Support of Somfy Thermostatic Valve
Dear Community,
I push forward the request to support Somfy Thermostatic Valve functionality to be handled in Overkiz cloud and also the new Local API
device (ValveHeatingTemperatureInterface)
FUNCTIONS AVAILABLE
  • Programming the thermostatic valve: In the thermostatic valve settings, it is possible to create two separate weekly programmes.
    These programmes are saved in the thermostatic valve and when activated, the programme will operate automatically in the event of an Internet interruption.
(Default:night from midnight to 6 a.m., at home from 6 a.m. to 9 p.m., night from 9 p.m. to midnight)
This programme incorporates the heating anticipation function which means the desired temperature is reached at the scheduled time. The algorithm learning period is approximately 1 week.
  • Direct Setting: The thermostatic valve can be Directly programmed (include temperature or mode orders in your typical days.)
4 modes available: AT home 21°C, night 19°C, absent 17°C, frost protection 8°C (factory values by default) + Personalised (the temperature of your choice)
Other settings:
  • Offset: temperature setting sensor (0°C by default)
  • Min. / Max.: allows temperature limits to be set on your thermostatic valve (5°C/26°C by default)
  • Locking - child mode: Child lock to block the temperature change on the thermostatic valve (deactivated by default).
  • Open window detection: If the temperature falls by more than 2°C in 10 minutes, the current mode stops and switches to open window mode = setpoint temperature of 8°C. The thermostatic valve will be reactivated if it detects a temperature increase of 0.5°C in less than 10 minutes.
