The new SmartThings integration is great, enabling me to turn off both my Mosquitto and SmartThings MQTT Bridge containers. One thing that I lost in the transition was the ability to select which platform is most appropriate for each device.
For example, I have several Homeseer HS-WS200+ switches. When using MQTT, I was able to configure them to be lights instead of switches. Unfortunately, a switch will not respond to a lights on/off command when part of a group. I’m currently working around this using the Light Switch platform, but that leads to two entities for each HS-WS200, a light and a switch. I’d prefer to just have the light if possible.
Another example is the Homeseer HS-FC200+ fan controller. It shows up in the new SmartThings integration as a dimmable light. This means I get a dimmer slider in the UI instead of the fan speed list. I may be able to work around it with a fan template, but I think I’ll still end up with two entities for that device.
Thanks for considering this feature request.
