Hello Thomas, I have the module VMB1USB in my velbus topology at home. When changing the configuration.yaml with the following (see last lines here below):
Text to speech
tts:
group: !include groups.yaml
script: !include scripts.yaml
velbus:
port: ā/dev/ttyACM0ā
core-ssh:~#
I did a reboot and still get the error. Here is the export of the command dmesg
0.243468] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.498335] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 7 counters available
[ 0.499687] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.512815] VFS: Disk quotas dquot_6.6.0
[ 0.513117] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.515013] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.515496] FS-Cache: Netfs ānfsā registered for caching
[ 0.516361] NFS: Registering the id_resolver key type
[ 0.516401] Key type id_resolver registered
[ 0.516410] Key type id_legacy registered
[ 0.518099] aufs 4.4-20170703
[ 0.519490] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[ 0.519606] io scheduler noop registered
[ 0.519622] io scheduler deadline registered
[ 0.519669] io scheduler cfq registered (default)
[ 0.522188] BCM2708FB: allocated DMA memory fdc10000
[ 0.522214] BCM2708FB: allocated DMA channel 0 @ f3007000
[ 0.527331] Console: switching to colour frame buffer device 82x26
[ 0.604570] bcm2835-rng 3f104000.rng: hwrng registered
[ 0.604686] vc-cma: Videocore CMA driver
[ 0.604695] vc-cma: vc_cma_base = 0x00000000
[ 0.604704] vc-cma: vc_cma_size = 0x00000000 (0 MiB)
[ 0.604712] vc-cma: vc_cma_initial = 0x00000000 (0 MiB)
[ 0.604921] vc-mem: phys_addr:0x00000000 mem_base=0x3ea00000 mem_size:0x3f000000(1008 MiB)
[ 0.619404] brd: module loaded
[ 0.628020] loop: module loaded
[ 0.628894] vchiq: vchiq_init_state: slot_zero = 0xbdc80000, is_master = 0
[ 0.630271] Loading iSCSI transport class v2.0-870.
[ 0.630820] tun: Universal TUN/TAP device driver, 1.6
[ 0.630830] tun: Ā© 1999-2004 Max Krasnyansky [email protected]
[ 0.631127] usbcore: registered new interface driver smsc95xx
[ 0.631179] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 0.831457] Core Release: 2.80a
[ 0.831469] Setting default values for core params
[ 0.831498] Finished setting default values for core params
[ 1.031825] Using Buffer DMA mode
[ 1.031835] Periodic Transfer Interrupt Enhancement - disabled
[ 1.031843] Multiprocessor Interrupt Enhancement - disabled
[ 1.031852] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 1.031866] Dedicated Tx FIFOs mode
[ 1.032152] WARN::dwc_otg_hcd_init:1047: FIQ DMA bounce buffers: virt = 0xbdc04000 dma = 0xfdc04000 len=9024
[ 1.032181] FIQ FSM acceleration enabled for :
[ 1.032181] Non-periodic Split Transactions
[ 1.032181] Periodic Split Transactions
[ 1.032181] High-Speed Isochronous Endpoints
[ 1.032181] Interrupt/Control Split Transaction hack enabled
[ 1.032203] dwc_otg: Microframe scheduler enabled
[ 1.032244] WARN::hcd_init_fiq:415: FIQ on core 1 at 0x804804d0
[ 1.032257] WARN::hcd_init_fiq:416: FIQ ASM at 0x80480830 length 36
[ 1.032271] WARN::hcd_init_fiq:441: MPHI regs_base at 0xbe87e000
[ 1.032328] dwc_otg 3f980000.usb: DWC OTG Controller
[ 1.032363] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
[ 1.032397] dwc_otg 3f980000.usb: irq 62, io mem 0x00000000
[ 1.032448] Init: Port Power? op_state=1
[ 1.032455] Init: Power Port (0)
[ 1.032653] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.032668] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.032680] usb usb1: Product: DWC OTG Controller
[ 1.032692] usb usb1: Manufacturer: Linux 4.4.50 dwc_otg_hcd
[ 1.032703] usb usb1: SerialNumber: 3f980000.usb
[ 1.033385] hub 1-0:1.0: USB hub found
[ 1.033434] hub 1-0:1.0: 1 port detected
[ 1.034003] dwc_otg: FIQ enabled
[ 1.034012] dwc_otg: NAK holdoff enabled
[ 1.034020] dwc_otg: FIQ split-transaction FSM enabled
[ 1.034049] Module dwc_common_port init
[ 1.034295] usbcore: registered new interface driver usb-storage
[ 1.034515] mousedev: PS/2 mouse device common for all mice
[ 1.035180] bcm2835-cpufreq: min=600000 max=1200000
[ 1.040228] sdhci: Secure Digital Host Controller Interface driver
[ 1.040233] sdhci: Copyright© Pierre Ossman
[ 1.040385] sdhost: log_buf @ bdc07000 (fdc07000)
[ 1.093813] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
[ 1.095844] mmc-bcm2835 3f300000.mmc: mmc_debug:0 mmc_debug2:0
[ 1.095850] mmc-bcm2835 3f300000.mmc: DMA channel allocated
[ 1.153857] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.154053] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.154115] hidraw: raw HID events driver Ā© Jiri Kosina
[ 1.154206] usbcore: registered new interface driver usbhid
[ 1.154210] usbhid: USB HID core driver
[ 1.154404] nf_conntrack version 0.5.0 (15500 buckets, 62000 max)
[ 1.155222] ip_tables: Ā© 2000-2006 Netfilter Core Team
[ 1.155313] Initializing XFRM netlink socket
[ 1.156010] NET: Registered protocol family 10
[ 1.156636] NET: Registered protocol family 17
[ 1.156669] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
[ 1.156726] Key type dns_resolver registered
[ 1.156956] Registering SWP/SWPB emulation handler
[ 1.157389] registered taskstats version 1
[ 1.157487] vc-sm: Videocore shared memory driver
[ 1.157494] [vc_sm_connected_init]: start
[ 1.157618] vc_vchi_sm_init: failed to open VCHI service (-1)
[ 1.157624] [vc_sm_connected_init]: failed to initialize shared memory service
[ 1.157629] [vc_sm_connected_init]: end - returning -1
[ 1.158783] 3f201000.uart: ttyAMA0 at MMIO 0x3f201000 (irq = 87, base_baud = 0) is a PL011 rev2
[ 1.158998] of_cfs_init
[ 1.159043] of_cfs_init: OK
[ 1.159376] Warning: unable to open an initial console.
[ 1.161889] Freeing unused kernel memory: 3528K (808c4000 - 80c36000)
[ 1.193679] mmc0: host does not support reading read-only switch, assuming write-enable
[ 1.197275] mmc0: new high speed SDHC card at address e624
[ 1.198282] mmcblk0: mmc0:e624 SS16G 14.8 GiB
[ 1.205048] mmcblk0: p1 p2 p3 p4 < p5 p6 >
[ 1.223270] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[ 1.223953] Indeed it is in host mode hprt0 = 00021501
[ 1.224829] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 1.226352] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 1.229118] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[ 1.321945] mmc1: new high speed SDIO card at address 0001
[ 1.403899] usb 1-1: new high-speed USB device number 2 using dwc_otg
[ 1.404076] Indeed it is in host mode hprt0 = 00001101
[ 1.604293] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
[ 1.604314] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 1.605232] hub 1-1:1.0: USB hub found
[ 1.605336] hub 1-1:1.0: 5 ports detected
[ 1.657076] udevd[328]: starting version 230
[ 1.659712] random: udevd: uninitialized urandom read (16 bytes read, 47 bits of entropy available)
[ 1.660198] random: udevd: uninitialized urandom read (16 bytes read, 47 bits of entropy available)
[ 1.660357] random: udevd: uninitialized urandom read (16 bytes read, 47 bits of entropy available)
[ 1.660506] random: udevd: uninitialized urandom read (16 bytes read, 47 bits of entropy available)
[ 1.665887] random: udevadm: uninitialized urandom read (16 bytes read, 48 bits of entropy available)
[ 1.666163] random: udevadm: uninitialized urandom read (16 bytes read, 48 bits of entropy available)
[ 1.666283] random: udevadm: uninitialized urandom read (16 bytes read, 48 bits of entropy available)
[ 1.666701] random: udevadm: uninitialized urandom read (16 bytes read, 48 bits of entropy available)
[ 1.667110] random: udevadm: uninitialized urandom read (16 bytes read, 48 bits of entropy available)
[ 1.667536] random: udevadm: uninitialized urandom read (16 bytes read, 48 bits of entropy available)
[ 1.883889] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[ 1.984120] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[ 1.984141] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 1.987206] smsc95xx v1.0.4
[ 2.047662] smsc95xx 1-1.1:1.0 eth0: register āsmsc95xxā at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:5e:a3:c7
[ 2.725239] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 2.780776] EXT4-fs (mmcblk0p5): recovery complete
[ 2.782186] EXT4-fs (mmcblk0p5): mounted filesystem with ordered data mode. Opts: (null)
[ 3.063853] usb 1-1.5: new full-speed USB device number 4 using dwc_otg
[ 3.116427] systemd[1]: System time before build time, advancing clock.
[ 3.158445] systemd[1]: systemd 230 running in system mode. (-PAM -AUDIT -SELINUX +IMA -APPARMOR +SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT +GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN)
[ 3.158963] systemd[1]: Detected architecture arm.
[ 3.163657] systemd[1]: Set hostname to .
[ 3.169652] usb 1-1.5: New USB device found, idVendor=10cf, idProduct=0b1b
[ 3.169670] usb 1-1.5: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 3.169683] usb 1-1.5: Product: VMB1USB Velbus USB interface
[ 3.169695] usb 1-1.5: Manufacturer: Velleman Projects
[ 3.510180] systemd[1]: brcm43438.service: Cannot add dependency job, ignoring: Unit brcm43438.service is masked.
[ 3.514581] systemd[1]: Listening on udev Kernel Socket.
[ 3.530770] systemd[1]: Listening on udev Control Socket.
[ 3.531007] systemd[1]: Listening on Syslog Socket.
[ 3.531113] systemd[1]: Reached target Login Prompts.
[ 3.531376] systemd[1]: Listening on Journal Socket.
[ 3.531747] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 3.533469] systemd[1]: Created slice User and Session Slice.
[ 3.533664] systemd[1]: Listening on Journal Socket (/dev/log).
[ 3.533763] systemd[1]: Reached target Swap.
[ 3.534113] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[ 3.534216] systemd[1]: Reached target Remote File Systems.
[ 3.534848] systemd[1]: Created slice System Slice.
[ 3.564160] systemd[1]: Mounting Temporary Directoryā¦
[ 3.567191] systemd[1]: Mounting POSIX Message Queue File Systemā¦
[ 3.582371] systemd[1]: Starting Journal Serviceā¦
[ 3.582606] systemd[1]: Reached target Slices.
[ 3.586174] systemd[1]: Starting Setup Virtual Consoleā¦
[ 3.589573] systemd[1]: Mounting Configuration File Systemā¦
[ 3.594484] systemd[1]: Mounting Debug File Systemā¦
[ 3.600715] systemd[1]: Starting Apply Kernel Variablesā¦
[ 3.608160] systemd[1]: Starting Remount Root and Kernel File Systemsā¦
[ 3.616923] systemd[1]: Starting Create list of required static device nodes for the current kernelā¦
[ 3.635875] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 3.635995] systemd[1]: Mounted Configuration File System.
[ 3.636252] systemd[1]: Mounted Debug File System.
[ 3.636469] systemd[1]: Mounted POSIX Message Queue File System.
[ 3.636650] systemd[1]: Mounted Temporary Directory.
[ 3.659806] systemd[1]: Started Setup Virtual Console.
[ 3.661234] systemd[1]: Started Apply Kernel Variables.
[ 3.662200] systemd[1]: Started Remount Root and Kernel File Systems.
[ 3.663151] systemd[1]: Started Create list of required static device nodes for the current kernel.
[ 3.675460] systemd[1]: Starting udev Coldplug all Devicesā¦
[ 3.682060] systemd[1]: Starting Create Static Device Nodes in /devā¦
[ 3.700315] systemd[1]: Started Journal Service.
[ 4.245004] bcm2835-wdt 3f100000.watchdog: Broadcom BCM2835 watchdog timer
[ 4.284937] bcm2708_i2c 3f804000.i2c: BSC1 Controller at 0x3f804000 (irq 83) (baudrate 100000)
[ 4.320522] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000
[ 4.680708] cdc_acm 1-1.5:1.0: ttyACM0: USB ACM device
[ 4.681677] usbcore: registered new interface driver cdc_acm
[ 4.681693] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 4.971860] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ 5.021064] usbcore: registered new interface driver brcmfmac
[ 5.146509] brcmfmac: brcmf_c_preinit_dcmds: Firmware version = wl0: Aug 29 2016 20:48:16 version 7.45.41.26 (r640327) FWID 01-4527cfab
[ 5.165338] cfg80211: World regulatory domain updated:
[ 5.165361] cfg80211: DFS Master region: unset
[ 5.165370] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[ 5.165385] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 5.165399] cfg80211: (2457000 KHz - 2482000 KHz @ 20000 KHz, 92000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[ 5.165411] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[ 5.165424] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[ 5.165438] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[ 5.165451] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[ 5.165462] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[ 5.165474] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[ 5.167555] brcmfmac: brcmf_cfg80211_reg_notifier: not a ISO3166 code
[ 8.016427] random: nonblocking pool is initialized
[ 8.388975] i2c /dev entries driver
[ 8.408918] brcmfmac: power management disabled
[ 9.694374] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 9.756144] smsc95xx 1-1.1:1.0 eth0: hardware isnāt capable of remote wakeup
[ 9.756526] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 9.784055] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 9.823192] brcmfmac: brcmf_add_if: ERROR: netdev:wlan0 already exists
[ 9.823218] brcmfmac: brcmf_add_if: ignore IF event
[ 9.829259] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 9.829300] brcmfmac: power management disabled
[ 10.350699] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 10.350723] brcmfmac: power management disabled
[ 10.642210] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 11.278967] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 11.279943] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0xCDE1
[ 11.682242] EXT4-fs (mmcblk0p6): mounted filesystem with ordered data mode. Opts: (null)
[ 15.368930] aufs au_opts_verify:1606:dockerd[804]: dirperm1 breaks the protection by the permission bits on the lower branch
[ 15.652119] Bridge firewalling registered
[ 16.071017] IPv6: ADDRCONF(NETDEV_UP): docker0: link is not ready
[ 16.264218] IPv6: ADDRCONF(NETDEV_UP): hassio: link is not ready
[ 20.095809] device vethff05f30 entered promiscuous mode
[ 20.096263] IPv6: ADDRCONF(NETDEV_UP): vethff05f30: link is not ready
[ 20.205729] device veth28e1f8d entered promiscuous mode
[ 20.206620] IPv6: ADDRCONF(NETDEV_UP): veth28e1f8d: link is not ready
[ 20.206645] hassio: port 1(veth28e1f8d) entered forwarding state
[ 20.206723] hassio: port 1(veth28e1f8d) entered forwarding state
[ 20.210712] hassio: port 1(veth28e1f8d) entered disabled state
[ 21.085620] eth0: renamed from veth4b3f362
[ 21.125320] IPv6: ADDRCONF(NETDEV_CHANGE): vethff05f30: link becomes ready
[ 21.125426] docker0: port 1(vethff05f30) entered forwarding state
[ 21.125486] docker0: port 1(vethff05f30) entered forwarding state
[ 21.125638] IPv6: ADDRCONF(NETDEV_CHANGE): docker0: link becomes ready
[ 21.486683] eth1: renamed from vethba26889
[ 21.526353] IPv6: ADDRCONF(NETDEV_CHANGE): veth28e1f8d: link becomes ready
[ 21.526494] hassio: port 1(veth28e1f8d) entered forwarding state
[ 21.526586] hassio: port 1(veth28e1f8d) entered forwarding state
[ 21.526920] IPv6: ADDRCONF(NETDEV_CHANGE): hassio: link becomes ready
[ 32.773999] device vethf466cab entered promiscuous mode
[ 32.775500] IPv6: ADDRCONF(NETDEV_UP): vethf466cab: link is not ready
[ 34.145693] eth0: renamed from veth57d1a0f
[ 34.185769] IPv6: ADDRCONF(NETDEV_CHANGE): vethf466cab: link becomes ready
[ 34.185916] hassio: port 2(vethf466cab) entered forwarding state
[ 34.186004] hassio: port 2(vethf466cab) entered forwarding state
[ 36.143826] docker0: port 1(vethff05f30) entered forwarding state
[ 36.543823] hassio: port 1(veth28e1f8d) entered forwarding state
[ 40.042983] udevd[9]: starting version 3.2.2
[ 40.059756] udevd[9]: starting eudev-3.2.2
[ 49.223866] hassio: port 2(vethf466cab) entered forwarding state
[ 352.550558] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 352.550612] brcmfmac: power management disabled
core-ssh:~#
Kind regards,
Geert
