I use GrapheneOS on my phone which has neither Google Play Services nor MicroG. I am getting an error that the app cannot register. It allows me to select my instance and input my username/password.
Any options? Would it help to build the app myself?
In case you missed it you can now install the minimal flavor of the android app that does not require google services. Keep in mind things like location tracking and notifications will not work as those depend on google services. You can grab the APK from the actions tab on the github repo, just select the latest commit and download the minimal version.
Hey, dshokouhi - thanks so much for the update! The solution to my problem was actually easier than your idea. Before pulling the APK from the actions tab I just downloaded the Home Assistant app from the Play Store (Aurora Store, technically) and went through the first install wizard. Where it used to fail (after inputting user/password) there was a new “Skip” button. I had to consent to missing out on Location-based stuff (don’t use that anyway) and the app started working!
Thanks for responding to this issue. The app is working great now!
Hi folks! Recently switched over to GrapheneOS. Is there no way to get location tracking to work without Google Play? Not having all the lights turn off in the house when I leave is a bummer!
until someone comes and adds support for open source we rely on google services for location tracking…you can use the wifi connection sensor which updates its state immediately to detect when you are home or not. I use it for local presence myself, its faster than GPS in most cases too.
I’ve been on /e/OS for a while and had the same issue. I use the GPSLogger integration (or you could opt for OwnTracks) that seems to work really well for location tracking.
@johndoe_snmp-hassos, I’ve been using NextTracks (OwnTracks), but the app never seems to want to work properly. I usually have to fiddle with it to get it to update my location. I’m going to check out GPSLogger, thank you!
