Lovelace has a conditional card which can show cards when the state of an entity is equal or not equal to a certain string.
I would like to also be able to check against numerical values, so if a state is smaller or bigger than a numerical value. I would like to use this to display a warning markdown card.
For instance, a warning when my NAS HDD space is low. I can to this with persistent notifications, but would like to show a markdown card in lovelace.
It puzzles me that there isen’t a unified syntax for conditions. The entity-filter card has a syntax for mathematical conditions. Why it’ens it the same for conditional cards?
Some alignment would be nice here - and maybe reuse?!
Conditional card is basically very downsized. Has such a potential, e. g. by allowing other logical conditions (like OR which would greatly enhance the usage scenario for that card!). Hope this will be picked during this “2022 year of streamlining user experience” if I got that slogan right.
+1 here, i’d love to have it. No news?
My use case is showing the thermostat of Nest (my case only for heat) or A/C thermostat depending of outside temperature sensor… above something for example
For now I do it with the Season integration… but i’d love to have > and < to do more stuff
+1 here aswell.
for my use case i do a workaround with mushroom template card since i for the moment was after changing color of icon depending on a temperature sensor. but sure would be handy being able to do it in a conditional card instead.
How about another bump. This would be great for battery warnings, IE pop up the battery button if a battery is below 20% instead if it is at 20% but only for a limited time…
