Hello, I am pretty new at this, but I have a problem. I bought a window opener on Amazon (from China of course) and it can be controlled by the Tuya app. I also have a bunch of Tuya devices that I previously integrated into Home Assistant and they all work great. Yet for this window opener (Olide) the device shows up in HA but is unsupported, and no entity is found for it. I donwloaded the device diagnostics and it shows the device category is also mc, and it led me to this thread.
My question is, does the current solution only cover the contact sensors? Or it also solves my problem? If so how do I get the modified code (or the correct Tuya integration version) into my server? Thanks for any help!
Below is the json diagnostic file:
"home_assistant": {
"installation_type": "Home Assistant OS",
"version": "2022.7.5",
"dev": false,
"hassio": true,
"virtualenv": false,
"python_version": "3.10.5",
"docker": true,
"arch": "aarch64",
"timezone": "America/Los_Angeles",
"os_name": "Linux",
"os_version": "5.15.32-v8",
"supervisor": "2022.07.0",
"host_os": "Home Assistant OS 8.3",
"docker_version": "20.10.14",
"chassis": "embedded",
"run_as_root": true
"custom_components": {},
"integration_manifest": {
"domain": "tuya",
"name": "Tuya",
"documentation": "https://www.home-assistant.io/integrations/tuya",
"requirements": [
"tuya-iot-py-sdk==0.6.6"
"dependencies": [
"ffmpeg"
"codeowners": [
"@Tuya",
"@zlinoliver",
"@frenck"
"config_flow": true,
"iot_class": "cloud_push",
"dhcp": [
"macaddress": "105A17*"
"macaddress": "10D561*"
"macaddress": "1869D8*"
"macaddress": "381F8D*"
"macaddress": "508A06*"
"macaddress": "68572D*"
"macaddress": "708976*"
"macaddress": "7CF666*"
"macaddress": "84E342*"
"macaddress": "D4A651*"
"macaddress": "D81F12*"
"loggers": [
"tuya_iot"
"is_built_in": true
"data": {
"endpoint": "https://openapi.tuyaus.com",
"auth_type": 0,
"country_code": "1",
"app_type": "tuyaSmart",
"mqtt_connected": true,
"disabled_by": null,
"disabled_polling": false,
"name": "Window Opener Left",
"model": "",
"category": "mc",
"product_id": "2tIqtzQxiihn6D14",
"product_name": "Intelligent Window",
"online": true,
"sub": false,
"time_zone": "-08:00",
"active_time": "2022-07-06T21:59:16+00:00",
"create_time": "2022-07-06T21:59:16+00:00",
"update_time": "2022-07-06T22:04:02+00:00",
"function": {
"anti_theft": {
"type": "Boolean",
"value": {}
"percent_control": {
"type": "Integer",
"value": {
"unit": "%",
"min": 0,
"max": 100,
"scale": 0,
"step": 1
"control": {
"type": "Integer",
"value": {
"range": [
"open",
"stop",
"close"
"auto_power": {
"type": "Boolean",
"value": {}
"status_range": {
"anti_theft": {
"type": "Boolean",
"value": {}
"type": "Integer",
"value": {
"unit": "%",
"min": 0,
"max": 100,
"scale": 0,
"step": 1
"control": {
"type": "Enum",
"value": {
"range": [
"open",
"stop",
"close"
"auto_power": {
"type": "Boolean",
"value": {}
"status": {
"anti_theft": false,
"percent_control": 99,
"control": "stop",
"auto_power": true
"home_assistant": {
"name_by_user": null,
"disabled": false,
"entities": []
