Support for LEDs on meeting room tablets?
Reguarding temperature and humidity, I didn’t look into it very much since the tablet is hung just beside the thermostat, but if I’ll find the time I might try to implement them as well. If you want to give it a try, send me a pm, I can give you the little documentation I have
I have a SMT101 from here and your update works for me.
Thank you for making this app.
“Thank you very much, everything worked on my 15.6-inch. I’m just curious, is it possible to switch to addressable LEDs and control them with your integration?”
I tested your app in a Smart Home Panel brand ELC model SMT156 and it worked! link to the manufacturer https://www.elclcd.com/products/15-6-smart-home-panel-smt156
Does the integration allow for effects like breathing, fading etc?
Would like to create a breathing effect when the car is charging and a solid green when it’s finished
Hi! I didn’t try to send many requests very fast, but from latest version brightness control is available. You may try to use it to create the breathe/fade effect, but I have no idea how it could behave
I was previously using your app on an SMT101 like tablet from AliExpress and it worked great. I recently upgraded to the newer 15.1 model that uses the newer rk3576s chip and android 14 instead of android 13.
I’ve installed the app but can’t seem to get it working. Other than the chip and android version the rest of the tablet is same. The built in led app looks identical on the new and the old table.
So I can confirm the newer tablets don’t work with the app. Any idea what the issue might be?
Hi, I have newer rk3576_u (Electron) android 14 model (dont have MQTT in-built) . PWM rgb app & appdata provided by manufacture ). WallPanelControl app is working but I am unable to run through the HA WallPanelControl integration. Anyone has any idea in this regard.Thank you.
