Support For New Switchbot Meter
There is a Switchbot integration already, but noticed it does not support new Meter product:
https://www.switch-bot.com/meter
Would love to be able to get temperature/humidity readings off this new Meter through the Switchbot integration. Is it possible to add support for this?
I know it’s a long time you wrote this post, but did you find any solution to integrate that?
I too am looking at this. Any way to make the switchbot meter work with home assistant?
Hi, guys - Look here to integrate your Meters with Home Assistant using MQTT.
Is there an other solution to get the data from the switch it meter?
