Could you please add support for the new Freebox Ultra (v9) in Freebox integration ?
It works, you need to remove first the previous /config/.storage/freebox configuration then run the integration and follow the instruction on the freebox ultra.
Hello, I have just migrated from a Delta and I had to authorize port 8443 on the freebox port configuration to be able to validate the first screen. I noticed that Freebox Ultra was not using the 8443 by default internally and when I checked the HA log, I could see that the Freebox integration was trying to reach the 8443. This may be due to my old delta setup.
Thank you, it worked !
Thanks, I can confirm that it worked with cleaning of config/.storage/freebox folder, restart and then configure the remote access on freebox Ultra on port 8443. Thanks for your contribution!
HA see my Freebox Ultra, but unsuccessful to config.
the https port is : 44392 not 8443.
Team,
can be configure the integration just by enable the traffic on local address listening on 9162 without open on internet welcome page?
This works for me too ! Thanks ![]()
