I was missing the support of friendly_name in the great modbus integration.
I don’t know if this is a big thing, but for me it seems logical to use it as I can use it in many other integration and makes live easier.
- name: nilan_temperature_room # T15 - Input.T15_Room - User panel room temperature
friendly_name: Nilan Panel Raumtemperatur
unit_of_measurement: '°C'
slave: 30
address: 215
scale: 0.01
count: 1
precision: 2
data_type: int
device_class: temperature
register_type: input
@janiversen
May I ask you directly if you can be so kind and support that?
I don’t think that it will get much votes here because it is only “cosmetic” / UI stuff…
Thx anyway for your great integration!
I can control my Nilan VP Compact with it and do great stuff with if!
Invalid config for [modbus]: [unique_id] is an invalid option for [modbus]. Check: modbus->modbus->0->sensors->20->unique_id. (See /config/configuration.yaml, line 15).
unique_id may not be configured in yaml, it has to be provided by the integration.
Looking at the integrations code it seems it doesn’t. Would be a good feature request as it would also enable area support.
