If you want instant events of remotes Hue bridge isn’t optimal to use.
See the “4h” in the screenshot? Click in that link and there should be “New Topic” below the “selected” link.
I found the custom component written by @robmarkcole really helpful. Exposing the hue switches as sensors means I can at write automations to make them do what I want.
@robmarkcole: Is there any chance you may consider releasing this into an official Hassio add-on?
@robmarkcole: Thank you for the link. I really appreciate this.
My start in “home automation” was grabbing a few hue globes and switches. I have 3 Hue Motion sensors and half a dozen dimmer switches I am using with your custom app now. Figured there was no point wasting them.
Thanks for your work. I’ll check the other thread.
@robmarkcole: Thanks for the excellent work on the Hue switches.
Folks I have a quick question (I hope).
I have a functioning environment with some hue lights and multiple bridges with some basic automations with switches around the house. Automations using the motion sensors work a treat.
I would love to enable a hue switch to toggle a few things around the house too.
I am running the stock HA hue integration under 0.95.4 with no problems so far (on linux docker).
Per https://github.com/robmarkcole/Hue-sensors-HASS
i’ve added the custom_components/huesensor folder.
have followed https://github.com/home-assistant/home-assistant/pull/9796
in configuration.yaml
(do I need to enable the hue platform?)
HA is now throwing two new errors
Error while setting up platform hue
File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 122, in _async_setup_platform
task = async_create_setup_task()
File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 87, in async_create_setup_task
None, platform.setup_platform, hass, platform_config,
AttributeError: module 'homeassistant.components.hue.sensor' has no attribute 'setup_platform'
Connection lost. Reconnecting…
Exception occurred:
File "/usr/local/lib/python3.7/site-packages/zeroconf.py", line 2245, in send
bytes_sent = s.sendto(packet, 0, (addr, port))
PermissionError: [Errno 1] Operation not permitted
AND unable to see any dimmers within my entities.
Where the heck do I start to resolve this?
or have I missed something fundamental?
Any help greatly appreciated.
