Support for M5Stack AtomU same as Atom Lite
Would it be possible on the Bluetooth Proxy Installers web page, to treat the M5Stack AtomU device the same as Atom Lite? I tried plugging in AtomU, and it tries to install as “Generic ESP32”. But the AtomU is identical to the Atom Lite for pin usage, board name, etc. (Well, AtomU has additional facilities, but that shouldn’t matter.)
That could be really slick way to get a Bluetooth Proxy online: flash an AtomU with Bluetooth Proxy code, plug the AtomU into a USB phone charger, and plug that into a wall outlet. No wires, no nothing --just flash, plug, plug, and you’ve got Bluetooth capabilities.
You can always just flash it with esphome. The configs are here bluetooth-proxies/m5stack-atom-lite.yaml at 8fbe822274d69b8e14f07e0eb45d508790a3333a · esphome/bluetooth-proxies · GitHub
Yep, I have indeed flashed my own into ESPHome. But also still think it would be slickest for the general user if it just flashed Atom Lite code when presented with an M5Stack AtomU device.
That would be totally the quickest way to get a BT Proxy up & running:
  • Plug AtomU device into computer USB port (USB-A)
  • Point browser to BT Proxy Installer web page, & follow the prompts.
  • Unplug the AtomU from the computer, & plug it into a USB wall wart, then plug that into the wall outlet.
I don’t think there will be any difference between the binaries. See platform-espressif32/esp32dev.json at 03254d41cb8e63e9b37d7c796ad55f2c00869ea5 · platformio/platform-espressif32 · GitHub cf
platform-espressif32/m5stack-atom.json at 03254d41cb8e63e9b37d7c796ad55f2c00869ea5 · platformio/platform-espressif32 · GitHub
True. I flashed the Atom Lite code into an AtomU. I just think it would be good if the BT Proxy Installer web page would do that, instead of flashing “Generic ESP” into the AtomU. But yeah, only difference I noticed is that Atom Lite YAML enables the on-board button, whereas Generic ESP YAML does not.
Maybe I am missing something, but I don’t think there is any difference. Both configure a button.
Oh you’re right. I thought I remembered the Atom one as enabling the on-board physical pushbutton (i.e., a binary_sensor on a GPIO pin). But yeah, no such. Sorry for introducing the confusion.
hello… I’m somewhat new to esphome devices.
I have a Atom Lite and a Atom U (usb-A).
I’m curious what I could add to the yaml code to re-enable the Led on the device to act as a status indicator?
These will both act as bluetooth proxies.
