Hi! These dimmers are very interesting because they are not expensive, work both with physical buttons and RF too, with SR-2818WiTR or SR-2818WiN we can convert RF to WiFi a unlimited number of dimmers.
When we have those dimmers reachable via IP from the Raspberry we may suppose to drive them easly by HA. Anything aready compatible existing? Thank you!
There is already a phone app for driving 8 dimmers called “Easylighting”, the author Kellie Scott
I have found the API, but how can I use it in HA?
Thank you a lot for help!
https://www.nuget.org/packages/Sunricher.Wifi.Api/1.0.5
I’ve found also MQTT library to implement it, I hope to find someone interested too so we can develope it for HA, thank you for writing
Hello!
Any updates about integration with arlight controller?
In the end I’ve sniffed the TCP traffic and I developed a clone of the app running on node red. It works stable, it’s important to don’t overload the dimmer with packets, ot it will crash and to revive it it’s needed a special reset procedure (you will loose lot of time).
If you’re interested I’ll describe how
hello I am interested in your solution to control the SR 2818WIN gateway. would it be possible to share it?,Thanks
If You are still here, we would very much appreciate to see, what you have sniffed
We want to control an AR-2818WiN in an old cinema
