nmsousa76
(nmsousa76)
March 22, 2023, 12:56am
1
It looks like today we only have a device_tracker and an update entity for the USP-PDU-Pro (see picture 1). It would be great to have switches to control the outlets in the same way as we have for teh POE switches (See picture 2)
I have a PDU Pro as well and would love this feature.
d4rk22
(Ryan Christensen)
May 29, 2023, 6:03am
3
+1 for integrating this device. I’d love a way to track power usage over time per device.
Cisien
(Chris)
August 8, 2023, 11:12pm
4
I’m working on a PR that will implement this!
home-assistant:dev ← Cisien:add-support-for-outlet-power
opened 11:14PM - 08 Aug 23 UTC
You are amazing! Thanks for contributing to our project!
Please, DO N… OT DELETE ANY TEXT from this template! (unless instructed).
## Proposed change
Describe the big picture of your changes here to communicate to the
maintainers why we should accept this pull request. If it fixes a bug
or resolves a feature request, be sure to link to that issue in the
additional information section.
This PR adds support for the Unifi component to pull power statistics from power outlets on PDU devices that support providing power data.
## Type of change
What type of change does your PR introduce to Home Assistant?
NOTE: Please, check only 1! box!
If your PR requires multiple boxes to be checked, you'll most likely need to
split it into multiple PRs. This makes things easier and faster to code review.
- [ ] Dependency upgrade
- [ ] Bugfix (non-breaking change which fixes an issue)
- [ ] New integration (thank you!)
- [X] New feature (which adds functionality to an existing integration)
- [ ] Deprecation (breaking change to happen in the future)
- [ ] Breaking change (fix/feature causing existing functionality to break)
- [ ] Code quality improvements to existing code or addition of tests
## Additional information
Details are important, and help maintainers processing your PR.
Please be sure to fill out additional details, if applicable.
This change was developed against the USP-PDU-Pro device, and tested with the USP-Plug as a device that shows up in the outlets API, but does not support power reporting. Additionally, the PDU-Pro has four outlets that are USB-C ports, which do not report power. In all cases, outlets that don't support this function are not included as power sensors.
My setup includes two PDU-Pro devices which properly associate their respective plugs.
- This PR fixes or closes issue: N/A
- This PR is related to issue: N/A
- Link to documentation pull request: N/A
- This PR fulfills the requirements in this feature request: https://community.home-assistant.io/t/support-for-usp-pdu-pro-in-the-ubiquity-integration/550746
## Checklist
Put an `x` in the boxes that apply. You can also fill these out after
creating the PR. If you're unsure about any of them, don't hesitate to ask.
We're here to help! This is simply a reminder of what we are going to look
for before merging your code.
- [X] The code change is tested and works locally.
- [X] Local tests pass. **Your PR cannot be merged unless tests pass**
- [X] There is no commented out code in this PR.
- [X] I have followed the [development checklist][dev-checklist]
- [X] I have followed the [perfect PR recommendations][perfect-pr]
- [X] The code has been formatted using Black (`black --fast homeassistant tests`)
- [X] Tests have been added to verify that the new code works.
If user exposed functionality or configuration variables are added/changed:
- [ ] Documentation added/updated for [www.home-assistant.io][docs-repository]
If the code communicates with devices, web services, or third-party tools:
- [ ] The [manifest file][manifest-docs] has all fields filled out correctly.
Updated and included derived files by running: `python3 -m script.hassfest`.
- [ ] New or updated dependencies have been added to `requirements_all.txt`.
Updated by running `python3 -m script.gen_requirements_all`.
- [ ] For the updated dependencies - a link to the changelog, or at minimum a diff between library versions is added to the PR description.
- [ ] Untested files have been added to `.coveragerc`.
This project is very active and we have a high turnover of pull requests.
Unfortunately, the number of incoming pull requests is higher than what our
reviewers can review and merge so there is a long backlog of pull requests
waiting for review. You can help here!
By reviewing another pull request, you will help raise the code quality of
that pull request and the final review will be faster. This way the general
pace of pull request reviews will go up and your wait time will go down.
When picking a pull request to review, try to choose one that hasn't yet
been reviewed.
Thanks for helping out!
To help with the load of incoming pull requests:
- [ ] I have reviewed two other [open pull requests][prs] in this repository.
[prs]: https://github.com/home-assistant/core/pulls?q=is%3Aopen+is%3Apr+-author%3A%40me+-draft%3Atrue+-label%3Awaiting-for-upstream+sort%3Acreated-desc+review%3Anone+-status%3Afailure
Thank you for contributing <3
Below, some useful links you could explore:
[dev-checklist]: https://developers.home-assistant.io/docs/development_checklist/
[manifest-docs]: https://developers.home-assistant.io/docs/creating_integration_manifest/
[quality-scale]: https://developers.home-assistant.io/docs/integration_quality_scale_index/
[docs-repository]: https://github.com/home-assistant/home-assistant.io
[perfect-pr]: https://developers.home-assistant.io/docs/review-process/#creating-the-perfect-pr
Just saw support show up after one of the recent updates, working great, thank you so much for implementing this!!
vcdx71
(Mike)
September 20, 2023, 7:36pm
6
Looking at adding one of these to my setup. Is the integration able to turn on/off the outlets or just track the usage?
vcdx71
(Mike)
September 20, 2023, 7:43pm
7
Found the PR, looks like it was merged so should support on/off operations too. Ordering now.
Looking at the PR it looks like it only supports usage - if you ended up buying it let me know if the outlet on/off works. I’m looking at it but want to confirm the outlet support first.
vcdx71
(Mike)
October 9, 2023, 6:55pm
9
Finally installed mine, been sitting here for a couple weeks. You do get individual outlet control as well as monitoring.
sgruby
(Scott Gruby)
October 24, 2023, 2:43am
10
I’m seeing energy usage on a per outlet basis, but not switches for the outlets. I wonder if I have to set it up again.
Has the ability to control individual circuits/outlets of the PDU-Pro ever been added / can anyone confirm that it… exists?
zacs
April 8, 2025, 3:54am
12
Yep, they have been able to be controlled and monitor power usage for some time. The only thing missing is a total energy sensor (needed for inclusion in the Energy dashboard), which is easy enough to add like so:
- platform: integration
name: Main Floor USP PDU Pro Total Energy
source: sensor.main_floor_usp_pdu_pro_ac_power_consumption
unit_prefix: k
GUS1
April 8, 2025, 3:33pm
13
I can see the current usage but I’m not able to control the on/off functions. Not sure what’s wrong with my install if this is working for others
RASBR
(Rami)
August 5, 2025, 10:32am
14
I noticed that on the PDU device when toggling the switch for an outlet to off, it return back to on right away, and in the Developer tools → States it always has the ‘ON’ state.
The only way it worked is from Developer Tools → Actions → Switch.Turn_off/on, yet it doesn’t reflect the state on the switch in the device
Edit: The power measurement entities per outlet also don’t update when the outlet is turned off.
sgruby
(Scott Gruby)
September 2, 2025, 2:15pm
15
To answer my own question, if the user you give in UniFi only has Viewer privileges, you won’t be able to power cycle any of the outlets. After you give the user more privileges, restart Home Assistant and then you’ll be able to toggle power outlets.
