@Borgy - yes, that update fixed it for me. I no longer get the prompt about a newly discovered integration and the duplicate (new) integration disappeared too.
I have just installed the Daikin integration on both a pi based H/A and also a H/A set up on my Synology NAS using the Hassio app. On the pi version I do not get an outside temperature sensor but on the NAS based one I do. Both versions have the same entries in the config yaml files. Any thoughts on why there would be a difference in the number of sensors?
Hi guys, just wanted to let you know i setup a new AIrbase controller on an older Daikin in Australia yesterday and all went well. It appears that i can not update the doco on Github - but it would be worthwhile to note that the BRP15B61 does not require a password or API key when registering it - simply the IP address.
I am fairly new to HA - is there somewhere to point me to where i can get started on modifying this integration ? For instance - my unit does not have integrated Zone controls - but rather a seperate bank of 240V switches that manage individual dampers - i intend to move these across to using a Sonoff 4 channel controller with ESPhome - and would like to put the switches into the same climate panel as the Daikin. Likewise i have integrated XIaomi Temp and Humidity sensors around the house and manage them through ESPHome - and i would like to feed their info back into an integrated single display
BRP072Cxx based units (including Zena devices) need to provide the API-key found on a sticker under the front cover during setup.
So no need to worry.
What do you mean by a single display? The simple thermostat support extra sensors. Otherwise I suggest that you look at Vertical stack card - Home Assistant and do something creative like the example at the bottom.
OK - thanks - what i meant was within the one card (thermostat) to have 4 zone control buttons (as well as for instance being able to change the fan speed by having two icons for low and high
I will check out the thread you have given me thanks
I have a Daiking ducted which is connected via the BRP15A61 I believe. It is connected and I can control the unit Hassio but does not appear to be getting updates in terms of the indoor and outdoor temperature as the last readings are from 2 days ago. Does the unit need to be running to return readings?
Yes, the Airbase device is a real pice of crap. I’ve tried my best to keep the number of requests at a minimum and do retries when it fails but still we get these errors.
