py", line 111, in async_setup
for cp in await client.get_chargepoints():
File "/usr/local/lib/python3.8/site-packages/chargeamps/external.py", line 81, in get_chargepoints
response = await self._get(request_uri)
File "/usr/local/lib/python3.8/site-packages/chargeamps/external.py", line 65, in _get
await self._ensure_token()
File "/usr/local/lib/python3.8/site-packages/chargeamps/external.py", line 46, in _ensure_token
response = await self._session.post(
File "/usr/local/lib/python3.8/site-packages/aiohttp/client.py", line 625, in _request
resp.raise_for_status()
File "/usr/local/lib/python3.8/site-packages/aiohttp/client_reqrep.py", line 1000, in raise_for_status
raise ClientResponseError(
aiohttp.client_exceptions.ClientResponseError: 401, message='Unauthorized', url=URL('https://ca-externalapi.azurewebsites.net/api/v3/auth/login')
Seems like there some problem with authentication but I’ve double-checked my username and password and I can login using them to https://my.charge.space/
I cannot verify my API-key but I’ve copied once again from the mail I received from Charge Amps.
Or do I have to do anything else to make it work?
So do I ![]()
Do you have any magical characters in the password (could be an issue with how yaml interprets your password).
Kul att du även har liknande uppsättning som jag har
Självklart har jag specialtecken men även fast jag nu bytt lösenord till att bara innehålla bokstäver och siffror så får jag samma fel. Jag var rätt säker på att ditt tips skulle hjälpa!
Edit. Har även mejlat Charge Amps så de får verifiera att API-nyckeln jag fått är korrekt gentemot mitt konto.
Då vet jag tyvärr inte.
Kanske dra igång logger debug, https://www.home-assistant.io/integrations/logger
logger:
default: debug
Men är osäker på hur @jschlyter har implementerat logging.
Som en extra grej, denna automatiseringen har jag från VOC (med notifikation när man laddar/slutar ladda)
- id: '1576334464454'
alias: CAR Charging
description: ''
- entity_id: binary_sensor.car_battery_charging
for: 00:00:05
platform: state
to: 'on'
platform: state
to: 'off'
condition: []
- data_template:
message: "{% if is_state('binary_sensor.car_battery_charging', 'on') %}\n\
\ CAR is currently charging, will finish at\n {{- (now() | as_timestamp()\
\ + (states('sensor.car_time_to_fully_charged')|int * 60)) | timestamp_custom(\"\
\ %H:%M\", True) }}\n {{- (-3600 + (states('sensor.car_time_to_fully_charged')|int*60))\
\ | timestamp_custom(\" (%-H h %-M min).\", True) }}\n{%- else %}\n CAR\
\ finished charging, battery at {{states('sensor.car_battery_level')}}%\
\ ({{ states('sensor.car_battery_range')}} km). \n{%- endif %}"
title: Car charging time
service: notify.pushover
Edit: här är ett blueprint https://gist.github.com/fredrike/ac758adad1360b74180194a0428a34dd
Man kan aktivera mer loggning för enbart integrationen via:
logger:
logs:
custom_components.chargeamps: debug
, tänkte att man kanske vill se output från aiohttp också.
Tack @fredrike och @jschlyter för era svar. Inväntar först svar från Charge Amps om min API-nyckel och sen testar jag loggningen.
Som jag anade visade sig felet ligga utanför vår kontroll. Charge Amps ändrade datumet när API-nyckeln blev aktiv så nu fungerar det
@fredrike, har du nån guide eller liknande på hur man kan presentera/visa de olika entiteterna på nåt snyggt och informativt sätt via korten på översiktssidan? Behöver lite inspiration och förslag då jag knappt vet vad alla entiteter egentligen är för nåt
Här är min dashboard:
ChargeAmps-dashboard
cards:
- content: >
{% if states("sensor.chargeamps_watt") |float > 0.0 %} The car is
currently charging via **{{ state_attr("sensor.chargeamps_watt",
"active_phase") }}** @ {{state_attr("switch.chargeamps", "max_current") |
int }} Amp ({{ states("sensor.chargeamps_watt")|round(-2)|int }}W){% else
%} The car is not charging. ChargeAmps is configured to charge from **{{
state_attr("sensor.chargeamps_watt", "active_phase") or "-" }}** @
{{state_attr("switch.chargeamps", "max_current") | int }} Amp. {% endif
type: markdown
- entities:
- entity: sensor.chargeamps
icon: 'mdi:flash'
- entity: sensor.chargeamps_watt
- entity: binary_sensor.charge_amps_plugged
- entity: binary_sensor.charge_amps_charging
type: glance
- type: grid
columns: 2
cards:
- entity: light.chargeamps_current
icon: 'mdi:car-electric'
type: light
- entity: switch.mjovik_1706001294_2
hold_action:
action: more-info
show_icon: true
show_name: true
tap_action:
action: toggle
type: button
- cards:
- entity: light.chargeamps_downlight
type: light
- entity: light.chargeamps_dimmer
type: light
type: horizontal-stack
type: vertical-stack
Jag har dock skapat endel av sensorerna/switcharna med detta
charge_amps.yaml
sensors:
chargeamps_phase:
unique_id: chargeamps_phase
friendly_name: "Charge Amps Phase"
value_template: "{{ state_attr('sensor.chargeamps', 'installationPhase') }}"
binary_sensor:
sensors:
charge_amps_plugged:
unique_id: charge_amps_plugged
friendly_name: "Charge Amps plug"
device_class: plug
value_template: "{{ is_state_attr('sensor.chargeamps', 'Connector 0 state',
'B2Connected') or is_state_attr('sensor.chargeamps', 'Connector 0 state', 'C2ConnectedCharging') }}"
charge_amps_charging:
unique_id: charge_amps_charging
friendly_name: "Charge Amps charge"
device_class: battery_charging
icon_template: mdi:car
value_template: "{{ is_state_attr('sensor.chargeamps', 'Connector 0 state', 'C2ConnectedCharging') }}"
switch:
switches:
chargeamps_socket:
unique_id: chargeamps_socket
friendly_name: "Charge Amp's Socket"
value_template: "{{ is_state_attr('sensor.chargeamps', 'Connector 1', 'On') }}"
turn_off:
service: chargeamps.change_settings
entity_id: none.none
setting: '{"connectors": [{},{"mode": "Off"}]}'
turn_on:
setting: '{"connectors": [{},{"mode": "On"}]}'
light:
lights:
chargeamps_current:
unique_id: chargeamps_current
friendly_name: "Charge Amp's Charger"
value_template: "{{ is_state('switch.chargeamps', 'on') }}"
level_template: "{{ ((state_attr('switch.chargeamps', 'max_current') | int) - 10) * 41.5 |int }}"
turn_off:
service: chargeamps.disable
chargepoint: 1706001294
connector: 1
turn_on:
service: chargeamps.enable
connector: 1
set_level:
service: chargeamps.set_max_current
data_template:
connector: 1
max_current: "{{ (brightness / 41.5 | round(0) + 10) | int | string }}"
Nice!
I am just starting to configure this in my Homeassistnant now. I have also installed a load balancer from Charge Amps, and that provides sensor data of current load on each if my phases at home to the cloud, do you know if that data is also available via the API to fetch? Does not look to be documented in the integration so far at least.
Looks like this in my.charge.space when the load balancer is also available.
It should be possible to read the raw stream from the web if it’s not exposed trough API (I did something like that on my version on the plugin https://gist.github.com/fredrike/c9e99a3ae59a39d8df9c811456b8012f perhaps something like that could be implemented here too).
It would be really interesting to see the network communication from the load-balancer to the charger (the charger should have a local api but we have not cracked it yet).
