Support of Aeotec Zigbee Pico (Duo) Switch requested
I would appreciate, if these two new products would be supported by the Zigbee Integration.
There are several versions of Zigbee available for use in Home Assistant. You did not specify which…
I am going to assume you are referring to ZHA, so I will address your question based on that.
Functions of individual ZHA devices are provided by the zigpy library as stated here:
Zigbee Home Automation - Home Assistant.
Requests for support for new hardware go in the zigpy github and not to Home Assistant.
Please read the pinned post before posting in Feature Request Topic…
Thanks for the hint
