As my network is compatible with IPv6, my HA server has a few IPv6 addresses assigned.
During startup, HA makes a check to resolve all of those IP’s.
2022-01-05 22:20:14 WARNING (MainThread) [homeassistant.components.ssdp] Failed to setup listener for fe80::6a96:2e14:4ed4:c46a: [Errno -2] Name does not resolve
2022-01-05 22:20:14 WARNING (MainThread) [homeassistant.components.ssdp] Failed to setup listener for fda8:1129:473c:0:8308:acf:9415:9c6: [Errno -2] Name does not resolve
2022-01-05 22:20:14 WARNING (MainThread) [homeassistant.components.ssdp] Failed to setup listener for fda8:1129:473c:10:eb75:14be:2e94:4fb: [Errno -2] Name does not resolve
2022-01-05 22:20:14 WARNING (MainThread) [homeassistant.components.ssdp] Failed to setup listener for fe80::60e2:2d3d:142c:a92e: [Errno -2] Name does not resolve
In order to properly resolve those, I want to add my DNS servers into the HA DNS config.
However when I attempt to specify the IPv6 address of my DNS, I get the following error:
$ ha dns options --servers dns://fda8:1129:473c:10:211:32ff:fe3a:4dba
Error: Only IPv4 is working for DNS: dns://fda8:1129:473c:10:211:32ff:fe3a:4dba @ data['servers'][0]. Got 'dns://fda8:1129:473c:10:211:32ff:fe3a:4dba'
When can we expect IPv6 to be enabled ?
