Everything works as expected. It’s just this one thing that I’m having an issue with.
Hardcoding room numbers in the params works fine, but calling a sensor’s state here instead to allow dynamic room selection doesn’t seem to work unfortunately.
Hello everyone,
I have been trying for weeks to setup my HA with my xiaomi vacuum s20+ but no luck.
As the map extractor is not working, I am using a img as background, but what I would like to do it, create the sections and click on the section to send the vacuum to the room with default settings used on the app, is that possible?
I have installed xiaomi vacuum miot auto and I was able to send the vacuum to the room using call action, however, I want to integrate it in the map.
Thanks for the answers.
I see you guys all talk about the s20+ with the code xiaomi b108gl.
But my vacuum is the xiaomi c102gl, is this the reason i dont get the separate room cleaning working?
Hi Juan Manuel! your post is very usefull! I’m having some trouble with Xiaomi Vacum S12. I think its related to the attribute “params”. Can you help me please? I leave here the link to de s12 discussion: Support for Xiaomi S12 Roborock in Xiaomi Miio Integration - #13 by rubengonzalez96
Thanks!
how are you?
I also purchased a Xiaomi S20 Plus and am trying to get an automation to work to clean the selected rooms.
action: xiaomi_miot.call_action
entity_id: vacuum.xiaomi_b108gl_3de0_robot_cleaner
siid: 2
aiid: 13
params: |
{"room": [{{ states('sensor.vacuum_rooms') }}]}
Have you managed to get it to work?
Because if I use it with the sensor that has the rooms, it doesn’t work and doesn’t generate any errors.
Has anyone managed to get it to work?
Apologies for the delayed response! I ended up losing the will to live with it and gave up trying to use a state as the param. Instead I set up individual scripts to clean each room then used a separate script that, when run, checks if the relevant room helpers are switched on and triggers the script for each room in sequence. It’s a bit hacky as the vacuum attempts to return home after each room before it is interrupted and sent on to the next one. I have attached a screenshot of my script to give you an idea.
I am trying to get the same working for S20 PRO version, but I am not able to send vacuum in to the room. How I will find which parameters to set/define for respective actions? went through this thread and struggling to get this working. Thanks!
I had the same problem so I built a custom Lovelace card for using the xiaomi_miot integration that handles room by room selection natively (no scripts needed). It cleans all selected rooms in one run without returning home between rooms. GitHub: GitHub - tojolab/xiaomi-s20plus-vacuum-card: Room-by-room control card for Xiaomi Robot Vacuum S20+ via xiaomi_miot · GitHub
It works only with Xiaomi Miot integration (both in LAN mode and cloud).
Feedback would be greatly appreciated ![]()
