It would be very useful if HomeAssistant could “talk” to EEBUS capable devices (e.g. Vaillant Heat Pump, SMA Inverter etc.) via SPINE/SHIP protocols. There are community integrations for integrating Vaillant Multimatic (GitHub - thomasgermain/vaillant-component: Multimatic integration for Home Assistant (NOT compatible with sensoAPP)), but communication via EEBUS would be far more efficiant, less error-prone, and independant from the cloud. More information regarding EEBUS: https://www.eebus.org/
Somehow it seems like EEBUS ist not really taking off.
There appears to be recent work towards getting talking to EEBUS via SHIP GitHub - enbility/eebus-go: EEBUS protocol implementation in go would be nice to bring this to home assistant
Loxone also recently integrated Vaillant heat pumps via EEBUS SHIP.
That would indeed be very welcome… hopefully someone picks it up here…
Have there been any new developments concerning EEBUS and Home Assistant?
Hi is there an update about eebus and home assistant?
I want to connect my vaillant arotherm plus over eebus with my home assistant to use Solar power at daytime or a range where the heat pumps still active and do not cycle.
I have a new thermostat with the Migo Link app, which uses eebus for easy connection to devices.
Is there anything planned to connect to Home Assistant?
I’m very much looking to use this as well. My Huawei solar inverter and Vaillant ground source heat pump are connected via EEBUS to my Loxone system. I then use the pyLoxone HACS module to individually map json sensors etc via UUID tags in Loxone. Then they are EEBUS into Loxone and readable into HA. This is more reliable than using the wfii connectivity to my inverter and via Vaillant’s web API which has limitations.
Basically using Loxone as an EEBUS hub.
The problem is, there is no EEBUS implementation in Python. The best bet is probably to code up a gRPC-or-whatever server that uses the eebus-go library, then write a module to call that from Python.
Doing that is a nontrivial exercise which needs somebody who’s reasonably proficient in Go as well as Python. I’d be willing to co-finance the effort if necessary.
I guess there is one …
Umm … no README, no updates for the last five months, huge code blocks that are badly-formatted placeholders at best, and almost no tests? That doesn’t look particularly useful to me.
