I have installed several Shelly switches and often use the auto_off or auto_on timer function. This allows a switch to be activated or deactivated directly in the Shelly after a defined time.
It would be great if such a timer could also be queried in HA and used for automations or display on dashboards.
The API should be able to return the corresponding values such as timer_duration and timer_remaining. Shelly API
I would also love to be able to set these auto_on / auto_off timers and have access to read out the status data like timer_started, timer_duration and timer_remaining from within HA.
I have used multiple shelly 1 for my autoamtic garden watering. And there you really should use “auto off” timers to prevent that the garden is under water when some command isn’t send.
