Logger: velbus-protocol
Source: deps/lib/python3.12/site-packages/velbusaio/protocol.py:91
First occurred: 7:55:09 AM (512 occurrences)
Last logged: 9:19:08 AM
Velbus connection lost: RuntimeError(‘get_buffer() returned an empty buffer’)
Also seems like my integration is not working anymore unless I reload it fully. Afterwards it’s working again for a random amount of time after which this happens again.
Any ideas ?
Note: I still need to update to the latest HA version but had issues with it last few days so reverted to older version with older Velbus integration as well (so if this is a known issue and it already got fixed in a newer version, I apologize and that would be good news… then I just need to figure out what’s going on with the new HA version because when I upgrade it doesn’t start up anymore and gives a 404 error)
Stop your HA instance and in the file system in configuration you’ll find a Velbus folder with all configuration, you can delete that and restart everything for new scans
I was wondering if there were plans to integrate VMB8IN-20 into Home Assistant. This is the only module I have that lacks support. It would be nice to add sensors this way and would open up the possibility to add energy monitoring to my smart home. Thanks!
Hi All, longterm Velbus user but novice debugger. I’m running HA on a PI with Velbus Direct via USB connected. When upgrading from 2025.1.0 to 2025.1.2 most of the time the Velbus integration fails to load. After reloading the integration sometimes the error message seems to go away but the entities remain unavailable. Already tried clearing the cache via the developer tools and manually from the system but no dice.
Logger: homeassistant.config_entries
Source: config_entries.py:640
First occurred: 10:33:41 PM (3 occurrences)
Last logged: 10:34:24 PM
Error setting up entry nestje for velbus
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 640, in __async_setup_with_context
result = await component.async_setup_entry(hass, self)
File "/usr/src/homeassistant/homeassistant/components/velbus/__init__.py", line 90, in async_setup_entry
await controller.connect()
File "/usr/local/lib/python3.13/site-packages/velbusaio/controller.py", line 147, in connect
await self._handler.read_protocol_data()
File "/usr/local/lib/python3.13/site-packages/velbusaio/handler.py", line 62, in read_protocol_data
self.broadcast = json.loads(await protocol_file.read())
File "/usr/local/lib/python3.13/site-packages/aiofile/utils.py", line 298, in read
return await self.__read(length)
File "/usr/local/lib/python3.13/site-packages/aiofile/utils.py", line 279, in __read
part_offset, part = await unicode_reader(
self.file, length, offset, self.encoding,
File "/usr/local/lib/python3.13/site-packages/aiofile/utils.py", line 26, in unicode_reader
chunk_bytes = await afp.read_bytes(-1, offset)
File "/usr/local/lib/python3.13/site-packages/aiofile/aio.py", line 233, in read_bytes
return await self.__context.read(size, self.fileno(), offset)
File "/usr/local/lib/python3.13/site-packages/caio/asyncio_base.py", line 47, in submit
if self.context.submit(op) != 1:
ValueError: The AIO context specified by ctx_id is invalid. nr is less than 0. The iocb at *iocbpp[0] is not properly initialized, the operation specified is invalid for the file descriptor in the iocb, or the value in the aio_reqprio field is invalid. [EINVAL]
This is the error thrown when reloading the integration.
I’ve tried removing the integration all together and adding it again but I get an Unknown error on the integration config after entering my connection string.
Restoring backup of 2025.1.0 immediately brings back Velbus connectivity. Anyone has an idea on what is going wrong with the update?
Hello fellow Velbus enthusiasts, I am using multiple Velbus sensors with an integrated thermometer like VMBPIRO and several VMBELO-20. The problem is that the value is not automatically updated. This is solved by reloading the Velbus integration every x minutes.
The issue with this is that every entity of the Velbus integration is reloaded and the motion sensors are reset which is not the intention. Does someone know a workaround for this, am I doing something wrong, is this a bug in the integration?
Thanks in advance!
Hello, does this implementation include the inputs for energy monitoring (consumption and injection)? I was not able to make this work yet if it does. If you need help with the testing part, I would like to offer my assistance. Have a good one!
Just an FYI, the new release didn’t make a difference either but since I was planning to move to a TCP connection in any case I sped up that process and now connect via Velserv succesfully and I don’t get the error message anymore.
However I did notice something else though with my VMBMETEO. Some of the entities get trailed by some strange characters. I can change the entity name in the settings but in the module overview these never seem to be going away.
Any ideas? I don’t see the same in VelbusLink.
Maybe just one addition to the previous comment. Is there anyway we can match the units used in HA with the ones in Velbus directly? Apart from Temperature being the same the other values seem to be coming in differently and I’ve not being able to use them consistently for my automations.
I updated from HA 2025.1.2 to 2025.3.2 today and got following Velbus error from the logs:
2025-03-14 09:27:23.893 ERROR (MainThread) [homeassistant.components.velbus] Migrating from version 2.1
2025-03-14 09:27:23.893 ERROR (MainThread) [homeassistant.components.velbus] Migration to version 2.2 successful
The ‘Error’ probably must be something less severe, because everything looks to be working.
Another thing is that most (not all) entities got their names prefixed with the modulename and channel name. This results in:
The name before the update was ‘Pomp living’.
Some entities are not recognized anymore in the interface. I had to change it to the new name.
Is this renaming of entities a new feature of the Velbus integration ?
BTW: I tried today’s update to 2025.3.3 too, but same result.
