I am one of these people So yes, any help is greatly appreciated, because Iām stuck searching for a way to control the battery charging of my SBSE4.0. I get no reaction to the typical Modbus commands 40149/40151 and canāt find a paramater in the webUi that would affect the battrry charging except for turning battery off completely. Thanks.
Hi Swante, and thank you for the awesome work!
I managed to setup my SHM2.0, but having trouble adding my inverter: Sunny Tripower 5.0 Smart Energy (hybrid inverter)
I tried all the interface options; others didnāt seem promising (not able to add device), but with the SpeedWire one I got it to recognize my inverter, and claim adding device is successful, but it shows up like this:
Diagnostic information is not available.
Normal logs: https://pastebin.com/TR6V1bmM
I see that a kind of similar device Tripower 10 Smart Energy was in the tested devices with Webconnect. This is baffling, as I was not able to add the device with webconnect regardless of SSL options or user/installer choices.
Any ideas what to try next?
The enneox-OS interface should worked.
Have to tried to just use the IP of the inverter?
have you verified that the username and password work directly on the inverter?
Speedwire has had some problems since version 0.3.5, which I have not yet been able to isolate as they do not occur in my case.
For host I have always used the direct ip address of the inverter.
The same IP in browser opens up the Inverterās admin page, and Iām using the same āinstallerā / <pw>
on my inverter successfully to open the admin page.
Some notes:
- When opening up the Inverter using a browser; it opens with http (not secured).
I was looking at your source code; I wasnāt able to test it yet, but Iām wondering if line 84 in init.py should be removed await sma.new_session()
I think before 0.35.0, that line was only executed inside the try/except block. Now, with the getPysmaInstance()
function it gets always executed?
The other function that calls getPysmaInstance() will later anyway call await sma.new_session() inside the try/except like before.
When trying with
SMA Devices with EnnexOS (e.g. Tripower X Serie)
I get error:
2024-08-31 21:06:09.351 ERROR (MainThread) [pysmaplus.device_ennexos] Request to https://192.168.88.71/api/v1/token did not return a valid json. Code 400
Iām a SMA noob, but Iām not sure if Tripower Smart Energy devices are ennexOS devices like the Tripower X series. The data sheet doesnāt mention anything about ennex?
Forked the repo, removed line 84 // new_session.
Now it failed with a new error:
Unexpected exception
File "/config/custom_components/pysmaplus/config_flow.py", line 47, in validate_input
device_list = await sma.device_list()
File "/usr/local/lib/python3.12/site-packages/pysmaplus/device_speedwire.py", line 440, in device_list
await self._protocol.start_query(["TypeLabel", "Firmware"], fut, self._group)
AttributeError: 'SMAspeedwireINV' object has no attribute '_protocol'
I havenāt yet understood what is the version link between the ha-pysmaplus and pysma repositories. Is there a corresponding version change on pysma repo side to 0.34 ā 0.35?
I was able to run the discovery:
discovery:
- addr: 192.168.88.72
port: 9522
identify:
- access: speedwireem
status: found
tested_endpoints: 192.168.88.72:38153
exception: None
remark: ""
device: Sunny Home Manager 2 (3014942681)
- access: ennexos
status: failed
tested_endpoints: https://192.168.88.72/api/v1/system/info
exception: >-
Could not connect to SMA at https://192.168.88.72: Cannot connect to
host 192.168.88.72:443 ssl:default [Connect call failed
('192.168.88.72', 443)]
remark: https
device: ""
- access: ennexos
status: failed
tested_endpoints: http://192.168.88.72/api/v1/system/info
exception: None
remark: http
device: ""
- access: speedwireinv
status: failed
tested_endpoints: 192.168.88.72:9522
exception: "No connection to device: 192.168.88.72:9522 (3/3)"
remark: ""
device: ""
- access: webconnect
status: failed
exception: >-
remark: https://192.168.88.72
device: ""
status: failed
exception: Server at http://192.168.88.72 disconnected 3 times.
remark: http://192.168.88.72
device: ""
- access: shm2
status: failed
exception: Could not connect to 192.168.88.72:502
remark: needs Installer Grid Guard Code. Usage not recommended.
device: ""
- addr: 192.168.88.71
port: 9522
identify:
status: maybe
tested_endpoints: 192.168.88.71:9522
exception: Login failed! Credentials wrong (user/install or password)
remark: only unencrypted Speedwire is supported
device: ""
- access: ennexos
status: failed
tested_endpoints: https://192.168.88.71/api/v1/system/info
exception: None
remark: https
device: ""
- access: ennexos
status: failed
tested_endpoints: http://192.168.88.71/api/v1/system/info
exception: None
remark: http
device: ""
status: failed
exception: ""
remark: https://192.168.88.71
device: ""
status: failed
exception: ""
remark: http://192.168.88.71
device: ""
status: failed
exception: None
remark: no multicast packet received.
device: ""
- access: shm2
status: failed
exception: Could not connect to 192.168.88.71:502
device: ""
status: {}
2024-08-31 21:40:17.740 ERROR (MainThread) [pysmaplus.device_speedwire] Login failed!
2024-08-31 21:40:19.751 WARNING (MainThread) [asyncio] socket.send() raised exception.
2024-08-31 21:40:20.252 WARNING (MainThread) [asyncio] socket.send() raised exception.
2024-08-31 21:40:20.956 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved (None)
File "/usr/local/lib/python3.12/site-packages/pysmaplus/device_speedwire.py", line 106, in controller
await self._send_next_command()
File "/usr/local/lib/python3.12/site-packages/pysmaplus/device_speedwire.py", line 158, in _send_next_command
f.set_result(True)
asyncio.exceptions.InvalidStateError: invalid state
please ignore my enneox comment. I made a mistake with the device type.
According to the discovery-action, speedwire should work:
status: maybe
device: ""
Unfortunately, as already mentioned, speedwire is currently problematic.
You could try installing HACS 0.3.4 and test whether Speedwire works with this version.
The differences between the two versions of the integration should be the following:
And for the used library:
Can you please test the latest version (0.4.2) from today.
I changed the logic for new_session
. Not sure if this helps with the speedwire problem.
