Support for Tidal Music - Want to playback music playlists/songs directly from HA
Are there any chances of getting Tidal Music to work in Home Assistant?
Have the app and also my Pioneer reciever supports Tidal streaming and works fine in HA.
Have found these API wrappers(hence Tidal API apparently is not public)
Google music is not supported in Denmark, and similar 16$/month for Spotify is way more expensive than my Tidal sub for my personal usage.
Up up up.
Google Play Music support is coming to an end so there’s a large crowd moving to TIDAL and there’s still no custom component.
For TIDAL I’ve seen support everywhere:
There’s apps in Android like USB Audio Player Pro.
There’s desktop apps like Yaronzz TDM, Roon, Audirvana, etc.
There’s online services like Soundizz, TuneMyMusic and so on that also work with TIDAL.
So I am guessing they have an API that can be used for the custom component.
In order to get Tidal work on HA, here is an easy way that you could try. You could find the tool windows Tidal Music Converter on the web and use it to convert Tidal music for offline using. Then you can move Tidal music to HA for using with ease.
no, that’s not what we want.
no, that’s not what we want. Not sure why this is a difficult concept? Raspi sd card + 1tb of music choices. Do some math here. How many songs could fit onto my sd card? Now, if I’m playing music from the sd card, how long is that sd card gonna last before it craps out?
Get a clue you two.
Is there any update on this?
I recently switched from Spotify to TIDAL after learning Spotify barely pays their artists and am really missing this in Home Assistant because I can no longer auto-mute my music when a work call comes in.
tidalapi · PyPI seems like it could help to implement a TIDAL integration.
I hope there will be an integration as soon as possible. I love TIDAL and Spotify is just no option for me, connecting my account to Home Assistant would be great!
This is an important topic. Is there a place to track Tidal support as a feature in HA? Like GitHub or something?
Also, if I want to use a third party streamer like Bluesound Node, is there a different approach I can take with HA? Like, using HA to control a multi source and multi zone pre-amp via rs-232? Is that a thing?
HA Newb here, thanks for the help.
Now that Spotify seems to be a very bad place in many ways, Tidal integration would be even more important.
I totally agree with you. Found the tidalapi @TheLastProject mentioned a super interesting project that could be really helpful!
I voted for this FR but, as much as I would like to see a Tidal integration, I wouldn’t pin my hopes on the tamland/python-tidal project. It hasn’t accepted a PR since 2021-05-02 (and there are 11 pending PRs). It’s entirely possible the author has abandoned it.
An unmaintained PyPi project isn’t the best foundation for a new integration. It means someone would have to fork it first and take over its development/maintenance. That’s more work than just leveraging an existing, actively maintained PyPi project.
I hope it happens but I’m not counting on it.
I’m not sure in how far it’s the same a native HA integration for Tidal, but this HACS solution is promising compatibility with TIDAL as coming soon:
Actually you can upvote the tidal integratiin unto music assistant right here: Add Tidal support to Music providers · Discussion #432 · music-assistant/hass-music-assistant · GitHub
You can control Tidal on Musiccast via Node-Red. I’m currently using NFC Tag to act as my Virtual CD.
[{"id":"2ac9ef4cbc7f97a0","type":"subflow","name":"Tidal Yamach","info":"","category":"","in":[{"x":140,"y":300,"wires":[{"id":"65438434cf152f45"}]}],"out":[{"x":1380,"y":740,"wires":[{"id":"c193bd9edbfa6ab6","port":0}]}],"env":[],"meta":{},"color":"#DDAA99"},{"id":"7b1d1aba9b177571","type":"musiccast-list","z":"2ac9ef4cbc7f97a0","mc":"84646cc8.5bcdc","name":"Enter Level","device":"cc796d12-2dd6-49db-9c09-1e971208ea9e","type_device":"device","command":"setListControl","type_command":"command","payload":"{\"index\":\"5\",\"type\":\"select\"}","type_payload":"json","f_show_status":false,"x":1050,"y":420,"wires":[["b05aec256e8e45f0"]]},{"id":"e08ea4cb2c13fb94","type":"musiccast-list","z":"2ac9ef4cbc7f97a0","mc":"84646cc8.5bcdc","name":"Up one level","device":"cc796d12-2dd6-49db-9c09-1e971208ea9e","type_device":"device","command":"setListControl","type_command":"command","payload":"{\"type\":\"return\"}","type_payload":"json","f_show_status":false,"x":370,"y":600,"wires":[["2e8dc7ec02996f04"]]},{"id":"da0e2f6a92ca48e6","type":"musiccast-list","z":"2ac9ef4cbc7f97a0","mc":"84646cc8.5bcdc","name":"Up one level","device":"cc796d12-2dd6-49db-9c09-1e971208ea9e","type_device":"device","command":"setListControl","type_command":"command","payload":"{\"type\":\"return\"}","type_payload":"json","f_show_status":false,"x":350,"y":420,"wires":[["f3f9b3b58113aad7"]]},{"id":"f3f9b3b58113aad7","type":"musiccast-list","z":"2ac9ef4cbc7f97a0","mc":"84646cc8.5bcdc","name":"Up one level","device":"cc796d12-2dd6-49db-9c09-1e971208ea9e","type_device":"device","command":"setListControl","type_command":"command","payload":"{\"type\":\"return\"}","type_payload":"json","f_show_status":false,"x":370,"y":480,"wires":[["a47fc4f26d8ad47d"]]},{"id":"a47fc4f26d8ad47d","type":"musiccast-list","z":"2ac9ef4cbc7f97a0","mc":"84646cc8.5bcdc","name":"Up one level","device":"cc796d12-2dd6-49db-9c09-1e971208ea9e","type_device":"device","command":"setListControl","type_command":"command","payload":"{\"type\":\"return\"}","type_payload":"json","f_show_status":false,"x":370,"y":540,"wires":[["e08ea4cb2c13fb94"]]},{"id":"2e8dc7ec02996f04","type":"musiccast-list","z":"2ac9ef4cbc7f97a0","mc":"84646cc8.5bcdc","name":"Up one level","device":"cc796d12-2dd6-49db-9c09-1e971208ea9e","type_device":"device","command":"setListControl","type_command":"command","payload":"{\"type\":\"return\"}","type_payload":"json","f_show_status":false,"x":390,"y":660,"wires":[["a6181d65636bae36"]]},{"id":"b05aec256e8e45f0","type":"musiccast-list","z":"2ac9ef4cbc7f97a0","mc":"84646cc8.5bcdc","name":"Get current position","device":"cc796d12-2dd6-49db-9c09-1e971208ea9e","type_device":"device","command":"getListInfo","type_command":"command","payload":"{\"input\":\"tidal\",\"size\":\"8\"}","type_payload":"json","f_show_status":false,"x":1240,"y":420,"wires":[["ead63508a033a853"]]},{"id":"b84d9e5d3bc5b4b3","type":"musiccast-list","z":"2ac9ef4cbc7f97a0","mc":"84646cc8.5bcdc","name":"Enter Level","device":"cc796d12-2dd6-49db-9c09-1e971208ea9e","type_device":"device","command":"setListControl","type_command":"command","payload":"","type_payload":"msg","f_show_status":false,"x":1050,"y":480,"wires":[["a923e0dad81c57eb"]]},{"id":"a923e0dad81c57eb","type":"musiccast-list","z":"2ac9ef4cbc7f97a0","mc":"84646cc8.5bcdc","name":"Get current position","device":"cc796d12-2dd6-49db-9c09-1e971208ea9e","type_device":"device","command":"getListInfo","type_command":"command","payload":"{\"input\":\"tidal\",\"size\":\"8\"}","type_payload":"json","f_show_status":false,"x":1240,"y":480,"wires":[["41524c4f839cbe24"]]},{"id":"6ee144db3eef57eb","type":"musiccast-list","z":"2ac9ef4cbc7f97a0","mc":"84646cc8.5bcdc","name":"Enter Level","device":"cc796d12-2dd6-49db-9c09-1e971208ea9e","type_device":"device","command":"setListControl","type_command":"command","payload":"{\"list_id\":\"abc...\",\"index\":\"1-8\",\"zone\":\"main|zone1|...\",\"type\":\"play|select|return\"}","type_payload":"msg","f_show_status":false,"x":1050,"y":540,"wires":[["08fd1a9c35b23232"]]},{"id":"08fd1a9c35b23232","type":"musiccast-list","z":"2ac9ef4cbc7f97a0","mc":"84646cc8.5bcdc","name":"Get current position","device":"cc796d12-2dd6-49db-9c09-1e971208ea9e","type_device":"device","command":"getListInfo","type_command":"command","payload":"{\"input\":\"tidal\",\"size\":\"8\"}","type_payload":"json","f_show_status":false,"x":1240,"y":540,"wires":[["58b6f80b9041f456"]]},{"id":"7133ffb2cc7a3857","type":"musiccast-list","z":"2ac9ef4cbc7f97a0","mc":"84646cc8.5bcdc","name":"Enter Level","device":"cc796d12-2dd6-49db-9c09-1e971208ea9e","type_device":"device","command":"setListControl","type_command":"command","payload":"{\"index\":\"2\",\"type\":\"select\"}","type_payload":"json","f_show_status":false,"x":1050,"y":600,"wires":[["53411b0e7d4f5a0f"]]},{"id":"53411b0e7d4f5a0f","type":"musiccast-list","z":"2ac9ef4cbc7f97a0","mc":"84646cc8.5bcdc","name":"Get current position","device":"cc796d12-2dd6-49db-9c09-1e971208ea9e","type_device":"device","command":"getListInfo","type_command":"command","payload":"{\"input\":\"tidal\",\"size\":\"8\"}","type_payload":"json","f_show_status":false,"x":1240,"y":600,"wires":[["2326fac24f370c9c"]]},{"id":"2b77f99edd748adb","type":"musiccast-list","z":"2ac9ef4cbc7f97a0","mc":"84646cc8.5bcdc","name":"Play item","device":"cc796d12-2dd6-49db-9c09-1e971208ea9e","type_device":"device","command":"setListControl","type_command":"command","payload":"{\"index\":\"0\",\"type\":\"play\"}","type_payload":"json","f_show_status":false,"x":1040,"y":660,"wires":[["c193bd9edbfa6ab6"]]},{"id":"c193bd9edbfa6ab6","type":"musiccast-list","z":"2ac9ef4cbc7f97a0","mc":"84646cc8.5bcdc","name":"Get current position","device":"cc796d12-2dd6-49db-9c09-1e971208ea9e","type_device":"device","command":"getListInfo","type_command":"command","payload":"{\"input\":\"tidal\",\"size\":\"8\"}","type_payload":"json","f_show_status":false,"x":1240,"y":660,"wires":[[]]},{"id":"65438434cf152f45","type":"delay","z":"2ac9ef4cbc7f97a0","name":"","pauseType":"delay","timeout":"100","timeoutUnits":"milliseconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"allowrate":false,"outputs":1,"x":310,"y":300,"wires":[["1ad24d04215ef6f4"]]},{"id":"ead63508a033a853","type":"delay","z":"2ac9ef4cbc7f97a0","name":"","pauseType":"delay","timeout":"1","timeoutUnits":"milliseconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"allowrate":false,"outputs":1,"x":610,"y":480,"wires":[["34b39d11bd437be3"]]},{"id":"41524c4f839cbe24","type":"delay","z":"2ac9ef4cbc7f97a0","name":"","pauseType":"delay","timeout":"1","timeoutUnits":"milliseconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"allowrate":false,"outputs":1,"x":610,"y":540,"wires":[["ec0ea635c5350fa0"]]},{"id":"fab8de084563a62b","type":"delay","z":"2ac9ef4cbc7f97a0","name":"","pauseType":"delay","timeout":"1","timeoutUnits":"milliseconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"allowrate":false,"outputs":1,"x":610,"y":600,"wires":[["7133ffb2cc7a3857"]]},{"id":"2326fac24f370c9c","type":"delay","z":"2ac9ef4cbc7f97a0","name":"","pauseType":"delay","timeout":"1","timeoutUnits":"milliseconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"allowrate":false,"outputs":1,"x":610,"y":660,"wires":[["2b77f99edd748adb"]]},{"id":"1ad24d04215ef6f4","type":"musiccast-list","z":"2ac9ef4cbc7f97a0","mc":"84646cc8.5bcdc","name":"Up one level","device":"cc796d12-2dd6-49db-9c09-1e971208ea9e","type_device":"device","command":"setListControl","type_command":"command","payload":"{\"type\":\"return\"}","type_payload":"json","f_show_status":false,"x":330,"y":360,"wires":[["da0e2f6a92ca48e6"]]},{"id":"a6181d65636bae36","type":"musiccast-list","z":"2ac9ef4cbc7f97a0","mc":"84646cc8.5bcdc","name":"Get current position","device":"cc796d12-2dd6-49db-9c09-1e971208ea9e","type_device":"device","command":"getListInfo","type_command":"command","payload":"{\"input\":\"tidal\",\"size\":\"8\"}","type_payload":"json","f_show_status":false,"x":610,"y":360,"wires":[["e802dec4e4d465f8"]]},{"id":"e802dec4e4d465f8","type":"delay","z":"2ac9ef4cbc7f97a0","name":"","pauseType":"delay","timeout":"100","timeoutUnits":"milliseconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"allowrate":false,"outputs":1,"x":610,"y":420,"wires":[["7b1d1aba9b177571"]]},{"id":"7cb2198628c3f5f9","type":"comment","z":"2ac9ef4cbc7f97a0","name":"My music","info":"","x":1480,"y":420,"wires":[]},{"id":"304dc3ec906bfb2f","type":"comment","z":"2ac9ef4cbc7f97a0","name":"Artists=1 / Playlist=0","info":"","x":1510,"y":480,"wires":[]},{"id":"520a77a35dc289d5","type":"comment","z":"2ac9ef4cbc7f97a0","name":"Which Artist ? / Which Playlist ?","info":"","x":1690,"y":540,"wires":[]},{"id":"182913928a8e0863","type":"comment","z":"2ac9ef4cbc7f97a0","name":"Top tracks","info":"","x":1480,"y":600,"wires":[]},{"id":"9a1f79b94036ea99","type":"comment","z":"2ac9ef4cbc7f97a0","name":"Play first","info":"","x":1480,"y":660,"wires":[]},{"id":"ec0ea635c5350fa0","type":"template","z":"2ac9ef4cbc7f97a0","name":"","field":"payload","fieldType":"msg","format":"json","syntax":"mustache","template":"{\"index\":\"{{global.artist}}\",\"type\":\"select\"}","output":"json","x":760,"y":540,"wires":[["6ee144db3eef57eb"]]},{"id":"34b39d11bd437be3","type":"template","z":"2ac9ef4cbc7f97a0","name":"","field":"payload","fieldType":"msg","format":"json","syntax":"mustache","template":"{\"index\":\"{{global.playlist}}\",\"type\":\"select\"}","output":"json","x":760,"y":480,"wires":[["b84d9e5d3bc5b4b3"]]},{"id":"58b6f80b9041f456","type":"switch","z":"2ac9ef4cbc7f97a0","name":"","property":"playlist","propertyType":"global","rules":[{"t":"eq","v":"1","vt":"num"},{"t":"eq","v":"0","vt":"num"}],"checkall":"true","repair":false,"outputs":2,"x":1430,"y":540,"wires":[["fab8de084563a62b"],["2326fac24f370c9c"]]},{"id":"84646cc8.5bcdc","type":"musiccast-config","name":"Salon","device_list":{"cc796d12-2dd6-49db-9c09-1e971208ea9e":{"name":"Salon","address":"172.17.72.156","model":"WXA-50","input_list":"{\"napster\":{\"id\":\"napster\"},\"spotify\":{\"id\":\"spotify\"},\"juke\":{\"id\":\"juke\"},\"qobuz\":{\"id\":\"qobuz\"},\"tidal\":{\"id\":\"tidal\"},\"deezer\":{\"id\":\"deezer\"},\"airplay\":{\"id\":\"airplay\"},\"mc_link\":{\"id\":\"mc_link\"},\"server\":{\"id\":\"server\"},\"net_radio\":{\"id\":\"net_radio\"},\"bluetooth\":{\"id\":\"bluetooth\"},\"usb\":{\"id\":\"usb\"},\"optical\":{\"id\":\"optical\"},\"aux\":{\"id\":\"aux\"}}","zone_list":"{\"main\":{\"id\":\"main\",\"input_list\":[\"napster\",\"spotify\",\"juke\",\"qobuz\",\"tidal\",\"deezer\",\"airplay\",\"mc_link\",\"server\",\"net_radio\",\"bluetooth\",\"usb\",\"optical\",\"aux\"],\"link_control_list\":[\"speed\",\"standard\",\"stability\"],\"link_audio_delay_list\":[\"audio_sync_on\",\"audio_sync_off\"],\"distribution\":{\"version\":2,\"compatible_client\":[2],\"client_max\":9,\"server_zone_list\":[\"main\"]},\"sound_program_list\":[]}}","serial":"0C8E78F3","udn":"uuid:9ab0c000-f668-11de-9976-00a0dedca5fb","uuid":"cc796d12-2dd6-49db-9c09-1e971208ea9e","status":"seen","mod_date":"2022-10-23T07:17:07.282Z"}},"f_use_debug":false,"list_language":"en","command_timeout":"2000","main":"Main","zone_2":"Zone 2","zone_3":"Zone 3","zone_4":"Zone 4","services_timeout":"5000"},{"id":"fcca692f173354c4","type":"server-events","z":"6e1d71a7e3879120","name":"NFC Tag scanned","server":"d304dcc2.36956","version":2,"eventType":"tag_scanned","exposeToHomeAssistant":false,"eventData":"","haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"waitForRunning":true,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"eventData"},{"property":"topic","propertyType":"msg","value":"$outputData(\"eventData\").event_type","valueType":"jsonata"},{"property":"event_type","propertyType":"msg","value":"$outputData(\"eventData\").event_type","valueType":"jsonata"}],"x":130,"y":340,"wires":[["9cbd618a1495d29e"]]},{"id":"2cf1d3439cf266e0","type":"switch","z":"6e1d71a7e3879120","name":"NFC Tag ?","property":"msg.payload.event.tag_id","propertyType":"msg","rules":[{"t":"cont","v":"26-45-1A-63","vt":"str"},{"t":"cont","v":"38-93-61-73","vt":"str"},{"t":"cont","v":"2B-62-B6-63","vt":"str"},{"t":"cont","v":"10-AC-92-AF","vt":"str"},{"t":"cont","v":"76-BA-D1-63","vt":"str"},{"t":"cont","v":"3B-63-F9-63","vt":"str"},{"t":"eq","v":"","vt":"str"},{"t":"eq","v":"","vt":"str"},{"t":"eq","v":"","vt":"str"},{"t":"eq","v":"","vt":"str"},{"t":"eq","v":"","vt":"str"},{"t":"eq","v":"","vt":"str"},{"t":"eq","v":"","vt":"str"},{"t":"eq","v":"","vt":"str"},{"t":"eq","v":"","vt":"str"},{"t":"eq","v":"","vt":"str"},{"t":"eq","v":"","vt":"str"},{"t":"eq","v":"","vt":"str"},{"t":"eq","v":"","vt":"str"}],"checkall":"true","repair":false,"outputs":19,"x":150,"y":700,"wires":[["87e5731081e5eccb"],["2d4a7d171d861aec"],["511d5edcc0ecfdb6"],["1115652b4660e6de"],["44b47f46894fc9d0"],["8064233cd28b5235"],["82865ce55ce2a2a5"],["4e071c8b148b284f"],["c299fe113a4ca37a"],["e9b2490e648c8447"],[],[],[],[],[],[],[],[],[]]},{"id":"9cbd618a1495d29e","type":"api-call-service","z":"6e1d71a7e3879120","name":"Włącz Yamacha","server":"d304dcc2.36956","version":5,"debugenabled":false,"domain":"media_player","service":"turn_on","areaId":[],"deviceId":[],"entityId":["media_player.salon_2"],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":340,"y":340,"wires":[["f4795e386f149122"]]},{"id":"f4795e386f149122","type":"api-call-service","z":"6e1d71a7e3879120","name":"Wejście Tidal","server":"d304dcc2.36956","version":5,"debugenabled":false,"domain":"media_player","service":"select_source","areaId":[],"deviceId":[],"entityId":["media_player.salon_2"],"data":"{\"source\":\"tidal\"}","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":550,"y":340,"wires":[["2cf1d3439cf266e0"]]},{"id":"5844887391a53926","type":"api-call-service","z":"6e1d71a7e3879120","name":"Set shuffle","server":"d304dcc2.36956","version":5,"debugenabled":false,"domain":"media_player","service":"shuffle_set","areaId":[],"deviceId":[],"entityId":["media_player.salon_2"],"data":"{\"shuffle\":1}","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1010,"y":660,"wires":[[]]},{"id":"abb322e7915f6981","type":"subflow:2ac9ef4cbc7f97a0","z":"6e1d71a7e3879120","name":"","x":790,"y":660,"wires":[["5844887391a53926","2411a6d6f8f17983"]]},{"id":"87e5731081e5eccb","type":"change","z":"6e1d71a7e3879120","name":"Black Sabbath","rules":[{"t":"set","p":"artist","pt":"global","to":"4","tot":"num"},{"t":"set","p":"shuffle","pt":"global","to":"1","tot":"num"},{"t":"set","p":"playlist","pt":"global","to":"1","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":500,"y":560,"wires":[["abb322e7915f6981"]]},{"id":"2411a6d6f8f17983","type":"debug","z":"6e1d71a7e3879120","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":1010,"y":600,"wires":[]},{"id":"2d4a7d171d861aec","type":"change","z":"6e1d71a7e3879120","name":"Tool","rules":[{"t":"set","p":"artist","pt":"global","to":"44","tot":"num"},{"t":"set","p":"shuffle","pt":"global","to":"1","tot":"num"},{"t":"set","p":"playlist","pt":"global","to":"1","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":470,"y":600,"wires":[["abb322e7915f6981"]]},{"id":"511d5edcc0ecfdb6","type":"change","z":"6e1d71a7e3879120","name":"Jan","rules":[{"t":"set","p":"artist","pt":"global","to":"3","tot":"num"},{"t":"set","p":"shuffle","pt":"global","to":"1","tot":"num"},{"t":"set","p":"playlist","pt":"global","to":"0","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":470,"y":640,"wires":[["abb322e7915f6981"]]},{"id":"1115652b4660e6de","type":"change","z":"6e1d71a7e3879120","name":"Jacek","rules":[{"t":"set","p":"artist","pt":"global","to":"2","tot":"num"},{"t":"set","p":"shuffle","pt":"global","to":"1","tot":"num"},{"t":"set","p":"playlist","pt":"global","to":"0","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":470,"y":680,"wires":[["abb322e7915f6981"]]},{"id":"44b47f46894fc9d0","type":"change","z":"6e1d71a7e3879120","name":"Synthwave","rules":[{"t":"set","p":"artist","pt":"global","to":"4","tot":"num"},{"t":"set","p":"shuffle","pt":"global","to":"1","tot":"num"},{"t":"set","p":"playlist","pt":"global","to":"0","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":490,"y":720,"wires":[["abb322e7915f6981"]]},{"id":"8064233cd28b5235","type":"change","z":"6e1d71a7e3879120","name":"Queen","rules":[{"t":"set","p":"artist","pt":"global","to":"39","tot":"num"},{"t":"set","p":"shuffle","pt":"global","to":"1","tot":"num"},{"t":"set","p":"playlist","pt":"global","to":"1","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":470,"y":760,"wires":[["abb322e7915f6981"]]},{"id":"82865ce55ce2a2a5","type":"change","z":"6e1d71a7e3879120","name":"Metallica","rules":[{"t":"set","p":"artist","pt":"global","to":"30","tot":"num"},{"t":"set","p":"shuffle","pt":"global","to":"1","tot":"num"},{"t":"set","p":"playlist","pt":"global","to":"1","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":480,"y":800,"wires":[["abb322e7915f6981"]]},{"id":"4e071c8b148b284f","type":"change","z":"6e1d71a7e3879120","name":"Kult","rules":[{"t":"set","p":"artist","pt":"global","to":"30","tot":"num"},{"t":"set","p":"shuffle","pt":"global","to":"1","tot":"num"},{"t":"set","p":"playlist","pt":"global","to":"1","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":470,"y":840,"wires":[["abb322e7915f6981"]]},{"id":"c299fe113a4ca37a","type":"change","z":"6e1d71a7e3879120","name":"KNZ","rules":[{"t":"set","p":"artist","pt":"global","to":"30","tot":"num"},{"t":"set","p":"shuffle","pt":"global","to":"1","tot":"num"},{"t":"set","p":"playlist","pt":"global","to":"1","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":470,"y":880,"wires":[["abb322e7915f6981"]]},{"id":"e9b2490e648c8447","type":"change","z":"6e1d71a7e3879120","name":"Led Zepplin","rules":[{"t":"set","p":"artist","pt":"global","to":"30","tot":"num"},{"t":"set","p":"shuffle","pt":"global","to":"1","tot":"num"},{"t":"set","p":"playlist","pt":"global","to":"1","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":490,"y":920,"wires":[["abb322e7915f6981"]]},{"id":"d304dcc2.36956","type":"server","name":"Home Assistant","version":5,"addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"on|home","connectionDelay":true,"cacheJson":true,"heartbeat":false,"heartbeatInterval":"30","areaSelector":"friendlyName","deviceSelector":"friendlyName","entitySelector":"friendlyName","statusSeparator":"at: ","statusYear":"hidden","statusMonth":"short","statusDay":"numeric","statusHourCycle":"h23","statusTimeFormat":"h:m","enableGlobalContextStore":true}]
i wish … Changed to Tidal also.
any updates on this maybe through Music Assistant?
any news ?
See my message here last week: Add Tidal support to Music providers · Discussion #432 · music-assistant/hass-music-assistant · GitHub
Not sure what’s going on here.
Any update here? I have tried the music assistant however the sound sounds horrible it doesn´t handle the flac output of tidal. Is there a possibility to get the sound quality as from the connect api?
