Just fitted sone day night blinds, that need 3 positions, would it be possible to add a 3rd position for a blind.
Thanks for that, when you say use the Aqara E1 (Which I have) Do you mean connect the roller motor through that hub?
I have setup both.
4x connected through the Aquara hub and 5x connected via ZHA with conbee II stick.
The screenshot is the one connected to ZHA
I have night/day blinds with motor that has build in rotary encoder and can store few positions internally. Se every impulse to move blinds up or down just moves them to next programmed position. I use simple ethernet relay module to simulate button presses and input_number to store the position inside HA. Works perfectly and easy to automate. Perhaps something similar is possible in your case?
You can create an automation and link some dashboard button push commands for each button
