Support for new Nest Temperature Sensor?
Just wondering whether support for the new Nest Temperature Sensors are in the pipeline. I picked up three of these at launch and would love to leverage them in my Home Assistant setup.
https://nest.com/thermostats/nest-temperature-sensor/tech-specs/
+1
I would also love to be able to use this new tech in automation.
No support in near future. https://nestdevelopers.io/t/temperature-sensor-api/1317/13
Anyone see if they can port this node app add on for Temperature sensors to HA
Interesting, I will look into it.
Edit: I looked, it used reversed engineered Nest mobile app’s endpoints. python-nest, the lib behind HA’s Nest component support, has moved away from this way long time ago, and I don’t want to go back to this route.
If you want to do that, just downloaded the nest-remote-sensor, and it will be run on your local machine, exposure an HTTP API, then you can add a HTTP Sensor to integration data into HA.
I personally would not support integrate the whole process into HA.
