The logs show that Home Assistant receives the correct data (CounterValueMessage with power and energy), the only problem that needs to be fixed is setting consumption and injection as sensors when initialising in Home Assistant instead of binary_sensors.
I’m not sure how to do this, otherwise I’d be happy to help!
I have home assistant running with velbus (on a raspberry pi 4) which is connected through ethernet to the signum module.
I installed a new PIRO module, and this module is detected, but not recognised:
025-10-19 22:03:17.803 INFO (MainThread) [velbus-handler] Found module at address 55 (0x37): VMBPIRO-20
Strangly enough, the log says adress 55 and afterwards no spec for 59?
I already tried changing the adress, but this changed the adresses also in the log of home assistant, but didnt get the module in home assistant.
I have another (older) PIRO which does work:
2025-10-19 22:03:17.589 INFO (MainThread) [velbus-handler] Found module at address 44 (0x2c): VMBPIRO
I upgraded my Velbus Signum so now it uses Home Assistant instead of OpenHAB. However, since I’ve done that, the integration in my original Home Assistant stopped working. All entities were marked as disabled and reloading did nothing. So I removed the integration and added it again, but still not all devices are showing up.
Weirdly, some devices pop up sometimes and disappear again later. I have all VMB8PBU (switches) devices popping up quite consistently, and one time the VMBGP1 (touchpads & heating) devices showed up as well, but I’m always missing the VMB4RYLD devices, which contain the lights so are quite important.
Lastly, the logs show this:
2025-10-28 16:11:00.622 ERROR (MainThread) [homeassistant.components.binary_sensor] Setup of platform velbus is taking longer than 60 seconds. Startup will proceed without waiting any longer.
2025-10-28 16:11:00.623 ERROR (MainThread) [homeassistant.components.button] Setup of platform velbus is taking longer than 60 seconds. Startup will proceed without waiting any longer.
2025-10-28 16:11:00.623 ERROR (MainThread) [homeassistant.components.climate] Setup of platform velbus is taking longer than 60 seconds. Startup will proceed without waiting any longer.
2025-10-28 16:11:00.623 ERROR (MainThread) [homeassistant.components.cover] Setup of platform velbus is taking longer than 60 seconds. Startup will proceed without waiting any longer.
2025-10-28 16:11:00.623 ERROR (MainThread) [homeassistant.components.light] Setup of platform velbus is taking longer than 60 seconds. Startup will proceed without waiting any longer.
2025-10-28 16:11:00.623 ERROR (MainThread) [homeassistant.components.select] Setup of platform velbus is taking longer than 60 seconds. Startup will proceed without waiting any longer.
2025-10-28 16:11:00.624 ERROR (MainThread) [homeassistant.components.sensor] Setup of platform velbus is taking longer than 60 seconds. Startup will proceed without waiting any longer.
2025-10-28 16:11:00.624 ERROR (MainThread) [homeassistant.components.switch] Setup of platform velbus is taking longer than 60 seconds. Startup will proceed without waiting any longer.
And then a lot of these
2025-10-28 16:11:31.179 INFO (MainThread) [velbus-handler] Scan module 25 failed: not present or unavailable
2025-10-28 16:11:31.179 INFO (MainThread) [velbus-handler] Starting handling scan 26
2025-10-28 16:11:31.180 INFO (MainThread) [velbus-handler] Starting scan 26
2025-10-28 16:11:34.183 INFO (MainThread) [velbus-handler] Scan module 26 failed: not present or unavailable
2025-10-28 16:11:34.183 INFO (MainThread) [velbus-handler] Starting handling scan 27
2025-10-28 16:11:34.184 INFO (MainThread) [velbus-handler] Starting scan 27
2025-10-28 16:11:37.185 INFO (MainThread) [velbus-handler] Scan module 27 failed: not present or unavailable
And finally these
2025-10-28 16:22:58.917 ERROR (MainThread) [homeassistant.components.binary_sensor] Platform velbus does not generate unique IDs. ID 39884-1 already exists - ignoring binary_sensor.garage_licht
2025-10-28 16:22:58.919 ERROR (MainThread) [homeassistant.components.binary_sensor] Platform velbus does not generate unique IDs. ID 39884-2 already exists - ignoring binary_sensor.garage_poort
2025-10-28 16:22:58.920 ERROR (MainThread) [homeassistant.components.binary_sensor] Platform velbus does not generate unique IDs. ID 39515-1 already exists - ignoring binary_sensor.garage_licht_2
2025-10-28 16:22:58.921 ERROR (MainThread) [homeassistant.components.binary_sensor] Platform velbus does not generate unique IDs. ID 39515-2 already exists - ignoring binary_sensor.garage_poort_2
2025-10-28 16:22:58.947 ERROR (MainThread) [homeassistant.components.binary_sensor] Platform velbus does not generate unique IDs. ID 30036-1 already exists - ignoring binary_sensor.toilet
2025-10-28 16:22:58.948 ERROR (MainThread) [homeassistant.components.binary_sensor] Platform velbus does not generate unique IDs. ID 5194-1 already exists - ignoring binary_sensor.berging
2025-10-28 16:22:58.951 ERROR (MainThread) [homeassistant.components.button] Platform velbus does not generate unique IDs. ID 39884-2 already exists - ignoring button.garage_poort
2025-10-28 16:22:58.959 ERROR (MainThread) [homeassistant.components.button] Platform velbus does not generate unique IDs. ID 39515-2 already exists - ignoring button.garage_poort_2
2025-10-28 16:22:58.972 ERROR (MainThread) [homeassistant.components.light] Platform velbus does not generate unique IDs. ID 39884-2 already exists - ignoring light.led_garage_poort
2025-10-28 16:22:58.974 ERROR (MainThread) [homeassistant.components.light] Platform velbus does not generate unique IDs. ID 39515-2 already exists - ignoring light.led_garage_poort_2
2025-10-28 16:22:58.979 ERROR (MainThread) [homeassistant.components.select] Platform velbus does not generate unique IDs. ID 39884-96-program_select already exists - ignoring select.selected_program
2025-10-28 16:22:58.980 ERROR (MainThread) [homeassistant.components.select] Platform velbus does not generate unique IDs. ID 39515-96-program_select already exists - ignoring select.selected_program_2
2025-10-28 16:22:58.980 ERROR (MainThread) [homeassistant.components.select] Platform velbus does not generate unique IDs. ID 30036-96-program_select already exists - ignoring select.selected_program_3
2025-10-28 16:22:58.980 ERROR (MainThread) [homeassistant.components.select] Platform velbus does not generate unique IDs. ID 5194-96-program_select already exists - ignoring select.selected_program_4
Does anyone have any idea how to fix this? Thanks in advance!
Hi @Cereal2nd, the Velbus integration is failing when using the latest HA 2025.12.0 (Velbus 2025.11.0). In HA 2025.11.0 no problem with Velbus.
Any ideas ?
2025-12-05 14:38:13.253 ERROR (MainThread) [homeassistant.components.binary_sensor] Error while setting up velbus platform for binary_sensor: 10
File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 451, in _async_setup_platform
await asyncio.shield(awaitable)
File "/usr/src/homeassistant/homeassistant/components/velbus/switch.py", line 23, in async_setup_entry
await entry.runtime_data.scan_task
KeyError: 10
2025-12-05 14:38:13.254 ERROR (MainThread) [homeassistant.components.button] Error while setting up velbus platform for button: 10
KeyError: 10
2025-12-05 14:38:13.255 ERROR (MainThread) [homeassistant.components.climate] Error while setting up velbus platform for climate: 10
KeyError: 10
2025-12-05 14:38:13.255 ERROR (MainThread) [homeassistant.components.cover] Error while setting up velbus platform for cover: 10
KeyError: 10
2025-12-05 14:38:13.256 ERROR (MainThread) [homeassistant.components.light] Error while setting up velbus platform for light: 10
KeyError: 10
2025-12-05 14:38:13.257 ERROR (MainThread) [homeassistant.components.select] Error while setting up velbus platform for select: 10
KeyError: 10
2025-12-05 14:38:13.257 ERROR (MainThread) [homeassistant.components.sensor] Error while setting up velbus platform for sensor: 10
KeyError: 10
2025-12-05 14:38:13.258 ERROR (MainThread) [homeassistant.components.switch] Error while setting up velbus platform for switch: 10
KeyError: 10
