the ONVIF standard for IP cameras among other things seems to be something that could be supported by Home Assistant.
There is even a Python module to communicate with ONVIF-enabled devices: https://github.com/quatanium/python-onvif
did you ever started with that? Iām in the same situation now.
ONVIF Support would be great!
I thought i need the ONVIF support, because I was not able to get my rstp stream.
But with RTSP support i could get my ONVIF RSTP Stream on HA.
Hi. I donāt understand what is wrong with my configuration.
In VLC software, if i put the stream like this, i had the stream working well.
rtsp://ip/onvif1
rtsp://ip:554/onvif1
rtsp://ip:554/onvif2
In the home assistant, i try to use the ffmeg like it was suggest here and itās not working.
camera:
platform: ffmpeg
input: rtsp://ip:554/onvif1
What am I doing wrong?
ffmpeg:
ffmpeg_bin: /usr/bin/avconv
camera 1:
- platform: ffmpeg
input: -rtsp_transport tcp -i rtsp://192.168.1.30/live/ch00_1
extra_arguments: -pred 1 -q:v 2
This is the code I am using and it is working for me. The /live/ch00_1 might be different for you.
Thanks for the response. Iāll try again with this setting when I get home.
This reply help me to understand what was wrong in my config.
https://community.home-assistant.io/t/rtsp-support/2306/9
tmjpugh2d
@mischoe
Below if for install on Raspberry pi that does not use Virtual Env
1.install ffmpeg. AKA āavconvā
sudo apt install libav-tools
2.add location of ffmpeg (or avconv) to configuration.yaml file. below location is example only. you must find yours
ffmpeg:
3.add camera to configuration.yaml file
FYI. There are many android/ios app support ONVIF to find IP cam RTSP address if you do not know this
camera:
Iāve written the onvif component. Iāve had is as a custom component for a few weeks now and itās similified the IP cameraā setup.
I have several Chinese ipcams and it works fine with them all.
I canāt see why it wouldnāt work with others.
It does require ffmpeg to be installed and setup.
Is anyone able to pull a .jpg with an ONVIF camera for notification in HA?
Is it going to make its way in to a future release? Is it capable of recording on motion detect/alarm?
My raspberry pi 3 crashes a few minutes after enabling my Chinese IP cameras because of ffmpegā¦ looking for a alternative to integrate them with hass.io. any ideas?
I had struggled to get the correct URL for the stream and then had to fiddle with the ffmpeg commands to get it working reliably. I also first used avconv but that was unreliable so i switched to use ffmpeg from the Jessie backports, that resolved several issues with the rtsp streams.
Thatās what made me write the component. Mine is running on a pi2 with hassbian.
I wanted to release the working version, then extra features can be added. The main issue I have found is trying to work out what the camera supports. Currently Iāve got PTZ working but itās not user friendly so Iāll be working on that once the first version is merged.
Matt
Any further work on the PTZ aspects?
Thoughts on subscriptions to Onvif events, e.g. movement?
Not really as several people have had issues which meant I spent time fixing them, and Iāve not had much time due to my 6 month old daughter.
I simply canāt get my Sricam SP009 camera to work with Hassio V53. I have tried both of the config settings below with the same result. I get an image under āFront Windowā in my dashboard, but it quickly locks everything up where I canāt refresh the dashboard page and there are no new entries in the log. A āhassio host rebootā is the only way to recover. Also, the rtsp url below works fine with FFMPEG from the command line (on my Mac at least).
Both of these config settings seemed to work initially, but eventually locked up the system
camera:
- platform: onvif
host: 192.168.0.53
camera:
- platform: ffmpeg
input: rtsp://192.168.0.53:554/onvif1
Here is the log right after it locks, nothing new is ever recorded after this:
2017-09-14 09:29:05 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=media_player.porch, old_state=None, new_state=<state media_player.porch=off; friendly_name=Porch, supported_features=21437 @ 2017-09-14T09:29:05.912794-04:00>>
2017-09-14 09:29:05 INFO (MainThread) [homeassistant.components.http] Serving /api/camera_proxy/camera.front_window to 192.168.0.6 (auth: True)
2017-09-14 09:29:11 INFO (SyncWorker_5) [pychromecast] Querying device status
2017-09-14 09:29:11 WARNING (MainThread) [homeassistant.components.media_player] Setup of platform cast is taking over 10 seconds.
2017-09-14 09:29:12 INFO (SyncWorker_5) [pychromecast] Querying device status
2017-09-14 09:29:12 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=media_player.home_group, old_state=None, new_state=<state media_player.home_group=off; friendly_name=Home group, supported_features=21437 @ 2017-09-14T09:29:12.387023-04:00>>
2017-09-14 09:29:12 INFO (MainThread) [homeassistant.components.http] Serving /api/camera_proxy/camera.front_window to 192.168.0.6 (auth: True)
Any help appreciated here!
Bob
Hi there. Same goes for my Digoo DG-M1Xā¦
I hope someone finds a solution, I have to remove the camera for now because it freezes everythingā¦ :-S
Same problem here. I donāt know whyā¦
As a temporary workaround, I have a secondary raspberry with a clean raspbian + ffmpeg transforming the rtsp stream into mjpegā¦ The mjpeg stream is imported without an issueā¦ :-S
