Eheim has a new line of wifi-connected products:
I would like to have integration especially for filters;
Thank you
Thank you
First step, do they have an available API for these devices?
It has no public API as far as I know. I just bought a ledcontrol+ with a light and was debuging a bit. It’s used with a browser over HTTP with javascript. So the information I’ve collected:
it opens a websocket to the device: ws://10.0.0.2/ws (of course the real ip of the device)
on turning on the light it sends this message to the device:
{"title":"CCV-SW","to":"12:34:56:78:90:AB","currentValues":[100,100,100],"from":"USER"}
the message contains the mac address of the device it needs to be sent, probably because of the mesh network support for other eheim devices. I have only one light connected to the ledcontrol+ so I don’t know how it works with more independent lights.
to turn off the light it needs the same message but the values needs to be 0,0,0
the page keeps the websocket open, but it works if I open the socket, send my turn on/off message and close the socket
there are lot’s of other messages which tries to get other eheim devices, but I have only this one yet so I don’t know how other messages are working.
Most likely all the eheim digital devices are working the same way, only the messages and answers for the messages are changing. It would be cool if Eheim would provide a documentation of this… Sad, but I’m not good enough and have no other devices to write an integration for those devices. For a start I hope it helps.
Using python3-websocket I can turn on and off my lighting (and dimming it aswell) in manual mode.
It seems like as a starter you could use some kind of commandline switch.
Thank you, this just helped me to make an Eheim autofeeder+ run a manual feeding turn by external command. It runs similar like your websocket example:
{“title”:“SET_MANUAL_FEED”,“to”:“12:34:56:78:90:AB”,“from”:“USER”}
@woockie I am currently trying to make an integration out of this, feel free to contact me if you want to help. I am very interested in getting this to work with HA!
Run eheim_digital.py script somewhere. More information about that later…
is it possible to run this script directly on HA when running as a operating system?
First of all sorry for the late answer! Sure, I’ll be able to help you in testing at least, but only from about this october. Until then my days are crazy
check again on the repo, we make good progress with the integration which is installable via hacs
just get in touch via the repo whenever you are ready
Any update on this? I have an autofeeder+ and really would like to get this integrated!
If there’s anything I can do, let me know! (I’m not a coder, so I’m afraid I can’t help coding )
I too have autofeeder+ but seen on github that this is not supported in your code, are there any plans to support the autofeeder?
Dear Community,
We are excited to finally release the long-awaited API documentation! We truly appreciate your patience and support.
You can now find the full documentation here: ** api.eheimdigital.com **. This includes:
Comprehensive endpoints overview
Usage examples
Authentication details
The API is available starting from software versions S2036 and S1024 from (release: 17.12.2024).
Please note that the following devices currently have an issue when acting as a master – they are unable to process POST requests. This will be fixed in the next release:
We hope this makes working with the API easier and more efficient for everyone. If you have any feedback, suggestions, or spot any issues, feel free to write a comment!
Happy coding!
Your Eheim Dev Team
This is great! looking forward to see support for EHEIM autofeeder+
