Some time ago I started searching for new light switches in my house. I first tried using a Zigbee module behind my current switches, but they almost don’t fit and it made loud noises when switching on and off.
I really like them and they use Zigbee Touchlink, but I don’t know if they are supported by Home Assistant using ZHA. I contacted them, but haven’t got a response back yet.
In a few week I’m switching to the Home Assistant Yellow that’s using the integrated Silicon Labs MGM210P Mighty Gecko Module.
The problem I might be facing is the support of Z2M for the Silicon Labs chipset that is used on the Home Assistant Yellow. The support is still in experimental state. Supported Adapters | Zigbee2MQTT
Is it easy to somehow add this light switch to ZHA? Or is the support for the MGM210P good enough on Z2M?
